Sunday, Dec 30, 2012 at 00:38
Thanks for the info - am looking for a single span, open plan building design to use as a basis for a house design.
Thick walls, curved roof and something a little different from the average 5br brick/tile box found all over the place.
While looking for "curved roof" on Google, a picture of this amazing building appeared.
As much as I would love to visit, to drag the 100 series and 4 daughters there with a tape measure and a sketch book may
well get me hung by the Minister for Treasure and Pleasure!
I was able to get a ball park size by counting iron sheets on the roof, and using the current width for corrugated iron (762mm, overlap 1.5 ripples), ended up with about 60m x 14m External - but nothing beats visiting I guess!
There was also a couple of humans in some photos, which let me get a door height of about 2.4m, meaning the walls are about 9ft high......and apparently 3ft thick!
Thanks to you all for the replies - first time
forum attempt - will get the hang of it eventually.
501239
Follow Up By: Lyn W3 - Sunday, Dec 30, 2012 at 06:48
You may get some help from a greenhouse designer/manufacturer as to the loads and stresses of unsupported spans. Maybe even try one in the USA or europe where they have to consider winter snow loads.
777323
Follow Up By: Rockape - Sunday, Dec 30, 2012 at 07:24
Humpty,
have a look at w.w.2 aircraft hangers. They also were very strong and the plans should be available.
There is a semi that backs up to the building and rolls the roofing sheets in one piece.
RA.
777325
