Km/L Verses L/Km
Submitted: Monday, Jul 20, 2009 at 09:51
ThreadID: 70828 Views:7146 Replies:21 FollowUps:44
G`Day all, I often wonder why most people calculate fuel consumption in Kilometres to the litre rather than the correct way of litres per 100 Km. Now I can understand why some of the older generation who went through the Miles per gallon era relate to, Km/Litre but I am also of that vintage and have made the adjustment. I just think when reading posts about fuel consumption it would be easier if we were all talking the same language.
Reply By: Gone Bush (WA) - Monday, Jul 20, 2009 at 09:54
I use Litres/100kms but I always convert it back to MPG so that I can understand it.....
AnswerID: 375347
Follow Up By: Member - Roachie (SA) - Monday, Jul 20, 2009 at 10:04
I have a few mates who do this as well...... I just don't get it at all???
Surely, once you've done a few calculations from L/100 back to MPG, you start to get a "feel" for what sort of economy you're achieving in "L/100", without the need to convert back to MPG??
For example (and I've forgotten what is good v not-so-good as regards MPG, so forgive me when I generalise)..... If you consider that 20MPG is about right for the type of vehicle you own and you do a few calculations and find that 20MPG = (say) 16L/100 (and I haven't done any calculations about this.....it's just an example), then surely you don't need to do the calculations every time in the future? If you do a subsequent check of fuel usage and find it's gone up to 18L/100, then you know you're not getting quite as good economy as you were before: It's all just relative to a known beginning point....
Or, am I missing something here? (that wouldn't be unusual)...hahahaha
Roachie
FollowupID: 642575
Follow Up By: Gone Bush (WA) - Monday, Jul 20, 2009 at 10:14
I think it's a strange thing pertinent to ageing baby boomers Roachie. You're one too but maybe you're not strange, I'll let other Forumites confirm or deny that....lol
I find that l/100 relates to distance, whereas mpg relates to consumption.
Does that make sense?
FollowupID: 642578
Follow Up By: Robert HL (SEQ)(aka zuksctr) - Monday, Jul 20, 2009 at 10:28
G'day Steve in short " NO".
Same as all things metric, it is so much easier to forget about Imperial measures
give it a go.Lo
Bob.
FollowupID: 642582
Follow Up By: Member - Kiwi Kia - Monday, Jul 20, 2009 at 10:48
If I have a fairly long distance between fuel locations I find it easiest to divide the known distance by my km / lt and relate that to my fuel capacity. E.g Carnegie - Warburton or Birdsville to Mt Dare. Divide the distance by the rate of consumption and then I know if I have enough tank capacity. Instant result no moving decimal points. Ask some people to add up a column of numbers and you may be surprised how many different ways people have of doing it. Some people do not add each number in succession but add like numbers and combinations that add to 10. This is not an uncommon method of addition. Different people have different ways of doing things so as long as satisfies that persons needs who cares. Lt per hundred km means nothing to me unless I am trying to compare motor vehicle manufactures brochures.
KK
FollowupID: 642589
Follow Up By: Member - John Q (QLD) - Monday, Jul 20, 2009 at 11:18
Hi Stephen,
MPG = KmpL, old school maybe, but then convert to Litres per 100KM so to keep up with the "new way of thinking". Good or bad, but many of us pre metric still like to convert back to Imperial out of sheer habit & don't get me started on rainfall measurements or feet/inches v cm/mm.
FollowupID: 642598
Follow Up By: Nargun51 - Monday, Jul 20, 2009 at 11:20
KK
I'm old enough to remember the introduction of "new math" in Victoria schools in the early 1960's (the year I started preps was the year it was introduced in the school I attended).
I have never grown up with the idea of adding each number individually, rather than adding as decimals. If your reasonably numerate, both ways you've described will give the same answer, but the first seems fraught with errors as you can't do it on your fingers :-)
I use l/100Km purely because its the accepted means under the SI system to use. If I use this, I can compare fuel consumption between different vehicles as a straight comparison, whereas to convert from km/l to l/100km needs another calculation, with the inherent capacity for errors to creep in
A forum such as this is about communication; if the majority use l/100km, it becomes common courtesy to speak the same language so others may understand.
FollowupID: 642600
Follow Up By: Madfisher - Monday, Jul 20, 2009 at 22:11
As another baby boomer when catching fish I like to weigh them in lbs ,and measure them in centimetres.
It also only taken me 30 years to get use to l/100(or even how to work it out lol) Like GB I still convert to mpg sometimes tro compare with cars I had years ago.
Cheers Pete
FollowupID: 642748
Reply By: wild dog - Monday, Jul 20, 2009 at 10:42
It's habit for me, I started my apprenticeship in '66 on Toyota and BMC. One metric one imperial, automatically I conevert one to the other. Having had to train apprentices over the years I became extremely impatient if they couldn't convert instantly. Thankfully I've retired and don't have to worry about it anymore.
