Off road trailer spring mounts
Submitted: Friday, Jan 06, 2012 at 16:23
ThreadID: 91052 Views:5402 Replies:5 FollowUps:13
Hi, I did a search but wasn't able to find the answer to my question.
I'm looking for an off road 7x4 trailer that I want to use both as a farm trailer and also to mount a camper tent to. One manufacturer south of Sydney has what appears to be a good product. However, on their off road trailers they only use slipper springs. What's the pros and cons of this for heavy duty applications? They claim the slipper set-up is easier to fix if you have a failure outback.
Appreciate your comments.
Thanks,
Reply By: MrBitchi (QLD) - Friday, Jan 06, 2012 at 16:40
IMO you should always use shackles. Slippers are just a cost saving method.
BTW, I have a 7x4 hot dip gal trailer with removable camper top (and shackle mount springs..) that I might be persuaded to part with.
PM me for details.
AnswerID: 474227
Follow Up By: Member - Johng - Friday, Jan 06, 2012 at 17:06
John, I'm trying to send you a PM after becoming a member, but the site won't allow me. Can you PM me?
Thanks,
FollowupID: 749166
Follow Up By: MrBitchi (QLD) - Friday, Jan 06, 2012 at 17:18
PM sent
FollowupID: 749167
Reply By: garrycol - Friday, Jan 06, 2012 at 17:00
I have looking at a similar issue - my old Jayco Jayflite Offroad camper has slipper springs but has clearly done a lot of outback miles and is in good condition, however I am still not sure about their use - all my box trailers have had slipper springs and I have never have a problem off or on road.
I went to a Jayco dealer and asked about slippers and they indicated the main issue was when reversing where the axle gets caught on something and you keep reversing as it can cause the slipper end to come out of its bracket and once out can be difficult to get back in. This can be minimised by putting a pin through the spring at the slipper end to stop them coming out of their bracket.
In due course I will replace these springs with an independent system if not too difficult.
I think the main issue and this applies to normal springs as well is to ensure the brackets are heavy duty and reinforced and to make sure they are welded on properly.
Garry
AnswerID: 474230
Reply By: Member - Leigh (Vic) - Friday, Jan 06, 2012 at 20:55
Hi John, Have you considered a set of Hilux or 60 series landcruiser springs. They are nice and long and easily sourced outback. The military wrap is a better option also on these springs than what's normally on offer from the manufacturers. My view is slipper springs are best left to the blacktop. Cheers, Leigh
AnswerID: 474239
Reply By: Rod W - Friday, Jan 06, 2012 at 22:20
I'm currently making my own off road trailer. It's tandem wheels and I'm using single leaf parabolic slipper springs.
AnswerID: 474248
Follow Up By: Ross M - Sunday, Jan 08, 2012 at 12:15
If you use SINGLE leaf only it is a disaster waiting to happen eg time bomb and if/when the spring does fracture then axle setup will instantly be the steering system and we will be reading about you in the papers.
I hope not in the obituary column though.
Single leaf and slipper? you can't get much more dangerous than that. May the force be with you.
Older Ford Transit vans had only one leaf and shackle, they worked well but when they broke, goodnight van.
No one with a sound mechanical knowledge would be prepared to tow a trailer with your proposed setup. I definitely wouldn't.
It is not just the trailer but the tow vehicle which also has to be considered, there are usually people in the vehicle while it is travelling and their safety should never be compromised by the towed item.
Many designs of suspension somehow pass Road Authority scrutiny but you wonder how sometimes.
Ross M
FollowupID: 749300
Follow Up By: Rod W - Monday, Jan 09, 2012 at 09:51
What's your qualifications Ross M?
FollowupID: 749380
Follow Up By: Ross M - Monday, Jan 09, 2012 at 13:12
Hello Rod W
The qualies you asked for are:
"A" Grade Automotive Engineer,
Automotive Technician.
Grad Dip App SCI Technology
Automotive Trade Instructor
+ others which aren't applicable to this subject.
FollowupID: 749404
Follow Up By: Rod W - Monday, Jan 09, 2012 at 15:42
So Ross does that mean there is every possibility you know what you're talking about then.
I guess everything has the possibility of failure.
What would you say/opinion on coil springs and their possibility of breaking?
FollowupID: 749415
Follow Up By: Ross M - Monday, Jan 09, 2012 at 16:32
Yes Rod, you are right everything has the possibility of failure it is just some ways minimize the failure rate. A coil set up drops when break occurs but usually doesn't instantly take over the steering.
Leaf springs have interleaf friction which tends to dampen the spring action to some degree. Thankfully they don't often break. Carry a spare leaf if you go that way.
A coil spring generally rides better and is more compliant if something not too heavy is chosen. A coil is just a spiral torsion bar.
I have a T van and while it is ok like all campers, all have pros and cons, it's suspension style is very good. The two point pivoted axle/arm setup is great.
Quality of manufacture could improve somewhat.
You can make your own and incorporate electric brakes just the same.
An engineering shop might be able to help you if your resources don't extend to it.
The coil spring doesn't have any internal friction so they tend to bounce, boing boing, and hammers the tyres back onto the ground more than a leaf does, so shock absorbers are required. A coil can break but you can always carry a spare if.
It depends on the amount of travel required upward and downwards from the running position eg 2/3 up 1/3 down, how long the spring has to be and what height the trailer will be loaded and unloaded.
Spring manufactures can probably be of help here to zero in on your spring selection for your load/travel combination.
Lots of sorting out problems here but it can be done. Just pinch ideas from other designs and best suit them to your requirements.
I will eventually make my own two point arms for my 6x4 and use coils.
