handy vehicle...lazy axle?
Submitted: Sunday, Jan 29, 2012 at 08:32
Member - Royce
This could be fun:
Landcruiser lazy axle
How does a lazy axle effect off road performance? I guess could be a help with weight spreading on sand etc. but maybe could make traction difficult if the drive wheels both lift off the ground?
Reply By: Member - Josh- Sunday, Jan 29, 2012 at 09:20
My understanding is the lazy axle increases the load carrying capacity but offroad can be a real pain. In the case were the lazy axle becomes ground the rear drive axle come loose traction rendering you very stuck. It would be better being converted to 6 wheel drive. Then it would be fun.
Josh
476253
Follow Up By: Fab72 - Sunday, Jan 29, 2012 at 09:25
Agree Josh. Without a boggie drive it's a real hinderence.
Good waste of dollars and a donor vehicle in my opinion.
Fab.
751272
Follow Up By: Member Andys Adventures - Sunday, Jan 29, 2012 at 11:29
Image Could Not Be FoundA bit like this one 6WD I saw at
Jenolan Caves last year
751294
Reply By: Member - Fred B (NT) - Sunday, Jan 29, 2012 at 09:39
Doubt it went off road as such. Looks like a disel fitters or welders truck for onsite work.
regards
476255
Reply By: Member - Phil G (SA) - Sunday, Jan 29, 2012 at 09:52
Royce,
Yep, the rear drive wheels lift off if you go through a gully.
Its had the chassis extended as
well, making it more useless offroad. You'd struggle over a
sand dune - it would bottom out on its belly.
Turning circle would be about 20 metres.
They have wasted a lot of money on a 24 year old Landcruiser.
476257
Reply By: Michael ( Moss Vale NSW) - Sunday, Jan 29, 2012 at 10:12
The fuel bill over time would make the starting price look trivial !! Best to set it on fire and save the planet!!! :) Michael
476259
Follow Up By: Axle - Sunday, Jan 29, 2012 at 20:52
Hahahahahahaha!,!!
Axle.
751355
Reply By: member - mazcan - Sunday, Jan 29, 2012 at 10:37
hi
have seen one or two in bunbury area fencing contractors have one its mainly for load bearing on hard roads with a stretched chassis
was told they are useless in sand on beach or hills as the drive wheel create a wall of sand between the two tyres hence making the drive wheels work even harder trying to drag the lazy axle wheel and it apparently bogs down rappidly
like said double drive rear would be the best use of extra axle installation cost
476265
Reply By: Member - Wamuranman - Sunday, Jan 29, 2012 at 10:54
Hi Royce,
I have owned a 6x4 for 6 years and have found them a great vehicle for the following reasons:
They make a great tow vehicle.
Mine had a GVM 4500kg so it was significantly heavier (and thus more stable) towing a 2700kg van. Refer to thread 91513 below where it is discussed how beneficial (and safer) to have the tow vehicle heavier than what is being towed.
Given that many touring 4x4 are probably over legal weight limits this is a safe and legal option.
Mine could carry 1200kg of gear.
They give a lot more stability on gravel roads – when cornering for example you have 50% more traction on each side of the vehicle (3 wheels instead of 2). When cornering fast on corrugated roads I found negligible drift.
The alleged weakness of losing traction when the lazy axle takes the load is not as significant as some may suggest. It depends on many things such as the quality of the conversion.
Mine was a Briggs Enterprise conversion (
Dalby) and these people knew what they were doing. There was significant articulation in the rear bogie allowing the lazy axle to extend far enough to avoid the drive axle losing traction in most cases.
In addition I always had slightly lower tyre pressure in lazy axle to assist drive axle retain traction. I have witnessed poor conversions (perhaps backyard jobs) where this guy I saw at a shopping centre could not even get over speed bumps. I had no such trouble. But are they designed for extreme off road conditions – probably not. Ceratinly not desert crsssings. The one on Ebay has also had a very significant chassis extension which makes it less suitable for off road.
If you can get one at the right price it may be viable to convert to 6x6.
Like all 4x4’s there are pros and cons for each type of vehicle. If you have the right use for such a vehicle they can be a great buy (especially second hand where the cost of the conversion is usually heavily discounted on resale.
476268
Follow Up By: Member - Beatit (QLD) - Sunday, Jan 29, 2012 at 18:40
G'day,
Intersested in a similar setup but I noticed the Briggs people do not have a web site. I'd be interested in knowing the ball
park cost of such conversion, are you happy to share? I have cheked out creative conversions at Brendale and it will be around $30k for the coversion and GVM upgrade.
I'm clinging to the positive message in your post and I'm happy with vehicle I own so am reluctant to go down the road of a big For Chev or Dodge at this stage.
Kind regards
Theo
751336
Follow Up By: Inflataduck - Sunday, Jan 29, 2012 at 19:18
I have had several briggs 6x4 over 18 years & love them & its only a few
places that it will give you a problem (search
forum)
The briggs is a 60/40 weight share & not a straight lazy that will make your 4wd useless the briggs conversion was classed as 2nd manufacture (full RDA) & came with a full new compliance plate Not a blue or engineers certificate they are no longer made due to the government changing regs, the company makes the little
dingo skid steer if you are close come down & we can do monkey gum or any of the close tracks to Nowra & you will see that they are very capable & legal with a load something most larger 4wd are not
751340
Follow Up By: Member - Wamuranman - Sunday, Jan 29, 2012 at 22:10
HI Beatit,
I think Briggs don't do the conversions amy more. The owner has retired but will still do any small repairs to any of his conversions. I did ring him a few years ago after I purchased
mine second hand and had a talk with him. I do not know the cost as I purchased
mine from the second owner. I am in the process of selling
mine (deposit taken) for a little over $10K.
Mine is a 1988 Landcruiser with 12HT turbo diesel - 323,000km.
751362
Follow Up By: Member - Beatit (QLD) - Monday, Jan 30, 2012 at 04:53
Thanks guys, it seems like a worthwhile conversion.
Kind regards
751385
Reply By: Member - Royce- Sunday, Jan 29, 2012 at 12:22
Hmmm ... If they may a set of chains or maybe a rubber track to fit around each pair of rear wheels, it could go
places.
I'm not interested in buying... I have my own beast to work on.
476278
Reply By: Life Member - esarby (NSW) - Sunday, Jan 29, 2012 at 13:26
Hi All.
Now this would be worth consideration.
http://youtu.be/qZ0IpUaGzs0
Just the thing for running ariund town - it's a Safety thing.
476286
Follow Up By: Mick O - Sunday, Jan 29, 2012 at 16:36
Yeah and at $60K AUD plus freight from Russia, not a bad rig. Might need stronger side walls on the tyres though lol.
751327
Reply By: Ray - Monday, Jan 30, 2012 at 09:32
I just wondered how you would get on converting or building from scratch a half track simular layout to what the army used to have but lighter.
There was also work done on the early Landrovers where a trailer was fitted with a drive axle driven by the power take off on the Landrover.
476365
Reply By: vk1dx - Monday, Jan 30, 2012 at 10:01
Royce
I would be concerned about the departure angle. You could end up with the rear drive wheel totally off the ground making the car a front wheel drive for a while. And if Murphy is around you could get stuck when the front ones are having trouble at the same time. I wouldn't like to take it up that bad steep and rocky section on the Ingeegoodbe Track down near the
Snowy River.
For load carrying, towing heavy loads and hard surfaces I can see some advantage. But for the hills I would question the usefullness.
476366