The Chinese decided 18mm was a good size for bolt heads, just to confuse the issue.
If metrication is so important why are tyre and wheel sizes still in imperial ???
AnswerID: 375354
Follow Up By: Member - Kiwi Kia - Monday, Jul 20, 2009 at 10:52
And to make it worse your example of tyre sizes even includes a mixture of inches (rim diameter) and metric for the rubber ratios.
Some European countries have metric thread sizes that are different to their neighbouring countries thread sizes.
KK
FollowupID: 642591
Follow Up By: Member - ross m (WA) - Monday, Jul 20, 2009 at 13:08
Probably because America is still one of the biggest users of car wheels and they are still using imperial.
Wheels are actually a size. A 16 inch wheel is really a size 16 in Australia as it became illegal to offer products in imperial measurement.
But slowly metricifation with prevail in tyre dimensions. I doubt any new cars are sold with an imperial sized tyre these days
FollowupID: 642619
Follow Up By: Member - Effie C (NT) - Tuesday, Jul 21, 2009 at 05:21
ross m
It was only illegal during the phase in period to offer imperial measurement products, it is OK now to offer either way, Toyota still sell and advertise the wheel size on their cars in imperial. Unfortunately I am one of those stuck in the middle of the conversion from imperial and metric and I still use both. To make matters worse where I work use the the US system for all measurements and I am relearning lots of things I had already converted in the memory box
Live One Day at a Time for Tomorrow May Never Come.
FollowupID: 642791
Reply By: DesF - Monday, Jul 20, 2009 at 10:50
Hi Foxhound, I for one use Klm per litre, because I want to know how many Klm I am going to get for my set amount of litres, this is more inportant when we are travelling by Motor cycle, as we have say, 18lt in the tank and we get about 20ks per lt, I know I can go about 360ks before I would be walking.
By the way , who said that Ltrs per 100ks is the correct way.?
Cheers Des. Age 69.
AnswerID: 375355
Reply By: Member - Andrew (QLD) - Monday, Jul 20, 2009 at 10:52
I see nothing wrong with the use of X km/L if the units are included.
Looking at the test process to obtain values as we have adopted from the European Standards, it seems the L/km Units are of value to "average" any irregularities that may appear, whereas measuring economy of 1 litre is difficult to standardise IMO.
IMHO, standardised units should not involve arbitary values where possible eg 100km. Either choose km/L or L/km. :)
Andrew
AnswerID: 375356
Reply By: robertbruce - Monday, Jul 20, 2009 at 12:00
i use l/100k's on long straight roads
and k's/Litre in soft-sand, mud and hills...
l/100k's is almost usleless when 4x4ing...
AnswerID: 375362
Reply By: howie - Monday, Jul 20, 2009 at 12:04
i use the km/L cause i know roughly what the 4WD will do on different surfaces like soft sand/bitumen at different speeds 90/110km/hr and pulling the 2 different trailers.
known distance x km/L gives me the amount i need.
also find it easy to quickly check my usage at the pump, ie trip meter divided by litres put in.
nothing against the other method if that suits you.
AnswerID: 375363
Reply By: Member - Mfewster(SA) - Monday, Jul 20, 2009 at 12:24
Showing my age. I use L/100km. And then I do a rough calc back to mpg. I know I shouldn't have to do this, but I do. What's worse, I then start comparing the results with what I would have expected from a Holder FJ. If i'm getting better than I would have expected from an fJ, I feel things are good, if worse, I think it's heavy. Please don't ask me for for a rational explanation of this, I can't provide it. Just happens.
AnswerID: 375365
Reply By: Wok - Monday, Jul 20, 2009 at 12:32
I use km/l on black-top......when slower bush traveling I use hrs/rpm.
eng
AnswerID: 375368
Reply By: hl - Monday, Jul 20, 2009 at 12:54
Litres per 100k is what is quoted on all new cars on the economy sticker, so, that's the one that should be used. I can understand some of the ancients people frustration with metric. If the conversion had been done more sensibly, less people would have stuck with imperial. I remember in the seventies when it started and it was mandatory to use exact conversions on packaging, things like .453kg (1lb) or in a book I read once on maintaining a boat and trailer. It said to check the spark on the motor by holding the plug lead "about" 2.345mm from the block, or maximum trailer load of 907.2kg (2000lb)...
No wonder people got confused.
AnswerID: 375371
Reply By: Flywest - Monday, Jul 20, 2009 at 12:57
Common sense.
The new liters per 100 km's makes no common sense.
Thats coz it is base 100
Time however is base 60 - something those of us from the old school remember - we had shillings and sizpences remember, and half dozens and dozens, all 6's and 12's.
Time is base 6 calculation and goes well with Miles.
60 miles an hour is one mile a minute
How many kilomers per minute is that?
Exactly - base 100 when used with time (base 60) is fricken unwieldy and confusing.
So it makes a lot of sense to work in Miles per gallon and 60 miles in an hour, you can do mental math to see how much fuel your using and when you'll arrive some where (eta's).
