Aussie Truck Mirrors
Submitted: Thursday, Dec 02, 2010 at 23:59
Member - Andrew (WA)
Anyone use these mirrors when towing? From what I read they seem like the preferred choice???
Looking for feedback and does anyone kow where to get a pair in
Perth? Who sells them?
Reply By: Member - Toyocrusa (NSW) - Friday, Dec 03, 2010 at 06:13
Hi Andrew. Quite a bit of info in this thread 82733 I have them on a 120 Prado and do find they can be a bit awkward to fit, vibrate a bit and rub the glass if you are not carefull. ( I think all mirrors of that design would have the same problems) I ended up making brackets to turn them verticle but haven't used them that way yet. They are available at most caravan accesory shops and on the internet. (ebay, etc) Regards,Bob
437671
Follow Up By: Member - Toyocrusa (NSW) - Friday, Dec 03, 2010 at 06:33
Image Could Not Be Found
Photo of them fitted on our last trip recently.
Murray Bridge. S.A.
709251
Follow Up By: Member - Graham H (QLD) - Friday, Dec 03, 2010 at 14:37
You will find they dont vibrate so much if you drop the support on the webbing down to sit against the furtherest out part of your door.
It gives a more rigid fixing.
709285
Follow Up By: Member - Toyocrusa (NSW) - Friday, Dec 03, 2010 at 21:26
Hi Graham. I'm guessing you mean to lower it down onto the false part of the door but it is only plastic and held on with plastic push plugs so it is not a very solid part of the door. May be worth a try next time to see what happens though. Thanks, Bob
709311
Follow Up By: Member - Graham H (QLD) - Friday, Dec 03, 2010 at 21:31
Yes A triangle is a strong way of bracing something but not if one corner of it is floating in mid air so to speak.
On my 100ser the bracket is on the
grey plastic strip that runs along the door.
It hasnt rubbed it and you cant really tighten them up enough to damage it.
HAve been on there for most of 50,000k
The way you have it allows the mirror bar to move in and out making the mirror vibrate.
709314
Reply By: Racey - Friday, Dec 03, 2010 at 09:08
Hi Andrew, I had a pair of these and found they interfered with the window operation. There is also the risk of damaging the window seals. After one mirror virbrated out at
Lake Mungo, I bought a mirror system which fits across the bonnet. Eazy to fit and when on-site the mirror section can be slid out. All this at half the price. Unfortunately I can't recall the brand.
Chears
Racey
437683
Reply By: Member - Bruce C (NSW) - Friday, Dec 03, 2010 at 13:35
Hi Andrew,
I have only ever used these Aussie Truck mirrors and I find them dam good.
My nephew, now deceased, used to work at Repco and he advised me that they were the best so I took his advice. That was 4 years ago and I have praised him ever since.
My mate lives down Nowra NSW way and he used those clip on units and although he had done about 8000K with them, the drivers unit vibrated free while returning from his last holiday.
I bought him a set from Ebay for around $60 a pair from a WA trader. He was stoked to say the least.
Mate, check out ebay. Easy As Sales was the traders name and I think Lisa was the person I dealt with, name could be wrong. They were good communicators and very prompt with deliveries.
Please note I have no connection with the trader mentioned other than a satisfied customer.
Cheers, Bruce.
437694
Follow Up By: Member - Bruce C (NSW) - Friday, Dec 03, 2010 at 13:39
Should have added that, as can be seen from my sig. pic that i have an 80 series cruiser as our tug. No problems fitting them just be precise and careful. once setup they stay set up for that vehicle.
709278
Reply By: Member - Graham H (QLD) - Friday, Dec 03, 2010 at 14:07
Camec at
Welshpool sell knock offs of Aussie Truck mirrors for a lot cheaper than genuine ones. Cant tell the difference The guy said they come out of the same factory.
The Repco ones I looked at were of a lesser quality.
437699
Follow Up By: Member - Graham H (QLD) - Friday, Dec 03, 2010 at 14:13
If they rub on the windows try this
lower the window fit the mirror Hold end of bar and pull outwards wind window up Make sure the fixing strap is really tight.
You can also bend the fingers that go in the window trough a little bit to help with this.
709283
Follow Up By: Member - Andrew (WA) - Friday, Dec 03, 2010 at 15:49
Thanks Graham
off to
Perth next week and will visit Camec...
709289
Reply By: Member - Doug T (NT) - Friday, Dec 03, 2010 at 16:20
Why not get some really good mirrors, like these smaller West Coast Mirrors . same as like what's on a Semi but smaller.
437706
Reply By: Roachie.kadina.sa.au - Friday, Dec 03, 2010 at 21:00
Clearview Mirrors
Don't waste your time on any other junky, vibrating, useless mirrors..!!!!
These things are the ducks guts!!!! I love em. If you have a 200, 100, 80 cruiser or GU Patrol or even some Prado models....these are great.
437728
Follow Up By: Nev (TAS) - Friday, Dec 03, 2010 at 21:49
Another vote for Clearview mirrors. May cost a bit but are very good and convenient. No more messing around putting on and removing mirrors.
709318
Reply By: Member - Charlie M (SA) - Friday, Dec 03, 2010 at 21:08
These mirror style are great
mine are vision plus, had them for 8 or 9 years. window glass needs some care ot is gets scratched. I tighten my strap up with a pair of pliers to get them tight, then they dont vibrate. Had them on pathfinder, jackaroo and prado 120
Chers
Charlie
437729
Reply By: Ozymacca - Saturday, Dec 04, 2010 at 06:00
Hi Andrew,
I have a set of Aussie truck mirrors. I have not had any problems with them. I also have a set of Elephant ears(Clearview Mirrors) for extended trips. With the Aussie Truck mirrors I did a little mod to them. Click on link below to my photo stream.
Macca's Photo's
Cheers Macca
437759
Reply By: Member - Dalb (SA) - Saturday, Dec 04, 2010 at 08:09
Hi Andrew
I have a LC100 and use the Aussie Truck mirrors. I looked at all the others, except the Clearview ones, and went for the AT's.
The AT's hold firm and give great vision, but like everything else, there are some negatives and that is when travelling on dirt roads - the presence of dirt will scratch the windows if you regularly wind them up and down when there is gravelly dirt in the window tracks.
Also, on dirt roads, wherever the strap or its rubber pad touches the side of the door, dirt will eventually get behind and sandpaper your duco or side strip. I fixed this problem by placing a clear plastic strip on the door and this works OK.
You can buy packs of the clear plastic sheets from auto shops, just cut to size and stick on with
water. The plastic sheet is similar to the plastic sheets you can buy to protect the screen of a mobile phone.
Cheers, Dalb
437764
