Tuesday, Jul 06, 2010 at 15:07
I would suggest that you do a few measurements before and after hooking up.
If you have 300kg on the ball your front guards will have risen about 50mm at least.
Pumping up your polyairs wont alter that as they only lift what is above them.
The best description of WDH effect I have read is
Think of a wheelbarrow Push down on the handles till the wheel comes off the ground Imagine the legs as your rear
suspension.
Put the legs on a large block of wood or something.
Apply the same amount of weight to the handles.
Does the barrow level No because it cant. It only lifts the point holding the load higher.
However straighten out the joint between the van and the car and it then pushes the front down a bit pivoting on the rear
suspension.
Thats what a WDH does and Polyairs cant.
There is a slight resistance from front springs and engine weight but the same applies.
A guy where I used to live towed a big Coromal with a Patrol and no WDH I would hate to meet him on a wet road as from a 100 metres away you could see right under the car the front was so high.
He didnt need a WDH "it handled fine" Used to put skinny split rim wheels on it as
well.. No wonder there is accidents.
693649