Now we all kn0w how much a gallon is - its half a 2 gallon bucket full...
But - imagine it in liters - a buckets 9 liters and half a bucket is 4.5 liters
That's a handy VOLUME to "imagine" in ones minds eye..........as to trying to imagine how much fuel you have left to travel a certain distance in a given time (NOT!).
Metrics is damn confusing and not easy to imagine in ones minds eye.
If I am travelling at 1.6 kilometers per minute - how many minutes/hours will it take me to travel 480 kiometers, and how much fuel will I use at 9.37 liters / 100 km's????
Yeah thats easy mental math.... NOT!!!. (Hang on I'll just get out my pocket calculator - ohh damn the batteries are flat, never mind I'll use the mobile phone now what was the question again?....exactly! :rollseyes:
So lets look the SAME calculation it in old school values shall we?
It I am travelling at 1 mile a minute,(or 60 miles an hour) how long will it take me to travell 300 miles?
er 300 minutes divided by 60 = 5 hours, or 300 miles divided by 60 = 5 hours
That bit was too damn easy.
Now how much fuel will we need at 30 miles to the gallon?
Ahh 300 miles divided by 30 mpg = 10 gallons
Gee that was hard wasn't it?
I went 300 miles of 10 gallons I[m getting 30 miles per gallon..and I know ann average opf 25 miles per gallon is pretty good - 30 mpg is excellent...40 mpg would be about what a new hybrid car might expect to get.
The whole imperial system os EASY to use.
WHY - coz all our time and distances etc were base 6.
Even our coainage and notes were base 6
Kilometers and liters, will NEVER become easy to use for mental math until TIME is metricated and made into base 10
10 days in a week
100 days in ayear
10 hours in a day
10 minutes in a hour
10 seconds in a minute etc
Until you do that to time - then metrics will always remain a clusterphuk of monumental proportions, when we want to use it for travel - because time is involved and while time remains base 6 - anything else is just confusing!
Its designed to deliberately confuse people and make our kids mental math midgets.
It's worked, our kids are now dumbed down - they don't know their times tables and can't do mental math.
Metrics is responsible.
Once you could buy a half dozen nails, or a dozen or a pound of you wanted loose at the hardware, now they come in blister packs of 4! :rollseyes:
No wonder the fricken economy is screwed with the inbuilt waste age of metrics.
Quite simply metrics sucks for anything but calculators.
AnswerID: 375372
Follow Up By: wild dog - Monday, Jul 20, 2009 at 13:27
Your logic used to be discussed endlessly in some of the workshops I've been in.
Should we change to 100 mins/ hr ?
10hr/day ?
10 days/ week ?
100 weeks/ year ?
We are already half way there as we have 100 years / century !!!!!!!!!!!!!!!!!!
FollowupID: 642621
Follow Up By: Nargun51 - Monday, Jul 20, 2009 at 13:59
What a lot of dodo guano!
Go back 2000 years VII + IV = XI, obviously they did things better in the past!
Then some Arabs came up with the concept of Arabic numerals, based on the base of 10; units in the first column, multiple of 10’s in the next column, multiples of 10 x 10 (hundreds) in the next etc.... Most of us are used to that and are quite happy with it, except for those who work in computer systems and use a binary numerical system (on/off).
Funny how this took off wasn't it?
Base 10; easy to use, can count on your fingers (or taking your shoes off…to 20… or 50% of the population to 21 whilst risking a charge of indecent exposure). Most people understand the concept of decimal numeracy innately.
Back when we were kids we had to remember 12 pence to the shilling, 5 shillings to the Crown, but 20 shillings to the pound, or 21 shillings to the Guinea
16 ounces to the pound (lb Avoirdupois); 14 lb to the stone; 112 lb to the cwt and 20 cwt to the ton, or 2240 lb
Let’s not forget inches, feet, yards, rods, furlongs, miles and leagues
A lot easier to calculate wasn’t it?
Great idea if you didn’t have any concept of communicating or trading outside the town you were born.
Use whatever you want to for your own calculations, but as a courtesy to others please use what is the accepted standards of measurement that the majority use
After all, your concept of a smidgen, a bee’s genitalia or a country mile may be radically different to anybody else’s
FollowupID: 642624
Follow Up By: Member - Mfewster(SA) - Monday, Jul 20, 2009 at 14:09
The problem is the base of time, not a problem with metrics. Distance and area measurement that used inches, feet, yards and miles was only a base of 6 in a limited way, it was a hopeless mishmash and that's before we start considering chains and acres and roods etc. Money wasn't a base of 6 either. It was a mish mash of base 6 for pennies/shillings, but then we had the issue of pennies/shillings to pounds. If it reall was a base of 6 we would have had what is now 120 as the unit rather than 100. Let's not mention guineas and crowns. Metrics is much superior as a system and there is merit in adjusting time as well.
