New Bt-50 Electrical
Submitted: Wednesday, May 09, 2012 at 20:05
ThreadID: 95461 Views:18029 Replies:9 FollowUps:27
I thought I would just make a comment here after reading an archived thread on this forum titled (new BT50 / Ford Ranger electrical issues)
I purchased my BT-50 XTR Duel cab in November with dealer fitted steel bull bar, canopy, spotlights, electric brakes & trailer wiring plug.
I myself fitted a UHF which I took the power from the fridge wire that runs up the back to the caravan.
My first issue was the bull bar mounts were faulty. I was told it wont fall off but it still has movement of 20mm at the top. Still waiting for new mounts to come.
I have towed the caravan numerous times with no problems at all. I was out bush getting a trailer load of firewood recently only to find I couldn't start my car. To cut a long story short- it has now been 1 month, sitting in the back yard of Ballarat City Mazda, whilst waiting for a new body control module which are non existent in Australia, Japan or Thailand.
Of course- Mazda Care Australia have graced me with a hire car (commodore) but, to date there is no word on when my part will be available.
My Mazda Care case manager has conferred with the dealer service manager and they 'think' it could be the incorrect wiring regarding the brake controller.
I was just about to run a hot wire to the rear of the tub for my fridge. And an Anderson plug for the van. I think now I will pay to have it done to prevent any damage.
There is no further word on the computer and it could quite easily turn into months before it's fixed.
The main reason I bought the new car when I did was because we were going to embark on a 5 week journey to Darwin in June this year. That wont be happening now. Even if the BT-50 is fixed- how could I trust it.
I just thought I would post this comment here to make you aware of the trouble getting spare parts for this model. (BTW) the airbag compatible seat covers I ordered from delivery are still non existent.
Look forward to hearing any comments- Cheers
Reply By: Phillipn - Wednesday, May 09, 2012 at 20:43
I purchased a dual cab XTR and had an auto electrician install the electric brake unit, dual battery unit and a wire from the ignition to a relay in the van, to switch the three way fridge off [12v] when the motor is turned off.
We have had one trip away with this set-up. Working OK.
The trailer wiring was installed by Mazda.
AnswerID: 485392
Follow Up By: skeeterau - Wednesday, May 09, 2012 at 20:51
My case manager has even suggested to me that a recall may take effect for all electric brake fits as there is a new wiring diagram from Japan just come in. Please check with your dealer and if he doesn't know, get him to find out.
Cheers.
FollowupID: 760637
Follow Up By: skeeterau - Thursday, May 10, 2012 at 14:59
Phillip, do you wipers wipe the screen once or twice every time you start the car? That is a annoying thing for me and no one, not even from Mazda can tell me if this is normal.
FollowupID: 760711
Follow Up By: Phillipn - Thursday, May 10, 2012 at 16:44
skeeterau
No they don`t.
The thing that I don`t like is the parking lights are turned on when a door is opened. If the door is not closed [ on first catch] It could flatten the battery.
I know that they can be turned off by flicking the light dipper twice, but children would no know.
Mazda dealer told me that the pilot light on the brake controller would flatten battery if the vehicle was left standing for a few days. It would not be as bad as the parkers accidentally left on. [Yes, the doors have to be closed to operate the lock.]
A good vehicle containing too many useless gadgets.
FollowupID: 760723
Follow Up By: skeeterau - Thursday, May 10, 2012 at 17:11
That's interesting about the wipers. I always thought that was a fault. Don't worry about your lights staying on. I leave all my doors open to clean and vacuum and the go off themselves. I have tried to time it numerous times but they won't go off if your watching them.....
FollowupID: 760729
Follow Up By: Nomadic Navara - Friday, May 11, 2012 at 12:15
Quote "Mazda dealer told me that the pilot light on the brake controller would flatten battery if the vehicle was left standing for a few days. It would not be as bad as the parkers accidentally left on"
Do you have a Tehonsha produced unit (P3 etc?) If so, he does not know what he is talking about. They go to sleep after 10 minutes of inactivity and draw less phantom current than your car radio does.
