Sunday, May 29, 2011 at 17:47
Vehicle Standards Bulletin 14 (VSB 14) Vehicle Regulation Related Links
?Certified Road-Friendly Suspensions
?Seatbelts for Kids
?Vehicle Safety
?Vehicle Standards Bulletins
?Road Safety
National Code of Practice for Light Vehicle Construction and Modification (NCOP)
4.2.4 Overall Nominal Diameter
The overall diameter of any tyre fitted to a passenger car or passenger car derivative must not
be more than 15mm larger or 26mm smaller than that of any tyre designated by the vehicle
manufacturer for that model.
The overall diameter of any tyre fitted to:
? 4WD passenger vehicles specifically designed for off-road use (typically MC ADR
category). All wheel drive (AWD) vehicles including those AWD vehicles that may be
certified as MC ADR category, (also commonly known as soft roaders) are not
included in this category;
? 4WD goods vehicles and their 2WD equivalents if the chassis and running gear are
essentially the same as the 4WD version (N ADR category); or
? any medium weight goods vehicle (NA2, NB ADR category).
Must not be more than 50mm larger or 26mm smaller than that of any tyre designated by the
vehicle manufacturer for that vehicle.
Note: Increases in tyre diameter are subject to compliance with all other requirements
specified under this clause (Clause 4.2 Non-Standard Tyres and Rims) and may
therefore be limited by other factors such as insufficient clearance.
Speedometer accuracy must be maintained for the selected tyre and rim combination to within
the degree of accuracy specified in ADR 18 where applicable. It is suggested that the degree of
accuracy is in accordance with the most recent version of ADR18.
728740