FollowupID: 642628
Follow Up By: wild dog - Monday, Jul 20, 2009 at 14:28
Hey Nargun51 totally agree with you.
You forgot the latest workshop manuals from China.
Torque figures in N/M instead of ft/lbs.
Of course 16 ounces to the pound is ok for some but not for reloading ammunition.
7000 grains = 1 lb of powder.
Depends who you're talking to and what about.
Seems that " the accepted standards of measurement that the majority use " still has not been decided on worldwide.
Haven't got into pressure yet have we ?? psi hectopascals kg/cm2 bar that is of course ignoring the barometer in inches of mercury.
Forgot about the thermostats in engines stamped in Farenheit and Celsius, nobody standardised that yet.
Still don't seem to have an "accepted standard" I just wish they'd hurry up and sort it out.
PS Our new rain gauge, marked in mm and inches, it's enough to make a man turn to drink !!!!!
FollowupID: 642631
Follow Up By: Member - Oldplodder (QLD) - Monday, Jul 20, 2009 at 22:02
Still reckon my slide rule is faster for working out that stuff, and it doesn'r need batteries.
FollowupID: 642746
Follow Up By: Welldone WA - Tuesday, Jul 21, 2009 at 02:09
Flywest
Bravo! Bravo! Give the man a twelve sided medal!!
The metric system doesn't completely suck , it's the politically correct axeholes that deem it mandatory to use inane , convoluted formulae to work out if you have enough juice to get from A to B, "litres per 100kilometres", what sort of non-prescription hallucinogenics were these non-driving, intellectual giants on??
MPG was a great method of mental calculation as it is simple multiplication [regardless of time] , Km/L [or if old school"KPL"]is the same simple multiplication excersise so if I look at my fuel gauge and the needle shows half a tank, I know that the 45litres left x 7KPL will get me 315 kilometres away ,easy!
The "proper" method means 7 into 100 which gives me 14.285714 litres per 100km, I then have to divide 45litres by [let's round for easy maths]14.3 which gives me a grand total of 3.1468531[again, let's round this up for easy maths]=3.15, now the final and easiest step ,moving the decimal point to the right two places to give me the kilometres left in my tank. If you were driving and attempting to do the mental mathematical gymnastics required by the "PC" method , you've got a statistically high chance of becoming a statistic!
Now, where did I put my "Imperial" Leather soap box?
OH! Look, I've been standing on it the whole time, what a wonderful view!
Welldone
FollowupID: 642780
Follow Up By: Flywest - Tuesday, Jul 21, 2009 at 17:36
Praise be to God - someone else who understands!
Take away the politically corrects liters / 100 km Pocket Calculator - and he / she would be lucky to find their way out of a Hungry Jacks drive thru!
If it ain't broke, don't fix it - too simple!.
Another gripe - there ARE no damn centimeters in the Australian Metric system.
You buy melamine sheet for your cabinet factory it comes in sizes 2400mm x 1800mm
NOT bloody 240 centimeters x 180 centimeters!
Why do we teach our damn kids centimeters at school?
I have a 20 year old whop to this day still can't read a damn tape measure properly - and gets all confused after the number of meters part - the milimetsr give him jipper!
I ask for the measurement and he uhms and aahhhs saying two meters 3 centimeters & 4 millimeters!
One might infer from that he MEANS 2034mm
Then I go cut the material only to find the REAL measurement wasn't 2034 at all - nope - more like 2340mm - but he just CANNOT get the idea of reading a tape without centimeters being in there somewhere and once that starts he's screwed - I might as well take all the damn measurements myself.
It's like having a dog and barking yourself!
Metrics is de work of de debil - no doubt about that!
FollowupID: 642870
Reply By: vk1dx - Monday, Jul 20, 2009 at 14:22
Personally I have also made the change to litres per 100 Km. 60+ young and still up to changing.
But here is the rub. When working out how much fuel I need to get to the next stop or how far I can get with the fuel I have on board I use the Lts per 100 Km figure.
As far as not talking the same language - What about the way some use psi and others use kpa etc etc. Too many inputs from too many countries and cultures and we get the mix we are in.
Hey I now know what "lol" means.
Just my two bobs worth.
AnswerID: 375383
Follow Up By: vk1dx - Monday, Jul 20, 2009 at 14:28
Whoops I got all mixed up there.
In the second paragraph I actually meant to type "kms per litre" NOT "Lts per 100 Km figure.
Clumsy. Concentrated too much on getting the spelling correct I think.
FollowupID: 642630
Follow Up By: Member - Graham H (QLD) - Monday, Jul 20, 2009 at 14:39
You will be Ok when the new auto spell checker comes on line.
Unfortunately we will still have duel batteries.