FollowupID: 760795
Follow Up By: Phillipn - Friday, May 11, 2012 at 13:11
Peter,I have a Tehonsha brake controler. I`ll save that for the Dealer when I am talking to him.
FollowupID: 760801
Reply By: gary53 - Wednesday, May 09, 2012 at 21:09
Hi Skeeterau, I've had my BT-50 for 2 months now, I've wired in the Tekonsha controller, dual battery isolator with a feed to an Anderson plug in the tub and one to an Anderson plug on the tow bar plus UHF. So far everything is working OK and I think that's because I read much of the Ford forum about the Ranger and all of the electrical advice on there. Basic rule is- stay out of the Canbus loom- if you do this, all should be OK. Check that you have'nt used the trigger wire for your brake controller coming off the brake switch under the dash, I picked up the power from the 12 pin plug using the wire for the 'van brakes. Hope this helps, Gary
AnswerID: 485398
Follow Up By: skeeterau - Wednesday, May 09, 2012 at 21:26
Thanks Gary, but mine was commisioned by Mazda before delivery. Take a look at the last paragraph on this bulletin-
hope this link works
Just days before the body control mod packed it in- the car was at Mazda having a temp fix for the bull bar. The very next day the 2 dealer fitted spot lights didn't work. I followed the wires and they were all good. It was both globes blown.
From memory now, there is a wire that dissapears in the firewall (high beam pickup via switch) and the main power came from the battery with an inline fuse. I dont think these cars accept that.
FollowupID: 760647
Reply By: Rockape - Wednesday, May 09, 2012 at 21:22
If you get it fixed in time don't even consider not going because it might not be reliable.
Yes it takes some time to get parts that don't fail much but such is life with modern vehicles and suppliers.
We have just gone through a similar thing with an I30 Hyundai. An electrical component was installed by others and next thing vehicle won't start and had to be placed on a tilt tray and sent to Hyundai. After much it is your fault and no it is your fault we finally got our vehicle back 5 weeks later with a new ECM. Vehicle only had under 200k on it.
Parts had to come out of Korea and through their parts system.
Don't let this little hiccup spoil your trip.
Such is the way of modern machines.
RA.
AnswerID: 485401
Follow Up By: skeeterau - Wednesday, May 09, 2012 at 21:29
I know you are right. I am just fully stressed out and I appreciate all the comments on here. I have learnt alot tonight and I am confident that the problem lies in the current wiring and it can be fixed.
FollowupID: 760649
Reply By: Bazooka - Wednesday, May 09, 2012 at 21:35
You might want to read THIS
AnswerID: 485405
Reply By: The Bantam - Thursday, May 10, 2012 at 10:21
Remember, lots of " dealer instaled" accesories are nothing of the sort, depending on the dealer in question and the item, it may very commonly be installed by a third party who may be little more than a ham fisted school leaver.
Guess what I did as a spotty teenager and before I trained as a tradesman?????
AnswerID: 485438
Follow Up By: skeeterau - Thursday, May 10, 2012 at 14:54
The work was done by an outside auto electrician.
FollowupID: 760710
Follow Up By: olcoolone - Thursday, May 10, 2012 at 16:13
All "dealer fitted" mean is it has been fitted through a dealer much the same as "factory fitted" meaning it has be fitted through the factory prior to delivery to the dealer.
Who ever fitted it for the dealer or factory is authorised to do so and most times they will outsource the work to a specialised fitter.
FollowupID: 760720
Reply By: Ron N - Thursday, May 10, 2012 at 11:40
I can't help but agree with the Bantam. Brother was having a new in-car phone kit fitted to his new 'Cruiser back in the early 90's. He was particular about location, wiring, where holes were going to be drilled (to minimise damage and for minimal effect on appearance).
Unimpressed after talking to ham-fisted installer - who seemed to specialise in draping wires like spaghetti through trees, and drilling holes everywhere it suited him - brother just happened to ask what his background skills were.
"Oh, I used to be a fencer on stations, mate!" installer cheerfully tells him.
Brother told me he thought that's where his skills originated from, going on his ham-fisted style. He never did get another phone installation performed by that crowd.
