Anne Beadell Hwy Conditions
Submitted: Sunday, Sep 25, 2011 at 21:13
Member - 4Motion
Hey Guys,
We are planning to head across the AB from
Laverton to
Coober pedy in a coupke of weeks and were after some input. I have heard tell that the scrub can get pretty tight in
Places. Our camper is a bit wider than the car and while I am not worries about scratches I would like to know how heavy the scrubs will be to get through?
Ben
Reply By: Member - Anthony W Adelaide - Sunday, Sep 25, 2011 at 23:15
Hi Ben,
We are heading across the AB in a couple of weeks time too from
Coober Pedy to
Laverton. My research says all is good except for the usual corrugations. I will be ringing the
Ilkurlka Roadhouse a few days before we go for up to date conditions though.
466051
Follow Up By: Member - 4Motion - Sunday, Sep 25, 2011 at 23:30
Thanks Wooly, I have spoken to the roadhouse and heard the WA end was graded in the last couple of months, so may run into you on the trip we should be leavig
Laverton on the 4th or 5th of October.
740117
Follow Up By: Member - Anthony W Adelaide - Sunday, Sep 25, 2011 at 23:52
No worries Ben. We should be leaving
Coober Pedy on 9th or 10th if all goes
well. Should see you on the track somewhere. We have a white 80 series toyota and a cavalier camper.
740118
Follow Up By: Member - 4Motion - Tuesday, Oct 04, 2011 at 17:59
Hey Wooly,
We are about to leave
Laverton WA heading for Cooberpedy. We will be out of service from Now on. Expect to land at
Coober pedy 9th of 11th.
This end has been quite wet so not sure on conditions but track is listed as open at
Laverton.
Good luck and hope to see you on the way.
BTW we are running on UHF channel 19.
Ben and Helen Richards
Also travelling with Barb and John Richards.
740878
Follow Up By: Member - Anthony W Adelaide - Tuesday, Oct 04, 2011 at 23:23
Hi Ben,
We are still on track to leave
Adelaide early on Sat 8th and go through
Coober Pedy on 9th. Hope to
camp in Tallaringa on Sunday night. We will keep an eye out for you, be good to get an update on conditions.
Cheers, Wooly
740919
Reply By: Members - Bow & Nan - Monday, Sep 26, 2011 at 00:13
You will get plenty of scratches
Image Could Not Be Found
466052
Follow Up By: Member - 4Motion - Monday, Sep 26, 2011 at 01:17
Nice pic! How much of this stuff is there? Does it get much tighter?
740120
Follow Up By: Peter_n_Margaret - Monday, Sep 26, 2011 at 05:22
The occasional OKA helps keep it under control. :-)
Peter,
OKA196 Motorhome
740122
Follow Up By: Member - Stephen L (Clare SA) - Monday, Sep 26, 2011 at 07:40
Hi 4Motion
The above section is out of
Laverton on the way out to Yamarna. It is only for a short distance. For more images of what you can expect to see, have a look at my Blog on the Anne Beadell.
It is a great trip, take your time and allow a minimum of 7 days to complete the crossing. Your biggest friend will be low tyre pressures and keep to speed
well down.
Have a great trip.
740124
Follow Up By: Member - 4Motion - Monday, Sep 26, 2011 at 20:01
I see your mate had a pretty big van with him. Did he have any trouble, aside from broken windows?
740181
Follow Up By: Member - Stephen L (Clare SA) - Monday, Sep 26, 2011 at 21:22
John's van was not an off road type and he did have trouble. As his van was wider than his vehicle, the van cope fairly
well but had axel problems from the constant corrugations.
On the other hand, Stewart and his F250 and off road camper went through without any problems what so ever.
Like I said before, keep you tyre pressures down and you will have an enjoyable trip.
740186
Reply By: Design Interaction - Monday, Sep 26, 2011 at 16:53
Hi Guys,
We travelled the Anne Beadell not too long ago to map the track from
Coober Pedy to
Laverton. Our Map Guide has all the information your may need including Len Beadells bench markers and good
camping locations. There are plenty of pictures along the track and we have provided GPS co-ordinates throughout.
Our books is called 'The Outback Travellers Track Guide' -
Anne Beadell Highway.
It is available from the ExplorOz
Shop or directly from our website:
www.outbacktravellers.com.au
You will enjoys the trip and it is quite interesting around the Emu area. The corrugations can be bad, but no worse than many other tracks. The SA section has a tighter track with vegetation encroaching that will scratch your 4wd.
Sand dunes don't cause any need for alarm; reasonably low dunes and sand fairly compact.
Have a great trip.
Greg.