FollowupID: 642632
Follow Up By: Lex M (Brisbane) - Monday, Jul 20, 2009 at 16:09
here, here. :-)
FollowupID: 642645
Follow Up By: Member - Graham H (QLD) - Monday, Jul 20, 2009 at 16:33
Actually its "Hear Hear"
as per here here
http://www.randomhouse.com/wotd/index.pperl?date=19980304
Ha ha :-)))))))))))))
FollowupID: 642652
Follow Up By: Lex M (Brisbane) - Monday, Jul 20, 2009 at 16:42
Actually it's "Dual batteries".
I know it's "hear hear" you sirryiriot :-)
FollowupID: 642655
Follow Up By: Member - Graham H (QLD) - Monday, Jul 20, 2009 at 18:16
I was making a tongue in cheek reference to the fact that the spell checker wont know the difference.
Shame so many simply cant spell.
FollowupID: 642667
Follow Up By: Member - Roachie (SA) - Monday, Jul 20, 2009 at 18:28
Lex, I think the idea was that something like "duel batteries" still won't be picked-up by a spell-checker as the word "duel" is an actual word.....
Same thing goes for : " they went to have there lunch" ("there" instead of "their")........... or the one that really grinds on me is : "there going to be here at lunch time" (where "there" should be "they're")... etc
I could go on for many paragraphs, but will spare you the pain....hahahaha
Roachie
PS: I guess you could actually have a "duel battery system".... All you'd have to do would be to hook the batteries together the wrong way around and they would be "duelling" one another.....
FollowupID: 642670
Follow Up By: Lex M (Brisbane) - Monday, Jul 20, 2009 at 18:40
Come on guys - get with it.
I was commenting that " here here " would not be picked up by the spell checker as " here " is an actual word.....
But then it could be "here here" as opposed to " there there".............:-)
FollowupID: 642675
Follow Up By: Lex M (Brisbane) - Monday, Jul 20, 2009 at 22:22
The other thing that bugs me is the use of incorrect units.
EG 12 Volt appliance uses 5 Amps per hour.
No.No.No.
It uses 5 AmpHours per hour (or it uses 5 Amps.)
FollowupID: 642751
Follow Up By: V8 Troopie - Tuesday, Jul 21, 2009 at 01:10
No Lex 'It uses 5 Amp hours (5Ah), period. There is NO hour needed to add to the hour you already stated in Ah.
BTW, just 5 Amps would be also wrong if its a consumption over time, where Ah is correct.
5Amps is an instantaneous figure.
FollowupID: 642779
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 11:52
Wrong. Wrong. Wrong.
(Tearing out minimal remaining hair)
Quote
"No Lex 'It uses 5 Amp hours (5Ah), period. There is NO hour needed to add to the hour you already stated in Ah."
End Quote
This gives no accurate indication of power usage. How long was it used to use that 5 Amphours? An hour, A day, A week?
A device running continuously drawing 5 Amps uses 5 Amphours per hour, or 10 Amphours per 2 hours or 840 Amphours per week etc.
Amphours is a measure of power used. It's meaningless without knowing what period of usage used that power.
Quote
"5Amps is an instantaneous figure."
End Quote
Exactly. The power usage is now determined by how long this device is on.
Example.
A fridge running current is 5 Amps. It runs for 12 minutes every hour.
It's power usage is 5 X 12/60 Amphours every hour or 1 Amphour per hour.
Amphours is power used, not power used per hour. Don't be confused by the "hour" part of the name.
FollowupID: 642819
Follow Up By: vk1dx - Tuesday, Jul 21, 2009 at 11:58
What happened for watts for the power?
FollowupID: 642820
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 12:06
Good question.
Watts is instantaneous power usage. Watthours is total power usage, and technically the above references to power should really be energy usage rather than power usage.
I was trying to keep it simple.
FollowupID: 642823
Follow Up By: vk1dx - Tuesday, Jul 21, 2009 at 13:56
This is extweemeley helpful when it comeeth to KM/Lt or TL/KM.
I am sure the battewy will knot care one iota wheather its watts or whats or whatevers.
Always work out the worst case scenario and use that figure to see if the battewy will last.
ie 5 thingumys times hours equals the total whatsits that the battery must supply in the worst case. Now it has x whatsits on the battery and that is bigger than the number of whatsits I need therefore the fish will not thaw out before morning.
Now wear were we. Thats wight. Whee were wending our mewwy way down a twack wondewing what if we would get home. Kms/lt or Lt/Km. Use hwat ever you are comfortable with.
In a world that is heading to a point where accuracy means nothing who cares as long as you can work out if you can get home.
Stupid spell checker. It has a lisp.
Elmer Fudd
FollowupID: 642842
Follow Up By: vk1dx - Tuesday, Jul 21, 2009 at 13:57
Sorry all. Just couldn't resist that.
Phil (alias Elmer Fudd)
FollowupID: 642843
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 21, 2009 at 14:25
Love it. :-)
FollowupID: 642848
Follow Up By: V8 Troopie - Wednesday, Jul 22, 2009 at 00:41
Lex, we might have to disagree there, and sorry about your remaining hair ;-)
Quote:
"This gives no accurate indication of power usage. How long was it used to use that 5 Amphours? An hour, A day, A week? "
end of quote.