Skeeterau - Re the BT-50 - I would be absolutely appalled and screaming like a banshee to senior Mazda Australia management, over this dreadful performance, of what is supposed to be a new vehicle - that is supposed to perform faultlessly, like a new vehicle should.
You have every right to dump this vehicle, and demand full restitution. If it was I, I would be talking lawyers, and playing hard ball.
The trouble is, we are all usually too soft, and prepared to let companies walk all over us - as they will do, at every opportunity.
When you make it abundantly clear that you are full of sharp spines, they will be far less inclined to walk over you. You have every legal right to demand full restitution or a new replacement vehicle, as you purchased a product to do a job, and perform to a requirement - and it has failed to deliver on those points.
The key point here is "dealer fitted accessories". As those accessories were dealer fitted, they should have been dealer approved and the installation QC'ed by the dealer.
They make enough profit on accessories to retire on every year, so they can't argue they didn't have any margin on the products to play with. Dealers make more from margins on accessories than they often do on the vehicle itself.
There are many lawsuits on record that set this right to expect a "level of performance" of a new product, in stone.
I can recall a contractor buying two new Caterpillar bulldozers from the W.A. Caterpillar agent in the 1960's. They were products of the new British Caterpillar factory - and they were dogs. They had manufacturing flaws galore. They broke down constantly.
The contractor dumped the tractors back in the dealers yard, and took the dealer to court - on the basis of they bought bulldozers to bulldoze, and they wouldn't bulldoze.
The contractor won, and the Caterpillar agent had to refund all the money the contractor paid for the tractors.
You have every right to take Mazda to court on the basis that you purchased a new vehicle so that you could expect new vehicle performance - but you have ended up with a vehicle that doesn't perform - or in reality, that performs like a $1000 wreck salvaged from a scrap yard.
I would be one very angry person, if I was in your shoes, and Mazda management would be fearful of sighting me.
Unfortunately, you don't usually get any results until you start raising Cain in managers offices, and turning into "the buyer from Hell."
I've had to do it, and I can tell you, it works.
Cheers - Ron.
AnswerID: 485441
Follow Up By: Ross M - Thursday, May 10, 2012 at 19:00
Well said Ron I agree, you mentioned accessories being a profit maker for the stealership/dealership, most people don't realize that the Mazda dealer who charged $50,000 for a BT50 paid Mazda Australia less than half of thta figure to have it in the yard for the customer to buy.
My daughter inlaw worked at a Mazda dealer and said the dealer paperwork showed he paid $10,800 for a new car from Mazda and then sold it for $22,000. A good mark up too.
Ross M
FollowupID: 760738
Follow Up By: Shaker - Thursday, May 10, 2012 at 20:50
There is nowhere near that sort of margin in new vehicles!
FollowupID: 760748
Follow Up By: AlbyNSW - Thursday, May 10, 2012 at 21:07
I know a fellow who owned a Toyota dealership in Sydney, sold out about 8 years ago and he certainly wasn't spruking about big margins to be made which is why he got out of the industry.
Overheads to run a car yard would be substantial
FollowupID: 760752
Follow Up By: Ron N - Thursday, May 10, 2012 at 22:19
Ross - I'm not sure how good those figures are, because I have some knowledge of car dealership markups, and between 15% and 20% on the wholesale purchase cost, is generally a good markup figure for the average dealer.
They don't make a fortune out of new cars, they make the real money out of parts and accessories, and the workshop.
Cheers - Ron.
FollowupID: 760764
Follow Up By: Ross M - Friday, May 11, 2012 at 15:18
G'day Ron
There was a bloke on the forums from Townsville and he bought a new Colorado from a dealer and had some warranty issues.
He sighted the paper work, relating to his vehicle, mistakenly left on a table at the dealers and it showed he had just paid slightly more than double the price paid by the dealer who sold it to him.
But, yes, there are overheads at a dealers though, but they do have room to Mooooove as the saying goes.
FollowupID: 760807
Follow Up By: Shaker - Friday, May 11, 2012 at 18:23
After nearly 18 years in automotive retail, I can quite categorically assure you the that is absolute garbage!
