Tasmania Western Explorer Hwy
Submitted: Saturday, Oct 01, 2011 at 19:45
ThreadID: 89325 Views:2193 Replies:4 FollowUps:1
We are touring Tassie next month and would like to see if we can travel from Zeehan to Arthur River along the Western Explorer Hwy with a Nissan Pathfinder towing a 17ft pop-top - basic van except for a 4in lift & 4WD tyres. Can we fit on the ferry or do we have to come in from Savage River. Any comments on road conditions would be appreciated. Thanks Jolo
Reply By: Member - Rob S (NSW) - Saturday, Oct 01, 2011 at 20:43
Hi Jolo
Shouldn't be a problem with your vehicle and van on the fatman barge
easly fitted two 80 series landcrusiers.
As for the road conditions from Zeehan 12 months ago was ok and a good gravel road all the way to West point, though a bit narrow in the twisty bits and a nearly got cleaned up buy some coming the other way too fast around a corner.
Well worth he drive wish i had more time.
Image Could Not Be Found
Rob
I only ever made one mistake
AnswerID: 466522
Reply By: Nomadic Navara - Sunday, Oct 02, 2011 at 09:23
Here are the dimensions - work it out yourself. The prime measurement you did not supply is distance between the centre of the front axle to the centre of the rear axle. There are other dimensions to work around, you will have to do your own figuring.still do the northern
If you can't fit the ferry, just do the northern section. It's worth doing that and exit the Explorer via Waratah.
AnswerID: 466544
Follow Up By: Nomadic Navara - Sunday, Oct 02, 2011 at 09:26
Edit, I see you are driving it the other direction. Yes come in via Waratah.
FollowupID: 740662
Reply By: GimmeeIsolation - Sunday, Oct 02, 2011 at 15:16
Very easy drive, can be done in any car now they have upgraded the track.
AnswerID: 466579
Reply By: Member - Alan John C (WA) - Monday, Oct 03, 2011 at 22:12
Nine mtre wheel base combo with minimum 200mm clearance. Google , fat boy barge corrina tasmania.
AnswerID: 466727