466083
Reply By: Member - bob v (WA) - Monday, Sep 26, 2011 at 17:08
Hi Ben, We finished the
Anne Beadell Highway on the 16th Sept. Pretty much all of the WA side is not too bad, some corrugations and bumpy bits but not much worse than you can find in the hills around
Perth. The
wildflowers on the WA side are lovely but we thought a bit disapointing on the SA side. The track get a lot worse as soon as you cross the boarder into SA. It is a lot rougher and more twists and turns. The section from Emu for about 100 km's is really bad and very slow going. We are glad we did not take the Jayco as it would not have survived. Parts of the track were narrow enough to keep knocking the mirrors in on both sides of the car which is a Patrol. If you are going to take the side track to see the crashed plane be very aware there are about 10 big
sand dunes which are very sandy and steep with sharp turns at the top. We did have any punctures along the way on any of the 3 Patrols in our group however we did manage to break 1 rear window and 2 of us had tail light fall out and 1 had his roof rack move forward about 30cm even though we were always checking and tightening. We also had to replace the shockies on the trailer. Our fuel consumption was pretty even around 20ks p/l even though we were towing a purpose built trailer. When you arrive in
Coober Pedy we recommend staying at least 1 night in the Comfort Inn it is truly an underground hotel with probably the most friendly staff we have met. We also recommend eating at John's Pizza Bar.
466086
Follow Up By: Member - Wayne B (NSW) - Monday, Sep 26, 2011 at 22:34
Any problems obtaining the Permits required I heard there are 4 different ones you need.
What is the lead time for the permits.
Thank you
Wayne B
740193
Follow Up By: Member - Anthony W Adelaide - Monday, Sep 26, 2011 at 23:41
Permits are very straightforward. You can get them all by email except for Tallaringa which is either desert parks pass or single
park pass from DEH.
All took less than 2 weeks.
740196
Follow Up By: Member - Wayne B (NSW) - Tuesday, Sep 27, 2011 at 15:40
Ok Thanks for that.
Sounds easy enough.
Wayne B
740244
Follow Up By: Member - Anthony W Adelaide - Tuesday, Sep 27, 2011 at 18:16
Sorry Wayne,
I forgot to add that the treck notes on this web site have all the permit details. Doesn't take very long to get them.
740259
Reply By: Member - Bruce T (SA) - Thursday, Sep 29, 2011 at 10:57
Image Could Not Be FoundBen,
We've just got back from the Anne Beadell. It's really an amazing desert. We went from Nullarbor to
Cook to Vokes
Hill and then on to
Laverton. We found the narrowest part was from
Cook to Vokes
Hill. We completely wrecked and lost our sand flag there. We also finished up with a very scratched car, not so happy as it's only a year old, but they are 'battle'scars. Our camper (
Kimberley) showed scratches too but we used toothpaste on it when we got home and it took them off. (We're now about to try it on the car!) Friends travelled with a Vista RV and that was scratched due to the narrowness of the road in parts.
We elected not to travel from
Coober Pedy to Vokes
Hill due to the corrugations. Two of our travelling companions travelled this route and said the corrugations were horrendous.
The Anne Beadell was wider and not so squeezy.
The scenery was amazing, so lush, beautiful flowers and generally great weather. After the Simpson the Great Victoria is a virtual Paradise.
Ilkurlka advised us to slip out via one of the roads to the Great Central as the road going on was in such bad condition. We were glad we did because it was just amazing countryside.
The WA permits came really quickly but we had to chase up the SA permits. The Spinifex Country was amazing and the community certainly makes visitors feel welcome on their land.
Di and Bruce
466318
Follow Up By: Member - 4Motion - Thursday, Sep 29, 2011 at 16:40
Thanks Bruce, Our permits are all sorted. Which road did you take out from Ilkurlka then? We are going west to east so need to check the best way to get on to the road. I have heard from the roadhouse that the WA section was graded in the last couple of months. When did you come through?
Cheers, Ben
740425
Follow Up By: Member - Bruce T (SA) - Thursday, Sep 29, 2011 at 18:41
Ben,
We continued on from Ikurlka. 24km from there is the turnoff to The Great Central along the
Point Sunday Road. It was about 168km to
Laverton once we hit the Great Central. We travelled the Anne Beadell at the beginning of September
We were told that there was roadworks at the
Laverton end of the Anne Beadell and Ilkurlka told us it was heavily corrugated and rough so we took their advice.
Di and Bruce
740440
Follow Up By: Member - 4Motion - Thursday, Sep 29, 2011 at 21:27
Awesome, we will
check out that option!
Ben
740462
Follow Up By: Member - Bruce T (SA) - Thursday, Sep 29, 2011 at 21:55
Whoops, should read 'were roadworks'.
740465
