Swap and Go Gas Cylinders
Submitted: Monday, May 28, 2007 at 20:01
ThreadID: 45995 Views:6425 Replies:4 FollowUps:9
One for the more learnered in the bush :) I currenly have 4.5 and 9 kg cylinders and seems to be able to swap them anywhere. I noticed in BCF 3.3 kg cylinders. These would suit my vehicle much better BUT.
Is the swap and go gas cylinders common or only in some places IE Birdsville Marree etc etc and what is the most common size the same as I have above or is it decantered at servos? ( I assume decanting has stopped in most places)
Your help is most welcomed
Brian
Reply By: Member - Roachie (SA) - Monday, May 28, 2007 at 21:09
I think you'll find that decanting is still very much the preferred option in the more remote places. I find that my 9kg and 4.5kg (1 of each) is more than enough to last me for the small amount of use I require from them during even a lengthy trip. As such, I have never had to fill up anywhere away from home.
I recently bought a short hose with the fittings necessary to enable me to decant my own gas from a 45kg cylinder, so will never have to leave home with anything less than a full cylinder/s in future.
AnswerID: 243005
Follow Up By: Stu050 - Monday, May 28, 2007 at 21:19
Do you have the proper (blue top) cylinder, or just turn it upside down like everybody else?
FollowupID: 504019
Follow Up By: Member - Roachie (SA) - Monday, May 28, 2007 at 21:22
I only got the hose a couple of months ago and so far have just up-ended the ordinary 45kg cylinder that I already had here at home which I use for the BBQ. However, I asked at my local supplier (Mobil garage) a few weeks ago about the possibility of getting a blue-top next time and the bloke said "no worries". So that's what I'll be doing from now on.
FollowupID: 504022
Follow Up By: SARocks - Tuesday, May 29, 2007 at 08:25
Fill up the car with LPG come home and fill the 9kg from the car for $10 and the 45kg for $50. If get the 45kg filled by gas mob costs $97.
Had to pay to get the 45kg retested and stamped and new valve fitted with bleed screw for $60
FollowupID: 504092
Follow Up By: Andrew from Vivid Adventures - Tuesday, May 29, 2007 at 13:33
interesting - is there anything required and/or is it possible to fill a 9kg bottle directly from the LPG bowser?
FollowupID: 504139
Follow Up By: SARocks - Tuesday, May 29, 2007 at 21:49
only thing required on the car is a T with a tap and a high pressure gas hose with a POL fitting on the end.
cannot fill a 9kg bottle directly from the bowser. If you could everybody would be doing it for $10 instead of getting ripped for $25
FollowupID: 504275
Reply By: Member - Brian H (QLD) - Monday, May 28, 2007 at 21:32
Thanks for that :)
Brian
AnswerID: 243011
Reply By: Gronk - Tuesday, May 29, 2007 at 09:36
Once you have a swap & go, you don't need to swap & go again ( too dear ) until it gets nearly out of date !!
AnswerID: 243106
Follow Up By: Member - Duncs - Tuesday, May 29, 2007 at 09:58
That's what I do.
When one of my cylinders is close to retirement date I swap n go.
I will never test or buy another cylinder again.
Duncs
FollowupID: 504108
Reply By: Gob & Denny - Tuesday, May 29, 2007 at 17:18
true or false ???? you shouldnt fill with car gas because it is a different mix to normal bottled gas ?????
steve
AnswerID: 243238
Follow Up By: Axel [ the real one ] - Tuesday, May 29, 2007 at 17:37
false ? was a thread way way back ,1 or 2 yrs ago that had lots of info re gas bottle refilling from servo outlets , people have to do it sneakily to fill the bbq bottle from the bowser as the connections ar generally not available , just like the b/s about refilling the "Coleman " disposeable bottles , You can get from the USA a Maccoupler that lets u refill from a 9kg bottle , works out at 1 tenth of the price of a disposable.
FollowupID: 504183
Follow Up By: Scrubcat - Tuesday, May 29, 2007 at 20:11
True, vehicle gas from the servo pump is mainly Butane with some Propane mixed.
I think you may find that the makers of most appliances i.e. gas fridges, cookers , h/water heaters, etc... say to use propane only.
The guy at the bottle test and fill depot, that by the way charges by weight, where I get bottles filled, also says that only propane should be used in camping appliances.
Propane burns hotter than Butane anyway, so it may be cheaper to buy Butane from a servo , but is it as efficient in the long run ?.
Just my 23 cents worth,
Scrubcat.
FollowupID: 504234
Follow Up By: G.T. - Friday, Jun 01, 2007 at 16:53
TRUE!!!!!! Sorry to shout but there are notices on gas pumps in Qld saying that it is dangerous and illegal to use car gas in cooking appliances. Heavy fines apply.
Regards G.T.
FollowupID: 504920
