Diff Locks
Submitted: Thursday, Oct 28, 2010 at 14:22
ThreadID: 82169 Views:7532 Replies:12 FollowUps:8
Related Pages
Hi everyone. I have a 100 Series GXL. It has the standard limited slip diff in the back. I have a questions on diff locks:
1. At around $2,000 is a diff lock in the back signficantly better than staying with the current LSD?
2. With a diff lock on both front and rear, can anyone say what the relative benefit is of each. Is, say, the benefit split 70% at the back and 30% at the front?
3. Do lockers offer any benefit in sand, particularly when towing?
I'm planning to do a bit of camping with the family and already have a winch on the front and the usual recovery gear, which I hope not to have to use too often. Towing a camper trailer, I'm not keen on getting stuck with a young family on board.
At $3,000 - $4,000 for a pair of lockers fitted, I'm wondering if they offer any benefit for a punter like me or are they for the serious "yep I know there's an alternative track but I can get over that" off-road brigade.
I'd appreciate any thoughts.
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Oct 28, 2010 at 15:25
For general touring I say they aren't a necessity. Diff locks especially F&R will only get you more stuck. Your winch and a snatch block (or 2) will get you out of trouble 99% of the time. Just make sure you service it now and then.
You can get the LSD tricked up so it works better.
A rear locker in sand will help until you need to turn. Tyre pressures are the best for sand and if the sand is very powdery, drive in the cool of the morning or evening when the sand is denser.
Personally I have only used my winch in anger three times, 1st was to remove a bogged fairlane and boat out of a dam, 2nd was to pull my FIL and camper out of the Mitchell River near Dunbar in the Gulf and last was to pull myself out of a bog in CQ(broke the cable on that one).
Dave
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 434430
Reply By: Keith Berg - Thursday, Oct 28, 2010 at 15:49
Thanks Dave.
I think you have a point about the LSD getting you even more stuck.
How do you trick up the LSD?
AnswerID: 434432
Follow Up By: Member - Tour Boy ( Bundy QLD) - Thursday, Oct 28, 2010 at 16:14
The last LSD I had done I think they put shims behind the clutch packs to make them a bit tighter therefore work better or something along those lines. I'm sure a diff specialist will chime on in soon and let us know.
Dave
2015 Fortuner
FollowupID: 705524
Reply By: Robin Miller - Thursday, Oct 28, 2010 at 15:58
I spent some time studying this and eventually got twin lockers.
We spent some time filming and evaluating them on hills in Vic and came to the conclusion that the front diff lock had a dramatic effect on traction in most circumstances and the rear was some use , but mostly when going backwards.
It is important to understand the balance of your car first and I can only claim the results on both GQ & GU patrols - the cruiser has a slightly shorter wheelbase.
Central to the above you should take your car to a public weighbridge and weigh the front axle and rear axle in normal configuration.
If roughly the same you will benefit more from the front than the rear.
Just have got an additional Patrol and its weight balance full of fuel is 40kg heavier on front than rear which is about perfect.
I will probably not fit a rear locker to this new car with its good LSD - if yours is in good condition I wouldn't go with rear.
Sand is tricky - in a recent post a few weeks ago we were unable to get as far up a tricky sand hill with lockers on due to wheel hop.
Always a $150 set of chains will beat lockers on dirt/muddy tracks and a set of Maxtrax will beat lockers on sand.
Robin Miller
AnswerID: 434434
Follow Up By: Member - Captain (WA) - Saturday, Oct 30, 2010 at 21:19
Gotta agree about fitting to the front - much better IMHO. Others will swear by the rear fitment, but I have always found a front fitment to give a much better overall benefit. Also, factor in the fact that all vehicles have better rear wheel travel then front (particularly IFS vehicles) and I do not understand why anybody fits a locker to the rear first.
Captain
PS. YMMV
FollowupID: 705729
Follow Up By: River Swaggie - Sunday, Oct 31, 2010 at 21:42
Hiya Robin
Been saying this for years..I'd put a front airlocker on my Hilux at some stage.Everyone seems to say the rear...There not going to convince me lol..