FollowupID: 760820
Reply By: Ross M - Thursday, May 10, 2012 at 12:46
G'day skeeterau
It is interesting you have problems with the bull bar.
It seems from comments on other forums that the Mazda dealers fitting staff can't tell when a bolt is tightened properly or it is bottoming on a bolt shank which has too long a shank.Yes the nut tightens but the bolt isn't tight and clamping the parts involved.
This has caused one BT50 owner to have the bar nearly fall off his vehicle and pieces of chassis broken out of the sides of the chassis. Bar damaged the body work as it flung around.
Because your brake unit was fitted by Mazda and they regard the wiring as being the cause of the fault you should be driving around in a BT50 not a crummydoor.
If the Mazda fitted wiring IS the cause then it goes to show the fitting is similar in expertise to the fitting of the Bull Bar.
If the brake controller wiring was incorrect in connection, it wouldn't take a while for the fault to appear, it would be instant and not start at the dealers after the fitting.
If the fiitting quality was poor and a fault developed afterwards then it points to dodgy fitting and wiring ability.
Have a look at your vehicle and see if they have used Scothlocks anywhere, if so they are the cause of many faults.
Welcome to the world of dealer expertise.
Ross M
AnswerID: 485442
Follow Up By: Phillipn - Thursday, May 10, 2012 at 17:00
Talking of bolts no tightened, Two bolts on the tow bar [ fitted by the Mazda dealer] were only started finger tight [a couple of turns]. I found them after I had towed the van about 50 Ks.
I phoned the sales man, who sold me the vehicle to raise the alarm. I haven`t been back to see them. I tightened them myself.
FollowupID: 760725
Follow Up By: skeeterau - Thursday, May 10, 2012 at 19:41
Its an interesting one this one. I have been towing the caravan, done about 1000klms no problems. Nothing new electrical added. The only notable thing prior to the break down was the bull bar patchup the week before when the spotlights didnt work.
Update today via phone. They have sourced a control module and Mazda Ballarat will have it by the end of the month. It must be coming out by row boat............. I am afraid they will fit the module, alter all the wiring to suit Mazda Corporation Japan's specs- tell me its fixed and not really know what caused the problem.
FollowupID: 760741
Follow Up By: Ross M - Friday, May 11, 2012 at 15:29
At least one of every conceivable/likely to fail part, should be in Australia before any of those vehicles are sold in Australia. The stock should also be kept up.
The issue of non available means they haven't allowed for ANY failures of anything.
An appalling attitude from a company who just wants your money and only will attempt to get pars when forced to do so.
The spare parts organization should be in place before the sales launch.
FollowupID: 760808
Reply By: olcoolone - Thursday, May 10, 2012 at 16:52
It's good to see so many can point the finger with little detail, talk about taking legal action against Mazda, right down to the so called unqualified installers fault and bad QUALITY CONTROL.
What you guys have to understand is most fixes are not fixed overnight especially if it's new problem unseen before.
The is a set procedure for lodging a claim and it might be something like this.....
1) The dealer has to establish if it's a manufactures fault, a third party fault or owner fault.
2) If it's a manufactures fault he dealer has to notify the manufacturer.
3) The manufacture has to establish the servility of the claim.
4) The manufacture has to establish what caused the fault.
5) The manufacture has to apply a rectification or fix for the fault.
6) The manufacture has to test to see if the fix or rectification will work.
7 The manufacture has to approve the fix or rectification for the fault.
8) The manufacture has to instigate a fix or rectification for the fault.
9) The manufacture then has to authorise the dealer of the fix or rectification.
10) The dealer has to carry out the fix or rectification.
11) The dealer has to document the fix or rectification back to the manufacture for final approval.
10) When final approval from the manufacture is authorised then the customer gets their car back.
For a simple fault that most unknown people may think is a simple fix and should only take 1 day to rectify can turn into weeks or months to fix and rectify using 20+ people and engineers (I don't class engineers as people... or human).
We are a Denso Service Centre and we have had stuff fail under warranty.... the effort and detail they (DENSO) go to is unbelievable including going back the the original component manufacture obtaining data on materials used for a specific item for that batch.