Think about that a bit. Got it? yes? If something consumed 5Ah that is all the info required to calculate battery drain between recharging.
If that something draws an instantaneous current of 5A then it was on for one hour.
If that something draws 0.5A then it was on for 10 hours.
So, knowing the Amps drawn and the Ah taken from the battery its easy to figure out how long it was switched on.
So, if one has several electrical items connected to a battery, one simply adds up the Ah (how many Amps over a given time, like: 1 Amp over a 24 hour period = 24Ah, 3 Amps for 1 hour = 3Ah; 24 + 3 = 27Ah total)
You might be happy quoting hour per hour figures but to me this looks silly.
Just like the land lubber who quotes a boat speed at 10 knots per hour, not knowing that 'knot' already means 1 nautical mile per hour.
FollowupID: 642926
Follow Up By: Lex M (Brisbane) - Wednesday, Jul 22, 2009 at 11:44
There are regular mentions in this forum and even in the articles on this sit.
"A Device uses 5Ah"
OK
I have a widget that uses 5Ah and I have a battery that can supply 100Ah.
How long can I use it for?
I cannot answer this question unless I make some assumption about that 5Ah usage figure. EG it used that 5Ah in 1 hour. That is it uses 5Ah per hour.
I could say I have a battery that can supply 360000 coulumbs and a device that uses 18000 coulumbs per hour. Would you accept that?
FollowupID: 642974
Follow Up By: Lex M (Brisbane) - Wednesday, Jul 22, 2009 at 11:47
Forgot this bit
"Just like the land lubber who quotes a boat speed at 10 knots per hour, not knowing that 'knot' already means 1 nautical mile per hour."
Quite correct a knot is 1 nautical mile per hour but an Amphour is not 1 Amp per hour, it is 1 Amp for 1 hour. Quite different.
FollowupID: 642977
Follow Up By: V8 Troopie - Thursday, Jul 23, 2009 at 00:24
Now I see where you miss it Lex.
"OK
How long can I use it for? "
If you have a 100Ah battery and you want to fully drain it you can use the above mentioned widget for 20 hours. Get it now?
Ah is a measure of Amps over time there is no compulsion to specify 1 A or one hour.
You can have a widget using 15Ah, 3Ah and so on. The first could be 15A for one hour or 5A for three hours or 0.1A for 150 hours - it still adds up to 15Ah.
When calculating power draw in a battery system one lists all the current ratings of the individual appliances. Then one lists for how long they are switched on in a given time interval, say 24 hours.
Multiplying the individual currents by the individual times one gets the individual Ah for a 24 hour period. You could do that for any time period but normally one chooses the time interval between battery recharging. Adding all the above Ah up gives the total power the battery has to supply for that period.
I sincerely hope I have enlightened you by now or I shall give up.
Klaus
FollowupID: 643097
Follow Up By: Lex M (Brisbane) - Thursday, Jul 23, 2009 at 14:16
Klaus,
You don't have to enlighten me.
I have 42 years of working in the electronic computer industry and several years of electronics experience prior to that.
Electronic terminology is my first language, English is my second.
I think I'm flogging a dead horse. You missed the pedantic points of my first and every other post. Obviously you understand how it works. I understand how it works.
Let's leave it at that.
Have a nice day.
FollowupID: 643159
Reply By: Member - Royce- Monday, Jul 20, 2009 at 18:53
I often wonder why one is 'correct' over the other. Both work?
AnswerID: 375417
Follow Up By: Robin Miller - Monday, Jul 20, 2009 at 19:19
I think one is correct because its the Australian standard Royce .
It took me a while but I got used to Lt/100k's and now I only wish that I used less of them.
Robin Miller
FollowupID: 642688
Follow Up By: Member - Royce- Monday, Jul 20, 2009 at 21:52
An Australian standard would be correct usage in an industry paper or a submission or maybe an ABC television presenter's manual....
But 'correct' infers that one is more appropriate or works better than the other. I'd argue that both are valid measures to communicate consumption of fuel.
I prefer how far you get to the litre above how many litres you use driving 100ks.
I can't remember gallons to 100 miles being used .... was it?
Doesn't really matter to me anyway.... I'm just killing time on the computer until something worth watching turns up on TV.
I just got a set top box and have found that more channels = same old stuff!
FollowupID: 642738
Reply By: kym111 - Monday, Jul 20, 2009 at 21:01
LOL
I'm a generation X, and think in MPG! I know that my Camry averages 23mpg, which roughly equates to 600kms to a tank of fuel (65-70ltr). If I want to get really pedantic, I give the brain a rest and use a cardboard slide rule from Caltex that gives me all three equations!
Kym
AnswerID: 375443
Reply By: PradOz - Monday, Jul 20, 2009 at 21:52
Oh dear! When I was growing up they always said never talk about politics or religion. I guess I just learnt about a third one to never bring up ;)
AnswerID: 375456
Reply By: Member - Oldplodder (QLD) - Tuesday, Jul 21, 2009 at 07:57
Glad we have metric.
