Friday, May 19, 2017 at 14:15
Like Stephen, I'm a big advocate for taking boxed water over 20L containers.
Buy the 10L boxed water from large supermarkets, like Coles or Woolies, $3.85 I think the going price is at the moment. For less than $25, that gives 60L of good potable water.
As they are used, the cardboard boxes can be burned. The bladders can be saved, and can be re-used. They can be stowed full of water even if the box is long gone, they are quite hardy. (Try jumping on an inflated 10L bladder, I bet London to a brick you'll be off to ER with a busted ankle).
As also stated above, 10L containers of boxed water can easier be distributed down low, and from side to side as required to keep the vehicle 'in trim'.
There is a lot of inbuilt redundancy in 6 x 10L boxes of water, than one or two 20L containers.
I've not traveled with water containers for quite some time, boxed water at the cheap price it is available at, you just can't go past it.
881249