We get called in by Denso to oversee fixes and rectifications at Toyota dealerships for unknown faults.
Most manufactures take failures very very seriously and spend a great deal of time and resources investigating the cause and a fix or rectification.
We had a very slight noise in the dash of or 200 series that would only last 5 seconds every now and again when travelling between 65 and 75 Kph when slowing down..... the Toyota dealer had the car for over a week and found it in the steering column...... they can up with a fix through Toyota that took 2 days to do.... we picked up our 200 series and no noise..... 2 weeks later we got a phone call from our Toyota dealer informing use Toyota wasn't happy with the fix and wanted to do it another way.... we dropped the 200 series off for another 2 days for the fix.... all sweet.
AnswerID: 485459
Follow Up By: AlbyNSW - Thursday, May 10, 2012 at 20:32
Olcoolone you bet me to it with your reply.
Nobody wants to have problems, consumers or merchants and to be jumping up and down wanting a new one every time there is an issue is not reasonable or realistic, where do you draw the line of when a new vehicle should be offered.??? Leaking tyre valve, air cond compressor etc. .??
The merchant needs to be given the oportunity to rectify the problem and if the parts are not available surely you cannot be too hard on the Dealer who is only a reseller not a manufacturer of a product.
Having said that I would be expecting the dealer to provide you a suitable alternate loan vehicle and a few other goodies as a goodwill gesture whilst getting the issue resolved.
This calling the Lawyers in capper mentality every time there is spilt milk is part of the problem with our current society.
Things go wrong sometimes that is life. I hope they get it sorted out for you with as little grief as possible.
FollowupID: 760746
Follow Up By: Ron N - Thursday, May 10, 2012 at 22:16
Alby - And it's people with your attitude that manufacturers love. They can walk all over you, they can use YOU as the test bed for poorly built, and inadequately tested products - and all the time the smooth ads are blaring away on TV - telling all and sundry what a superior product they are selling - and you're guaranteed to look like Tom Cruise whilst driving it, and you can expect the same adulation.
Meantimes, Skeeterau's experience is that he's walking when he should be travelling - he's paid $50K and get to drive around in a used Commonwhore - while he waits months for a major parts that is made of unobtainium - and which should have been ripped off a new vehicle at the very least, to get him going again.
He's had his major holiday plans destroyed because the company doesn't really care too much - about its products, and about its service and customer care levels.
I'll wager if the CEO of Mazda Australia had HIS BT-50 cease operating, it would be worked on around the clock, and parts air-freighted from the factory to get it running again.
This kind of BS treatment is exactly why America has Lemon Laws. The Yanks won't put up with being fobbed off with poor quality or faulty products. They go for the jugular, and rightly so.
FollowupID: 760763
Follow Up By: AlbyNSW - Thursday, May 10, 2012 at 22:44
Ron I can assure you that I do not get walked over by anyone. What I am saying is that you have to be realistic and reasonable.
Skeeteraus said that the dealer has had the vehicle for 1 month and awaiting a part to rectify the situation, they have provided him with an alternate vehicle in the interim and it is Skeeteraus saying that even if he gets the vehicle back in time, will not go on his trip as he has lost confidence in the vehicle.
If the type of loan vehicle is not appropriate I think he is well within his rights to request another more suitable one, likewise they should provide a vehicle for his holiday if they still have not fixed the problem.
He may well be happy with the Commodore in the interim but if not by all means communicate with the dealer so that you are happy as could be under the circumstances. I didn't read in his post that the dealer is refusing to sort out the problem or that he would only provide a commodore that was not satisfactory to him!
You are assuming the dealer does not care and is destroying his holiday, maybe the dealer is not even aware of his upcoming holiday??
By all means get the dealer to sort out the problem and provide a vehicle to allow him to still have his trip but my point is I don't think being trigger happy with Lawyers is a necessary action when the dealer is on the case.
FollowupID: 760768
Follow Up By: skeeterau - Friday, May 11, 2012 at 18:47
Mazda Australia have bent over backwards to help me with everything in their power. I am still just a number, customer in the queue- awaiting my turn.
