Saturday, Jan 19, 2008 at 15:57
Pete
You have probably already found all this ... extracted from a much longer article on the Paroo.....
Downstream of
Eulo, below the
Caiwarro gauge, Carwarra Creek flows out of the Paroo during flood events to fill the
Currawinya Lakes system. Flows are generally not large enough to reach Lake Wyara, however, an exceptional flood event flushed saline water from Lake Wyara back into the Paroo. This rare event had devastating effects on fish populations and killed
the gardens of riparian landholders using the river for their domestic
water supply.
Still maintaining a south-west course, the Paroo River then passes through
Hungerford and crosses the Queensland - New South Wales border on to
the settlement of
Wanaaring. South of the town, the Paroo is joined by
Kulkyne and Cuttaburra Creeks. These streams direct flows from the
Warrego River in the east to the Paroo during flood events. At this point, after prolonged dry periods, the Paroo contracts to a series of deep, permanent
waterholes along the riverbed. These
waterholes provide important refuge areas for aquatic species during dry times. The Paroo then passes through Nocoleche
Nature Reserve and goes on to fill Waitchie, Mungundi and Camel Lakes. Waitchie Lake is virtually permanent, receiving regular inflows and retaining water for many years, Mungundi has a block bank built across the inlet to aid water retention and is also permanent. Camel Lake has no regulating structures and is ephemeral.
Below these lakes, the main channel of the Paroo River loses definition and separates into two main systems. The floodplain widens to form an extensive network of channels and wetlands known as the Paroo Overflow. A series of linked lakes and depressions filled by floodwaters continue south along the lower catchment all the way to the
Darling River. In rare flood events, waters of the Paroo fill the expanse of the Paroo Overflow and join the waters of the
Darling River upstream of
Wilcannia.
This site last updated on 05/06/2006.
The NPWS is part of the NSW Department of Environment and Conservation.
Viv
282514
Follow Up By: madfisher - Saturday, Jan 19, 2008 at 17:29
Thanks Viv,
this is exactly what I wanted to know. I knew someone on this fantastic site would know. A very detailed reply thank you
Pete
547044
