madigan line
Submitted: Tuesday, Apr 26, 2011 at 20:25
ThreadID: 85881 Views:3072 Replies:7 FollowUps:15
We are planning a trip across the Madigan Line as far as Hay River then north up the Hay River track in August. Whilst my vehicle, a 2007 Mitsubishi Triton is improved as far as suspension, front diff lock,tyres etc I have some reservations for a trip such as this.
I wondered if any one who has done this trip had any thoughts about this vehicles capacity to handle the conditions.
Who would handle the permit application to visit camps 3,4 and 5?
Thanks in advance for your help.
Tony
Reply By: Member - Stephen L (Clare SA) - Tuesday, Apr 26, 2011 at 21:05
Hi Tony
Your Triton will have no problems out there, as long as it is diesel. Your three most important pieces of equipment - in various sections will be
Long Handle Shovel
Snatch Strap
Good quality puncture repair kit and good quality plugs
Allow a minimum of 300 litres of diesel for the trip and as for permits for camps 3,4 and 5, forget it, you will never get them from the CLC, I have tried a number of times and they refuse point blank to issue them. From The Twins, you will have to travel south for that gap between the Aboriginal Lands.
Have a great trip.
Smile like a Crocodile
AnswerID: 452391
Follow Up By: Member- Tony C - Wednesday, Apr 27, 2011 at 06:29
Hello Stephen,
Thanks for your advise.
It is a good to know that you think the Triton is capable of this trip. Fuel consumption must increase significantly to warrant carrying 300 litres of diesel. Other desert trips the vehicle has consumed up to 15 litres/100k.
It was my job in the party to pursue a permit for 3,4 and 5 but it sounds that this would be fruitless.
Tony
FollowupID: 725091
Reply By: Member - Phil G (SA) - Tuesday, Apr 26, 2011 at 21:17
Similar advice to Stephen, but I'd suggest you'll be OK with 250-260L of diesel if you are starting from Mt Dare. Petrol vehicles can manage, but usually need 100litres more.
I'm hoping you are travelling with other vehicles - its no place to be stuck alone.
I've been out there twice and on both occasions we had vehicles break suspension components - a lower front arm on an IFS Landcruiser, and a rear control arm on a Prado that needed welding, and seen shocks spit their fluid. You'll be spending most of your time crawling over spinifex moguls, so you'll be lifting wheels a bit with the triton. Plugging tyres is part of the experience.
Plan well, take it easy and don't be in a hurry!
phil
AnswerID: 452395
Follow Up By: Member- Tony C - Wednesday, Apr 27, 2011 at 06:43
Hello Phil,
Yes will be doing this trip with two other vehicles, an IFS 100 series diesel and a Prado diesel.
I take your point on not hurrying. When travelling alone I always take my time. This can be a bit more difficult in a group to keep up the pace.
What do you think about the breakdown you experienced with the 100 series IFS was it one off accidental damage or a weakness with the lower front arm?
Tony
FollowupID: 725092
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 27, 2011 at 18:07
The 100series was the typical lower arm problem - breaking where the torsion bar attaches. That trip was in 2004, and the Landcruiser was about 12 months old. He was driving normally back in the convoy. Had brand new ARB suspension including the upgraded torsion bars - the front shock spat their fluid and were replaced with spares the day before the arm broke. It was still attached, so he was able to limp out the rest of the trip very slowly on his bump stop.
Don't hear of as many arms breaking these days - I think Toyota had it fixed on the later models. ARB do make a strengthener kit.
The Prado that broke the rear upper control arm was a 90series - it took two attempts to weld it strong enough for it to last the rest of the trip.
A read of the visitor books also give you an idea of what other groups have had go wrong. Most failures are suspension naturally enough, and aftermarket bits seem more likely to fail than factory components. But carrying the kitchen sink and travelling fast are the surefire ways to break something.
FollowupID: 725149
Reply By: Mel59 - Tuesday, Apr 26, 2011 at 23:11
Hi Tony,
I agree with the others. We did this 3 years ago with a big group. I had a 2004 rodeo 3lt diesel, modified, 265x75-16. front locker and suspension. Broke a leaf in each of the rear springs but made it home that way. A few others had suspension problems but with some outback welding no major issues besides the flats.
Of our 11 vehicles I had the best fuel economy. Mt Dare to Birdsville 160 lt, took 240, the worst was the leader 4.2 Patrol 210lt. There had been rain a few weeks earlier and the sand was not that bad but still challenging. My technique for the rough stuff was to idle 2nd low range and let it walk over the spinifex mounds. Our slowest day was 16 km.
Brilliant trip but most said never again, it is hard driving and very remote. You will be following new tracks but sometimes they may not be the best over the sandhills.