Reece bought you up the other day....
Catch Ya
FollowupID: 705813
Reply By: ben_gv3 - Thursday, Oct 28, 2010 at 16:23
Toyata's are known to have woeful LSDs compared to Nissans.
Instead of an airlocker have you considered an autolocker, eg Lockright? Much cheaper and no airlines, air compressor to worry about.
AnswerID: 434436
Follow Up By: Gossy - Friday, Oct 29, 2010 at 15:13
agree. you can have one fitted for $600 - $700 with exactly the same result and less things to go wrong.
FollowupID: 705596
Follow Up By: Member - Ian H (NSW) - Friday, Oct 29, 2010 at 18:49
Yep, me too. I fitted a Lock Right auto "UNLOCKER" in the front of our 80 series (part time 4wd) back in 1998 and it has been great off road.
FollowupID: 705610
Reply By: Member - Duncs - Thursday, Oct 28, 2010 at 16:40
My previous vehicle a GQ had 2 ARB Diff Locks.
I owned it through that stage in my life where I wanted to get to the top of every hill I laid eyes on. I succeeded. I never got stuck with both diff locks in, but if I ever had I would have been monumentally stuck.
On sand the diff locks buried me quicker than any other mistake I made. I would not use diff locks on sand, let the tyres down and be gentle.
I used that vehicle for trips to Cape Yorke, Victorian Deserts and various shorter trips. Apart from one spot in the Blue Mountains I never used the diff locks while travelling with the family and never at all while travelling with the Camper Trailer.
My current vehicle is a GU. I intended fitting diff locks when I first got the car but never got around to it. I have done many family touring miles in this vehicle including towing the camper through parts of the Vic High Country. Only once have I been in a situation where the diff locks would have been really nice. Not having them I got out of trouble by applying a bit of brain power.
Would I fit them to the GU? Absolutely but only if I had nothing else to spend my money on and even then only if I was travelling alone in really steep country.
Duncs
AnswerID: 434437
Reply By: Crackles - Thursday, Oct 28, 2010 at 19:34
1: Yes they are significantly better particually in deep ruts & over rock ledges. Slip diff doesn't work offroad.
2: I'd use the rear locker more mainly because it doesn't effect the steering as much. Front locker is engaged briefly for difficult obsticals.
3: Lockers both front & rear more often than not make sand driving worst. Only time I'd engage mine would be to restart in very soft sand then turn off once going. Have heard of several people blowing up CV's when turning in sand with locker engaged from extreme axle wind up.
If you are not sure if you need lockers I'd suggest you probably don't. For towing in the desert spend your money instead on good tyres, a spring lift & a tyre gauge.
Cheers Craig.............
AnswerID: 434444
Reply By: rumpig - Thursday, Oct 28, 2010 at 21:20
sand driving is all about tyre pressures IMHO, reduce your tyres to the correct pressure and you shouldn't get stuck to start with. if you do get stuck then knowing how to unbog yourself easily is better then owning diff locks i reckon.
personally i reckon reducing tyre pressure and using Maxtrax are the easiest way to unbog a vehicle in sand (others will have their opions of what they use aswell i know), by far they are the easiest method i have used to unbog many a 4wd stuck in the sand (usually they are stuck from to high a tyre pressure in the first place though).
if you do go the air locker route, then look at a solid pinion spacer in the front diff at the same time the locker is fitted, 100 series cruisers are known for their weak front diffs (i've busted a crown wheel and pinion in mine once already), and this helps to strengthen the front diff abit.
AnswerID: 434462
Reply By: Member Brian (Gold Coast) - Thursday, Oct 28, 2010 at 21:46
My 2 cents worth..... FWIW.
