Yalata SA
Submitted: Saturday, Jun 06, 2015 at 17:51
ThreadID: 119102 Views:3131 Replies:8 FollowUps:8
Can anyone advise if the Roadhouse at Yalata is operating (I'm thinking fuel here)
Reply By: Pimbi - Saturday, Jun 06, 2015 at 18:23
No ,it,s not open.
AnswerID: 554648
Follow Up By: Kazza055 - Saturday, Jun 06, 2015 at 18:39
I think it closed about 10 years ago.
FollowupID: 840765
Follow Up By: Motherhen - Saturday, Jun 06, 2015 at 23:10
Yes, 2006 I recall.
FollowupID: 840770
Reply By: Gone Bush (WA) - Saturday, Jun 06, 2015 at 18:53
With 180 litres in your Troopy you should be able to sail past it with heaps to spare.
AnswerID: 554651
Follow Up By: Member - Bigred13 - Saturday, Jun 06, 2015 at 20:07
Fill up at Penong cheapest fuel you will find over that way
FollowupID: 840769
Follow Up By: Nomadic Navara - Sunday, Jun 07, 2015 at 17:07
Not only is it the cheapest, You can get a list o the prices across the way.
FollowupID: 840784
Follow Up By: Member - Trouper (NSW) - Monday, Jun 08, 2015 at 13:36
Your right, just curious Thanks
FollowupID: 840808
Reply By: Gone Bush (WA) - Saturday, Jun 06, 2015 at 21:01
Trouper, I assume you will be heading west.
Fill up at Ceduna, and Border village is only 490 kms away. I can do it in my 200 Series (138 litres) towing a 3500kg van.
You should piss it in with 180 litres, towing or not.
AnswerID: 554652
Reply By: GG7777 - Saturday, Jun 06, 2015 at 21:36
Just returned across Nullabor and my advice - fill at Ceduna (Penong if don't have range) and then at Eucla (It was $0.20/litre cheaper than Border Village) prices then keep rising til Cocklebiddy. Can't help after that as only as far as Eyre Bird Observatory and return
Murray
AnswerID: 554653
Reply By: Motherhen - Saturday, Jun 06, 2015 at 23:15
As advised Trouper, plenty of fuel outlets along the Eyre Highway. The longest distance between fuel stations is Balladonia to Norseman - 192 kilometres.
We don't run too close to empty chasing cheaper fuel after reaching Mundralbilla once and finding their fuel truck two days overdue.
AnswerID: 554655
Reply By: Gone Bush (WA) - Sunday, Jun 07, 2015 at 01:00
Do a little research before you go.
I refuel exclusively at BP servos because I think I can trust their diesel. Last time I stopped at Mundrabilla, and this might have changed by now, they were using SAFF (South Australian Farmers Federation) diesel that has a high bio content. Modern common rail diesels don't like it, and Toyota won't honour their warranty if more than 5% bio-diesel goes into the tank.
So, Ceduna BP, Border Village BP, and a couple more (Cocklebiddy?) before Norseman BP are my preferences. Not the cheapest, that's for sure, but neither is a rebuild.
AnswerID: 554656
Follow Up By: Member - Phil G (SA) - Sunday, Jun 07, 2015 at 23:29
Stephen, No need to worry about SAFF - taken over by Mogas in 2009.
http://www.adelaidenow.com.au/business/mogas-buys-sa-farmers-fuel/story-e6fredj3-1225701631610
FollowupID: 840793
Reply By: Crusier 91 - Sunday, Jun 07, 2015 at 07:58
You can re-fill at the Nullarbor Roadhouse
https://www.google.com.au/maps/dir/Yalata,+South+Australia/Nullarbor+Hotel+Motel,+Eyre+Hwy,+Ceduna+SA+5690,+Australia/@-31.4285755,131.0648666,8z/data=!4m13!4m12!1m5!1m1!1s0x2ac6eeced19b61ad:0x4033654628ef270!2m2!1d131.8241905!2d-31.5009472!1m5!1m1!1s0x2ab6921f3aae1715:0x706f35af9994baf4!2m2!1d130.896161!2d-31.44971
AnswerID: 554657
Follow Up By: Crusier 91 - Sunday, Jun 07, 2015 at 08:01
Copy and paste the whole lot.
It will give you all the way points on google maps
FollowupID: 840771
Follow Up By: Nomadic Navara - Sunday, Jun 07, 2015 at 17:04
It would be better for you to use the "Insert Link" function. It works correctly every time and does not produce those crappy links.
FollowupID: 840783
Reply By: peterdre - Sunday, Jun 07, 2015 at 08:24
Nullarbor fuel
The following fuel prices were noted across the Nullarbor early May 2015
Ceduna (Shell), diesel $1.359
Penong, diesel $1.349
Nundroo, diesel $1.419
Nullarbor, diesel $1.789
Border Village, diesel $1.770
Eucla, diesel $1.720
Mundrabilla, diesel $1.780
Madura, diesel $1.760
Cocklebiddy, diesel $1.80
Caiguna, diesel $1.770
Balladonia, diesel $1.750
Norseman (Caltex), diesel $1.349
BP, on the Eyre Hwy corner $1.80 diesel
AnswerID: 554658