They were aware of all my circumstances and requirements and the first question asked when I was offered a rental- Do I require a utility for work purposes. I said no because I expected to receive a 1 ton tray type ute and I needed the seats.
When I informed them of my holiday they looked for a suitable rental vehicle to tow the caravan. It turns out that you can't easily obtain a rental tow tub (which is what I expected) from the major rental firms. They don't have vehicles set-up for towing with electric brakes and the like.
Even if they did, I wouldn't have taken the trip in one because- My holiday- would be in my rig. I would want to use my freezer in the back, use the extra 90lt fuel auxiliary fuel tank and carry all my gear that has a place of it's own in the tub of my ute. The holiday is in driving and enjoying your own set-up. I would have rather flown domestic than drive a hire car.
I have just been the unfortunate victim of circumstance. I purchased a new vehicle for reliability, to have a holiday without the fear of car problems. In hindsight, I should have kept my 2004 diesel pajero, that just clicked over 270k and has only cost me 4 sets of tyres & 7 sets of rego.
The commodore suits my needs to drive to work and back, (its more expensive to run than the BT-50) Its a SV6 with skirts and spoilers but drives like a bucket.
I am now just concentrating of getting my vehicle back- gaining trust in reliability and looking forward to having it back in my care.
I hope I didn't give the impression that Mazda Australia just dumped me, as this is not the case. I really feel sorry for my case manager who has to be the one to talk with me on the phone to tell me there is no further news. I would not want to ring someone like me. I for one, would not want his job.
The local Mazda dealer who sold me the car and fitted my accessories..... now that's another matter.
The feeling I get when I talk to them- They are doing me a favor, and its a pain in the butt having my car sitting in their compound.
When I spoke to them about minor electrical work to be done (Anderson plug and fridge power in the back), and I am nervous now about doing this myself like I planned- they said no you need to be careful when doing a job like this. You will need to take it to an auto electrician. That is ludicrous not being able to do minor work yourself like this. Even if I had the confidence I wouldn't now because it would make me responsible for computer failure.
I did make enquiries last week to my lawyer regarding my case. His thoughts were that Mazda Australia are doing their best to rectify the situation. I can only follow through the system and keep receipts for any undue costs that can be recovered. One thing he mentioned that I try to keep a paper/email trail. Phone conversation promises mean nothing.
FollowupID: 760825
Follow Up By: olcoolone - Saturday, May 12, 2012 at 11:18
AlbyNSW.... We get people at work acting the same and this is on their first contact with us....... we get great enjoyment from their bad attitude when we say "sure we will fix it"..... all of a sudden your thier best friend and you have them eating out of your hand....... but we also have a few who we have KICKED out our workshop.
99.9% of customers are fantastic but it's the .1%ers who leave you with fond memories.
skeeterau, it's funny how some (customers) deal with issues with a heavy hand and others like you are level headed..... good to see.
People with a level head usually gets better results.
As AlbyNSW said.... nobody want a vehicle sitting around broken, the customer, the dealer or manufacturer.
I feel sorry for you, sit tight and it will be all OK.
FollowupID: 760866
Follow Up By: AlbyNSW - Saturday, May 12, 2012 at 11:47
Olcoolone , I am in the building industry and our experience is similar to yours. I have spoken with a couple of Fair Trading officers who deal with disputes and they tell you that consumers and their unrealistic expectations is as much of an issue to deal with as merchants with faulty product.
Skeeterau, hopefully you get sorted out soon and that you are satisfactorily compensated for your expenses.
I know what you mean about it not being the same in someone else's vehicle, I often think how much money and time I would save flying to a destination like the Kimberly and hiring a 4 WD but it is just not the same sense of satisfaction.
Good luck and hope you are back on he road soon.
FollowupID: 760869
Follow Up By: Ron N - Saturday, May 12, 2012 at 12:05
I think olcoolone has a vested interest here in keeping dissatisfied customers at bay.
Let's just run through the scenario again. Skeeterau has forked out probably in excess of $50,000 last NOVEMBER, to acquire a NEW vehicle, with a SUBSTANTIAL reliability increase, over an old worn-out one.