This winter (Late June- Early August) we spent touring the outback. Our rig is a GQ Patrol, 3" lift, after market turbo 4.2L diesel, towing a Track Tvan. We drove the Strzelecki, Birdsville, and Oodnadatta tracks, the Mereenie Loop and crossed the Simpson Desert. I don't have lockers, but I am lucky enough to have one of the Nissan REALLY good Limited Slip Diffs.
I have never driven a truck with lockers, although I have many friends who have them, but they don't use them on sand.
Would I have them? If my LSD ever gives out, I would consider it rather than have a rebuilt LSD in the truck, but again, I wouldn't use them on sand. Sand driving is Tyre Pressures and Momentum!
The only downfall I see is the Toyota LSD is renowned for not being being as "tough" (for want of a better word,) as the Nissan. Having said that, our travel partners on the trip own an 80 series, without lockers and they had no drama's either.
If your LSD packs it in, and the lockers are not too much more than rebuilding your diff, maybe consider the lockers. If the LSD is still good, and you're just doing touring style 4wd'ing as opposed to comp style rock crawling /hill climbing etc... maybe stick with the LSD and spend your money elsewhere.
Hope I haven't confused you Keith, and all the best whichever way you go!
Brian
AnswerID: 434467
Reply By: Member Brian (Gold Coast) - Thursday, Oct 28, 2010 at 21:58
Brian
AnswerID: 434469
Follow Up By: Member - Matt M - Friday, Oct 29, 2010 at 16:02
That's 4 cents you've had now Brian.
FollowupID: 705604
Follow Up By: Member Brian (Gold Coast) - Friday, Oct 29, 2010 at 19:42
Matt!!! GOLD!!!!!!!!!!!!!!!!!!!!!!!!
LOL!
Brian
FollowupID: 705616
Reply By: Barra-2 - Friday, Oct 29, 2010 at 15:27
Hi Keith
My 100 Series O6 Sahara has dual Air Lockers and I love them.
A mate managed to get my Cruiser bogged in sand, and I tried reversing and going forward with correct tyre pressures, no go. Engaged both lockers, and the beast with STT tyres clawed it's way out. I was told there were 2 huge sand castles left behind me.
Recently in the (Lake) Simpson I used the rear locker a lot because it's there to use, one of the guys said try it without it, and I did, and I felt a great difference. My response to him was that was like going to Kings Cross without protection...
http://www.4wdaction.com.au/forum/viewtopic.php?f=129&t=97164&start=0
Over the dunes I was towing a trailer and didn't have the need to use the locker as the sand was firm.
I use the rear more often, even when it's not really needed, just so it eases any stress on the Cruiser
AnswerID: 434543
Follow Up By: Barra-2 - Friday, Oct 29, 2010 at 15:44
FYI - ARB Air Lockers & Compressor $3,200.00 Installed, Air hose, and puncture repair kit included too. This was a special ARB was running ealier this year.
FollowupID: 705603
Reply By: Keith Berg - Friday, Oct 29, 2010 at 19:58
Thank you for all your replies. I have learned more about diff lockers from you blokes in the last 24 hours than I have by reading a year's worth of off road magazines. Thanks again.
Keith
AnswerID: 434560
Reply By: Member - Gavan F (WA) - Saturday, Oct 30, 2010 at 20:28
Hi Keith
One thing not mentioned so far is that with lockers you can just crawl over most obstacles. When you get a tyre off the ground in normal circumstances most people rock back and give there beast a little more herbs to push them through ( a few will change there line). With lockers you will just walk over every thing. Your wife and kids will feel safer. If you have the coin ,do it. My preference is for a locker that you can turn on and off as you wish ( I have also had a Lock right on a Triton.)
ARB Lockers wiring loom makes you use the rear locker first before you can engage the front one. (interlock system),not to say you cant just fit a front one ..And your LSD will not perform nearly as good as a Locker they still require a certain amount of down force to work.
Also as someone else mentioned ,buy the best tyres you can afford..(probably at least $340 each)
Both of my max trax's have broken ,they look pretty on the roof rack but didn't fair so well under the Cruiser
Regards Gavan
AnswerID: 434642