I did my training at the end of imperial, and using 8 and 10 figure log tables with feet and inches working out slopes and distances was a pain.
Rough calculations were done on a slide rule.
1974/1975 metric and calculators came in and what a difference. Much easier.
Just have to watch myself to ensure I don't become lazy. Caught myself using the calculator to add up 2 + 2 the other day :o)
Only one problem now, is it a metre or a meter in kilometres(ers)?
Must get it right, it might affect my fuel consumption!
Yes, prefer litres per hundred kilometres, easier to use in the head, or on the slide rule when you have 100, or 350 kilometers to go. Multiply the 12 or 15, or even 10 at times, by 1 or 3.5.
AnswerID: 375486
Reply By: OzTroopy - Tuesday, Jul 21, 2009 at 14:36
Metric is great ... for lengths of steel, timber, and weights ... now that products are sold in metric measurements rather than, imperial converted to metric as it was done in the past.
Fuel use .... Imperial is the best way to go ... as in Flywests post - time & miles is a simpler and relative equation to a travelling circumstance.
My trip meter works litres per 100klm as does the consumption indicater ... all meant nothing to me until I sat down and did the sums so that 12.5/100 meant I was getting my expected, approx 20mpg loaded travel consumption. yes, yes, ... its 21 point something .... big deal
Now if I see 16/100 I know Im getting worse fuel economy ... about all there is to it really.
Biggest hassle I have come across is that all building measurements are in "mm" ... so "mm" is what I use ... Kids and Grandkids have been educated in "cm" and ask what a 1000mm are ..... pffffffft
AnswerID: 375526
Reply By: Member - Oldplodder (QLD) - Wednesday, Jul 22, 2009 at 08:04
Oztroopy,
Re cm and mm.
Been here before.
Wife is a teacher and I am in engineering.
She works in cm and I work in metres (m) and millimetres (mm).
Had some one from the federal government ring up the office about a job I was doing and wanted to know what length a particular item was. They were not in engineering, couldn't read a drawing, so I looked up the drawing and gave the measurement in mm as per the drawing. They wanted it in cm, so I converted, and commented (nicely) that mm and m are the correct units to use. They came back after a day or so and gently referred me to the Australian SI standards. Australia put their own twist on metric in 1974 by specifying cm as a recognized standard of measure.
Evidently cm has been used (and only in Oz) since 1974 as it related more easily to half an inch, or the width of a thumb or finger. Centimetres was thought to be an easier unit to understand by the general public at the time than mm. Centimetres was taught in the schools, and still is, as a basic unit of measure.
Just for the heck of it I use decimetres for utter confusion of every one. :o)
Be careful though, some one will have their revenge.
Now my son who is doing a doctorate in nanotechnology and a nanometre is a massive figure to him, so he talks in picometres, to stir his old dad. :o0
Prefix Symbol Meaning Factor by which unit is multiplied
tera T one million million 1012 1,000,000,000,000
giga G one thousand million 109 1,000,000,000
mega M one million 106 1,000,000
kilo k one thousand 103 1,000
hecto h one hundred 102 100
deka d ten 10 10
deci d one-tenth 10-1 0.1
centi c one-hundredth 10-2 0.01
milli m one-thousandth 10-3 0.001
micro µ one-millionth 10-6 0.000,001
nano n one-thousand millionth 10-9 0.000,000,001
pico p one-million millionth 10-12 0.000,000,000,001
AnswerID: 375618
Follow Up By: wild dog - Wednesday, Jul 22, 2009 at 08:32
Hi Oldplodder
Wonder how long this subject will go on ??
I've always wondered why my micrometer measures to one thousandth when as per your list milli is one thousandth.
Should they have been called millimeter, it's all sounding a bit weird it is early in the morning though.
FollowupID: 642947
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Jul 22, 2009 at 08:45
Wild dog,
Suppose your micrometer is measuring to a thousandth of a millimetre, or a micrometre (!). Don't think so, a micrometre is pretty small in engineering.
And I thought a thousandth of an inch was small until my son started nanotechnology. He rattles off the picometre dimensions of atoms of some of the periodic table.
But for all of us who drive a thousand kilometres in a day, we should declare we belong to the megametre club. Doesn't sound the same does it?
And to think the metre was originally contrived by the french to be a millionth of the length of the longtitude through Paris. There were out by a little I think.
FollowupID: 642949
Follow Up By: OzTroopy - Wednesday, Jul 22, 2009 at 09:10
picometres ... lol ... cheeky kids.
Not a bad measurement though .... wonder if I could quote jobs using it ... might help to fudge the profit levels ... lol
Doctorates in nanotechnology ??? .... certainly goes to show we are the clever country eh ??? ... although the "cm" / "mm" debacle spoils the that line of thinking.