You will not get permits. The year we went the early crossers went by 345, you could see the tracks, but we respected the no go.
regards Mel
AnswerID: 452404
Follow Up By: Member- Tony C - Wednesday, Apr 27, 2011 at 06:53
Hi Mel,
Thanks for your comments. I would be running 215/85/16 Toyo m55,s so hopefully these should provide enough clearance. These are not quite as large a diameter as your tyres.
My rear leaf's are King springs which have been good so far. Do you think it would be worth carrying spare rear springs and putting up with the additional weight?
Tony
FollowupID: 725093
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 27, 2011 at 18:13
Tony,
If I can make a suggestion - spare full rear leaf springs are too heavy to carry as spares. A single main leaf, two spare U-bolts, spare spring bushes and a spare front spring pin are what I would carry.Check the U-bolt tightness at the start.
FollowupID: 725151
Follow Up By: Michael A (VIC) - Wednesday, Apr 27, 2011 at 20:12
and I would add a couple of centre bolts....
FollowupID: 725171
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 27, 2011 at 20:39
Gday Michael,
Yep, forgot to add the centre bolts (which I do carry), but a broken centre bolt won't stop you - I've seen a 79series travel for 12 months with a broken centre bolt - it had been crabbing the whole time- even got a wheel alignment where they adjusted the front to follow the rear without realising a centre bolt was broken! But centre bolts take up no space, so worth throwing them in. Lengths of threaded rod and nuts is something else I carry that will do the job of a centre bolt, and can be used for other stuff.
FollowupID: 725177
Reply By: Ozhumvee - Wednesday, Apr 27, 2011 at 07:44
Agree with all the others advice, FYI there is a new (put in a few years ago now) exploration road from North Bore (where you visit the Mac Clarke reserve) through to the Colson and camp 6.
It was proposed to continue down towards Geosurveys Hill but don't know if it has/did.
It leaves Nth bore on the western side and swings around the reserve before heading east. There was a big camp just west of the Colson.
Possibly worth backtracking from the Twins to use it to get across to the colson as it is far easier than scrub bashing, not sure about the legality though.
AnswerID: 452417
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 27, 2011 at 18:15
Gday Peter,
Thats good info - I reckon the good people at Andado Station would be able to advise too.
FollowupID: 725153
Reply By: Robin Miller - Wednesday, Apr 27, 2011 at 08:00
Planning to do that drive late July , but doing end part as well instead on going up the Hay again Tony - biggest problem I see is weather which may mean we have to change plans a bit.
Couple of troppy based vehicles going with us , they plan on 240lt , mine is pertol so I will carry up to 300lt .
Plan to average 50k min per day.
Had a gathering and vehicle check out over easter as lots of new bits.
If weather delays us we may end up seeing you.
Robin Miller
AnswerID: 452419
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Apr 27, 2011 at 14:36
Hi Robin
Please do not think that I am cynical, but your plans on your daily distances will be greatly reduced once you get out into the desert proper. There is a very big chance that when you are out there, you will be lucky to do even half of what you have as a daily average, like I have said many times, it is no normal Simpson crossing.
The moment that you start to push your vehicle out in that country is when things will break, no questions asked, in a very big way.
Work on around a maximum of 30 - 33 kilometres per day and you will be on the mark.
Have a great time and do not push the vehicles.
FollowupID: 725123
Follow Up By: Member - Howard (ACT) - Saturday, Apr 30, 2011 at 20:46
Stephen,
I am unsure of your daily travel times but I am aware of an AULRO trip in August 2008 where it took 11 days Old Andando to Birdsville missing camps 3,4,&5 but including a night at Geosurveyors hill where there daily travel distances (in Kms) were
52, 51,59,64,53,22(stopped at lunch time-black tie dinner that night),61,75,73, 58,138.
an average of 64km per day
none of the 5 vehicles experienced any problems on this leg of their trip.
all landrover defenders , trip leader used 170 litres from Finke to Birdsville.
I understand conditions vary year to year but they had no problems in doing twice the daily average you mention and the 50 km per day was achieved on all but one that was essentially a rest day.
Howard
Resigned to Retirement
FollowupID: 725613
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Apr 30, 2011 at 22:56
Howard
Have you ever been out there and seen and driven in the real Simpson, not the easy tracks that everyone usually takes?? If you have then you will see why I have stated what I have, as well as the others that have been out there as well stating that it was a very big ask. There are no medals for setting any records and if those figures are correct, so be it, but what were the conditions of all vehicles really like after their trip and how long were they driving each day??
If you follow any replies that I have ever made, I do so to give the reader an idea of what to expect in the real world, and to travel safely with the least amount of damage to vehicle and driver.