In the first 5 months of ownership, he has been overwhelmed by a raft of faults that have finally led to this NEW vehicle being taken from his use and possession, in an unuseable state - and this has been going on for in excess of a MONTH.
He's been informed that NO-ONE in the company has any idea of when a crucial component that is required to get his NEW vehicle running again, will be available.
I quote - "There is no further word on the computer and it could quite easily turn into months before it's fixed".
This is not a leaking tyre or an A/C fault - it is a case where a man has forked out a SUBSTANTIAL sum of money, for a new vehicle - only to see that vehicle perform, firstly, with a level of reliability that approaches a 500,000km vehicle - and secondly, it has been removed from his possession (and meantimes he's still paying the monthly payments - but doesn't have his vehicle - and thirdly - NO-ONE CAN TELL HIM WHEN HIS NEW $50,000 VEHICLE, WILL BE BACK ON THE ROAD!!!
This rates as the most appalling performance of a new item of equipment that I have heard about, in the last couple of years. As a businessman who has purchased and owned probably well over 2000 items of equipment and vehicles over 45 years of being in business - I can tell you, if this vehicle was mine, I would be savaging every senior employee of Mazda and going right to the top, to get some serious action - instead of INACTION.
In my case, on many occasions, I purchased new Caterpillar machines that in todays values ran into several hundred thousand dollar value purchases.
In a few cases, those machines performed badly. In every case, I was initially fobbed off by the dealer.
It was only after some hell-raising amongst senior management, that they usually belatedly admitted they had a problem. In several cases, components were pulled from new machines in stock to get mine going again immediately.
In one case, valves failed on a near-new Cat engine. A head fell off a valve. I paid for an engine overhaul, and the Cat dealer told me the problem was my operators methods, causing the failure. A week after the overhaul, another head fell off another valve, causing engine destruction.
After I made a trip to the senior managers office, raising cain about the problem, the senior management of the Cat dealer then admitted that, yes, there was a manufacturer problem. They had had a "crook batch of valves".
Lo and behold, a complete and full replacement of all engine valves was then supplied, gratis. However, if the dealer had admitted the problem in the first instance - they would not have been up for the (unnecessary) cost of a engine rebuild - and I would not have had a machine seriously broken down, and out of commission, twice in the one month.
If there's one thing I've found after 45 yrs in business, after buying lot of machines and vehicles - it's that a dealer will only admit to a major problem, and do something about it quickly - when they are harrassed beyond any normal level of griping.
In Skeeterau's case, this vehicle should have been at least provided with a new computer taken from another vehicle - immediately - so he could enjoy the new vehicle he's paid substantial sums of money for - and if the problems continue, Mazda should take the vehicle back, and provide a replacement or a refund.
FollowupID: 760872
Reply By: Member - bbuzz (NSW) - Thursday, May 10, 2012 at 21:57
A bit OT but what do you do when the dealer or manufacturer will not talk to you about a problem?
You can write letters to have a record of the efforts you went to but if they won't discuss or blow you off with "the warranty is not transferable" and similar, you have to go the Fair Trading or ACCC. I warned a mob that was what I was thinking and they said, "Go ahead".
Bill
Bill B
AnswerID: 485487
Follow Up By: Ron N - Thursday, May 10, 2012 at 22:32
Bill - It's called a lawyers letter - preferably written by a Rottweiler-type lawyer. Once they know you're serious, and are making it obvious you will not stand for their BS, and are happy to have your lawyer commence legal action, they might start getting talkative. Let's put it this way - refusing to talk about a problem indicates;
A: they have something to hide ..
B. they have little to no communication skills.
Either way, you have nothing to lose. People who run a business, dealing with the public have to have communication skills that are substantial enough to be bale to sit down, discuss, and thrash out problems.
The trouble is, that too many people running businesses have inadequate communication skills, and just hope that if they ignore the problems, they'll go away.
It doesn't work like that, and an unhappy client with a genuine grievance is the worst kind of (negative) advertising a business can get.
Of course, there are always people who are never happy, and who can be a nightmare to deal with. In business, one needs these type of people to sharpen ones negotiation skills - and to show one, how good most people are.
Cheers - Ron.
FollowupID: 760765