FollowupID: 642953
Reply By: nsgnomad - Wednesday, Jul 22, 2009 at 23:11
Just to throw in my 2cents worth (thats approx tuppence to all the old schoolers), it is all horses for courses.
I hired a car in UK earlier this year and the trip computer measured consumption in mpg. There, they're still measure distance in miles so it makes sense to still use mpg.
Here in Oz, we have measured distance in km for some 35 plus years and unless you are driving a vehicle made before 1970, you will be seeing km on your odometer. Therefore it makes sense to use the metric system for fuel consuption.
If you are having trouble understanding the "new" figures then by all means for yourself, convert it back to something that means something to you but please if you are trying to involve others, talk in what is understood by most - L / 100km.
Remember the lower this figure is, the less fuel you are using.
AnswerID: 375766
Follow Up By: Foxhound (WA) - Thursday, Jul 23, 2009 at 09:49
That is the whole point of the post exactly spot on. I myself have had to make the effort to change from Km/ltr to Lt/100 Km and now find it easer once you get used to it. Also having been in the Automotive trade you have to speak the correct language in this regard. Thanks for all the replies.
FollowupID: 643127
Reply By: Member - Adam S (SA) - Thursday, Jul 23, 2009 at 16:10
G'day Foxhond, I run a truck, and for me I calculate Km to the Litre.
I find it easier and more accurate, to keep track of fuel consumption.
But I also use this calculator quite a bit.
http://sikls1.v8owners.com.au/index20.html
AnswerID: 375841
Reply By: nsgnomad - Thursday, Jul 23, 2009 at 22:54
Before this thread dies a natural death or alternatively goes on ad infinitum, I would like to thank all the contributors for their entertainment, especially the one from Elmer.
I wonder if all those baby boomers like me, who can remember when they could buy a bag of lollies on the way home from school, using the change from the shilling their mum gave them for lunch money after buying a pie and a cream bun, can work out how far a mile is these days. You won't find it on signposts or maps these days. You won't measure it on your car odometer unless you drive a really old banger. You probably won't be up to walking the distance and counting your (accurately measured?) steps til you get to 1760. So what relevance is it to work out the MPG.
I wonder how many of you know that the origin of the mile was from the roman times and it it came from the mille, i.e 1000 paces of a roman soldier in a march. (did someone really count them?). Somehow or other, it was worked out that this distance was equal to 5280 times the measurement of a certain king's foot. Now that really makes sense doesn't it? Then on the other hand, the metre was originally proposed to be one 10,000,000th of the distance of the quarter circumference of the earth measured along the line of longitude passing through Paris (i.e from north pole to equator). The fact that this calculation was incorrect and later it became the distance between 2 marks on a bar of platinum held in a certain location, then even later still redefined as being a certain number of wavelengths of a particular frequency, all means about as much to all of us as does 5280 times the length of a king's foot.
In reality, both systems are metric in origin. Now if you want to have something more meaningfull, why don't we promote a new measurement of speed, that of furlongs per fortnight, first mentioned to me years ago by an ex collegue at DoT ATG S&T SA/NT (thanks John if you are out there). Now there's an idea for another thread - acronyms.
There is a little saving grace though. For those of you that still want to convert to mpg to satisfy our own unexplainable curiosity to compare it with what we used to get from our old holden/ford or whatever, the mental gymnastics that we go through will help to keep our minds active. Mind you the younger ones who don't know about miles and gallons also didn't learn how to add up and divide, but rely on calculators so their minds probably won't be as active as ours later on anyway.
For those of you who are buying your metric sheets of melamine or plywood or mdf are you buying a 2400mm x 1200mm or is it really 2440 x 1220 (the old 8ft x 4ft)?
Now I could climb onto my soapbox to mention a few other issues mentioned like spell checking, puctuation and incorrect use of there, their, and they're, or lowering of the standard of communciation by txt speak when we are all using a full keyboard, but for the moment my aging arthritic m.i.l needs the box to help her climb into the fourby. Oh I forgot, they make soapboxes out of cardboard these days. I had to make my own using (metric) pieces of 5 x 1 timber. Now there's another idea for a thread - origin of expressions.
Happy travelling to you all.
AnswerID: 375927
Reply By: Russ n Sue - Thursday, Jul 23, 2009 at 23:53
My vehicle kindly informs me of my fuel consumption, as I drive along, in L/100Km. That suits me fine. It also tells me what range I have left in the tank under any given amount of right foot and is accurate to 3%, which also suits me fine.
Because the vehicle has educted me to think in L/100Km, it now comes naturally. When I get talking to someone and they quote me the fuel consumption of their vehicle in Km/L I just shrug my shoulders and agree with them that it is good or bad or whatever they think it is, because I couldn't be bothered doing the conversion to something that makes sense to me.
All of the brochures for new vehicles use L/100Km, as do reviews in 4x4 magazines etc. Why fight it?
Russ
AnswerID: 375929