If those distances were covered each day, then they would have been very long and hard days, starting before sun up and travelling well after any normal person out there would call it a day and set up camp and enjoy the solitude of the desert.
Like you, I also enjoy reading. When I was a member of the Honda Riders Association of Australia a good number of years ago, I read a report that a group of riders on CBR1100XX Blackbirds (The same bike that I owned) while on a trip around Australia covered a distance of over 200 kilometres, just inside of the Northern Territory in just over 50 Minutes, yes you have read correct. Yes it is easily on a bike like that for a stock standard bike that was capable of speeds up to 300 kilometres per hour, but very unsafe and something that they were crazy to do. So having read this, does this mean that anyone else can safely do that distance in that time - NO WAY!!
The reason why adventurous travellers go out into truly remote areas is not to set records, but to see and experience a place that few people get to see at a pace of travel that not a marathon.
FollowupID: 725623
Reply By: Ozhumvee - Wednesday, Apr 27, 2011 at 18:42
Robin
I agree your daily average is a bit on the high side, we had one day we did 16k, for several days when we had no tracks to follow we never got over 6-8 kph with 4 vehicles. Suspension takes an absolute hammering as do the passengers, driver is ok as he/she has the wheel to hold, passengers just get flung from side to side constantly.
AnswerID: 452475
Follow Up By: Member - Stephen L (Clare SA) - Wednesday, Apr 27, 2011 at 18:59
Hi Peter
Well said and until anyone has been out there 'in the flesh', as such, they have no idea of what the terrain is like. Fiona had sore hips and shoulders for a good time after the trip, from all that constant side to side travel.
FollowupID: 725159
Follow Up By: Ozhumvee - Wednesday, Apr 27, 2011 at 20:25
The Humvee was actually very comfortable due to its wide stance, independant suspension all round and very low C of G, it just waddled over everything. One of the other vehicles was a 79 trayback with a Trayon on the back and the ride in the cab was pretty hard and the trayon actually shifted a few times despite being held down at each corner. Some of the passengers chose to walk at every opportunity and it was rare for the convoy to travel for any longer than an hour without a break due to the continuous pounding on the rough bits. An auto is definately preferred.
FollowupID: 725175
Follow Up By: Robin Miller - Wednesday, Apr 27, 2011 at 20:41
Hi Guys
50 (average) shouldn't be to hard for the Patrol and I'm sure you are right and it will include some days of 20-30 and some of 80.
I am going with some troppies though and I have seen people get back trouble from mogul traverses and physical exertion so I am a bit concerned.
It a reason I use easily settable shocks.
I have also chosen to take my manual rather than auto Patrol after our recent tests showing the fuel advantage so I suspect we could have an interesting time out their.
For my car I am mostly concerned about punctures though and probably will go with a little higher than average pressures and repair bits.
Just hope the weather holds for Tony and others - if not well we will try again sometime.
Robin Miller
FollowupID: 725178
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 27, 2011 at 22:55
Gday Robin,
Patrol is no different to the troopies, Pajeros, landcruisers, Prados or whatever. You'll be pitching from side to side in any vehicle. Every vehicle that goes there can break stuff - the panhard rod bushes failed on a patrol on our 2006 trip and replacements had to be doctored up. And given the weights and the conditions, coil patrols are at risk of the rear spring towers bending/cracking, especially with airbags.
Like Peter said, stopping every hour to have a stretch and smell the roses (or spinifex) is necessary.
Aftermarket shocks seem to fail more often than factory shocks so carry spares (old factory shocks are very good spares). I've only driven manuals out there, but usually settle for 1st gear high or 3rd gear low in Landcruisers - just enough to keep a good speed at about 1200 revs without stalling - you're basically idling over the moguls (with a TD anyway). You might need a few more revs with a petrol vehicle. Autos are easier, but the only auto on our first trip smoked its torque converter (maybe from the driver keeping it in high range).
Punctures - almost all are sidewall stakes - almost every puncture I've seen out there has been fixable with a plug. If you've got a puncture, hook the pump up to get more air into it, pull out the stake (make sure you haven't left any in), load a plug with glue and insert and twist. Reinflate to 16psi and drive on. Usually only takes 10 mins all up. If anyone is taking split rims, then you'll spend 30 minutes changing the wheel and an extra hour at camp repairing the puncture.
Lower pressures are the way to go - better fuel consumption and fewer punctures. about 16/20 psi F/R is what we have used in the past.
FollowupID: 725200
Reply By: Member- Tony C - Wednesday, Apr 27, 2011 at 22:50
Hello Robin ,Phil, Stephen and Peter,
very much for your helpful advise and suggestions following your experiences gained in doing this trip. This will be a great help in planning and providing an insight in what to expect.
Tony
AnswerID: 452511