You can make a jig out of some rhs which will ensure each of your axles are the same. Remember the forward/rearward setup of the cross arms when doing this though.
As far as welding goes, advice on where to weld is advised. But you couldn't get worse than some professionally built ones. Most manufactures are good but it is in forums like these the failures in newish, well used and second hand used campers suddenly become noticed.
On 4wdaction there is a post from someone who's axle broke going into the mountains near Dargo Vic. Interesting. Has pics too.
Hope this helps un jumble the myriad of possibilities.
Ross M
FollowupID: 749422
Reply By: Ross M - Saturday, Jan 07, 2012 at 23:09
I changed the short sharp incompressible slipper spring on my 6x4 a few years ago.
Used HJ60 LCruiser fronts with the overload taken out. Added 50 Sq axle and also used the LC shackles and short VW shocks.
Trailer doesn't bounce, will take a load, is very compliant and soft riding and handles the Oodna track easily.
Std springs with slippers are a disaster waiting to happen and if it does where will it be when it happens, you guess, yes outback. Got it right first time.
Chuck the originals and upgrade to something decent which can perform the required functions.
You don't see landcruisers with slipper springs.
Ross M
AnswerID: 474338
Follow Up By: garrycol - Sunday, Jan 08, 2012 at 01:44
But what is actually wrong with slipper springs. The issues you raised about short stiff slippers equally apply to short stiff normal springs. If I were to use long soft compliant slippers why would these be worse than long soft compliant normal springs.
No one has actually said what the problem is with the slipper design vs normal design when similar length and compliance is used.
Garry
FollowupID: 749268
Follow Up By: Alan S (WA) - Sunday, Jan 08, 2012 at 11:33
Garry
My understanding is that if the spring breaks the slipper design will fall apart. Where as spring bolted both sides if it breaks you have a better chance of being able to strap it togethor to get home.
In reality if either springs break and fall apart it will be probably near either end and a temporary fix will be very difficult anyway.
FollowupID: 749297
Follow Up By: Ross M - Sunday, Jan 08, 2012 at 11:54
If you are worried about the slipper action specifically then these are the features I don't like:
1.The slipper is not mechanically secured to the vehicle.
2. The slipper end slaps up and down and is noisey even though some have two spread leaves trying to stop that happening.
3 There is friction in everything but the slipper ends have to be in a high friction sliding action all its life unlike a shackle/greased and mostly sealed, having the sliding action converted to a rotary action in a bush of some sort.
4. If you haven't got military wrap on the front eye end then if the spring eye broke the shackle can't move far and will upset the alignment of the axle greatly, BUT,
the slipper will just force its way back until it steers you into on comong traffic or over the edge. Will you be alert enough and have enough experience to instantly detect this happening and therefore avoid the disaster?????
It isn't very rewarding to see your $50.000 4wd crashed and destroyed and your holiday ruined because of substandard suspension.
5. If you intend to use shockers on the trailer the shock action will be somewhat reduced by the slipper spread leaf feature trying to flex open and shut as the road forces are applied to the shock and suspension.
This flapping flexing doesn't occur with shackles to any worrying degree.
6. As mentioned slippers are a cheap and nasty way of making a suspension.
FollowupID: 749299
Follow Up By: Member - Johng - Sunday, Jan 08, 2012 at 14:45
Thanks for all the comments. It seems to me from the responses that the major issue is that should a main leaf break forward of the axle, having the rear of the spring restrained by a shackle rather than a slipper is likely to be less of an issue safetywise.
It's possible that I overstated the off road aspect, when in reality, all I want is a sturdy trailer for farm use, that can also double as a camper trailer for no more than a gravel road applications. So thanks for taking the time to respond.
FollowupID: 749308
Follow Up By: ozjohn0 - Monday, Jan 09, 2012 at 15:51
Ross M's Answer #6 covers everything I could add.
Ozjohn.
FollowupID: 749418
Follow Up By: garrycol - Monday, Jan 09, 2012 at 16:25
Thanks Ross - not trying to be argumentative but trying to understand - my comments against your points.
"Ross M posted:
(Is this important as its actions are restricted so mimick as if it secured to the vehicle)
(If that is your experience Ok but it has not been my experience - I have had slippers since 1975 and they have been on all my trailers and vans)
(Don't follow this point - the metal on metal action is relatively friction free once the two surfaced have worn a bit)
(I agree completely with military wrap springs but both normal and slippers can come in military wrap springs - the slippers on my box trailer are not military wrap but the slippers on my offroad van are military wrap so your point applies to springs that do not have a military wrap rather than to slipper springs.
(Why - from the axle (where the shock connects) forward is the same on both type of springs so shocker action is the same - at the back end, in both cases the the end of the spring is moving back and forward with increasing and decreasing shock load. In this regard both slipper and normal springs are acting in the same way - lengthening and shortening as load increases and decreases)
(I have had heaps of issues with spring mounts and rubbers on my normal springs but never any with the slippers - I agree most slippers are cheap and nasty but so is the $30 shackle spring from supercheap. There is nothing you have said that makes slippers worse than shackle springs when the same parameters are applied to both springs, ie same length, same number of leaves, same mil wrap etc. - the only issue I have been able to find out in all this is that there is a possibility t,hat the slipper can come put of its bracket when reversing. Other than that, based on the evidence put forward in this thread, slippers are as good as shackles assuming the same parameters are used but what seems to be happening is cheap, single wrap, short, tight slippers are being compared with more expensive, mil wrap, long and compliant shackle springs.
I am happy to be convinced otherwise)
Garry
FollowupID: 749421
