Heart Surgery for my 80
Submitted: Sunday, Jun 27, 2010 at 23:08
Member - Wayne B (NSW)
Went to the salvage auctions Thursday and picked up a rolled HJ80 1HD-T. Not cheep $4900 but at least I now have an Turbo Engine to replace the 1HZ plus all the spares I will ever Need. LOL
The 1HZ was good in the rough going but lacked pulling (As in Trailer) power.
So I am about to commence the Transplant are there anything I should be aware of in performing this procedure.
Wayne B
Reply By: Member - Stuart P (WA) - Sunday, Jun 27, 2010 at 23:48
most things should fit straight together. maybe an exhaust change
422324
Reply By: Hairs & Fysh - Monday, Jun 28, 2010 at 06:35
Hi Wayne,
Good to hear that you have found a motor for your old girl.
Now the fun begins
At lest you'll have all the bits at the ready to do the swap. Have your Big Ends done while shes out, How many k's on her?
You'll have to do a blog of the transplant and progress.
Keep us updated.
422333
Follow Up By: Member - Wayne B (NSW) - Monday, Jun 28, 2010 at 17:53
Yes I may do a blog just for fun.
Wayne B
692764
Follow Up By: Member - Wayne B (NSW) - Monday, Jul 19, 2010 at 23:01
Took your advice and had a look at he BE Bearings. They have been done before 20thou undersized bearings.
Bearings looked ok except for a few scratches. Ordered a new set of ACLs for it.
Engine is as clean as a whistle inside no sludge at all.
May have to use my old Gearbox ( Center Diff) wiring harness, different connections on the 151F gearbox. All other connections are already included in the original wiring harness so should be simple swap.
Tell you what the engine is bloody heavy I had to would a overhead gantry as my normal engine lifter would not look at it.
Wayne
695014
Reply By: Member - Nick (TAS) - Monday, Jun 28, 2010 at 08:00
Id be checking the engine over very carefully.The trouble with buying a rolled vehicle wreck is you dont know how long (if at all) the vehicle was left running upside down being starved of oil.I hope you got a good one.
And definately
check your big end bearings.I'd replace them anyway.
422339
Follow Up By: Member - Wayne B (NSW) - Monday, Jun 28, 2010 at 17:59
Started the engine Sunday runs like a kitten. Very quite compared to the old 1HZ
Engine has 360,000km on it or at least that is what is on the Odo.
The vehicle has been looked after by the previous owners and everything looks to have been maintained correctly.
There are two stickers on the RHF door pillar that indicate the vehicle has had 2 recalls done. The last one being 2000 which I think was the bearing
check.
Anyone know the code for the bearing recall.
I will drop the sump and
check them anyway.
Wayne B
692766
Follow Up By: Hairs & Fysh - Tuesday, Jun 29, 2010 at 07:22
Hi Wayne,
There was a thread ages ago in Lcool that had most of the recall codes,
Recall sticker codes on an 80 series
There was another thread about it as
well, can't find it atm.
Hope this Helps Wayne.
692808
Reply By: Member - Old Girl (QLD) - Monday, Jun 28, 2010 at 09:54
Waaayne My shopping list includes!!!
Just kidding but if you don't need the bottom half of the dash mm me.
What you have done is probably cheaper. We rebuilt ours 12k then after complaining for 12 months it isn't right (using oil ,crap power) the head came off to find the stems full of oil. The new??? seals went hard. Used a lt of oil every second tank of fuel. Then when all went
well, couldn't fault it the metal hose off the turbo split which resulted in oil every where again grrrr . Thank god the lot was under warranty. We were travelling all around the country side while it was sick including two 4x4 parks (stuff I will only walk up, I wont go up in the car, he is mad) and from the Cape to
Byfield. Try do that with any other brand or newer vintage. NOT
Ha we are going back to where it all started The Strez Track, the turbo intake valve broke open. For a shella I know more about the 1HZ T than I need to.
Cheers.
Sharon
422353
Follow Up By: Member - Wayne B (NSW) - Monday, Jun 28, 2010 at 18:03
Is that the bid with the Bonnet and fuel flap handles. If it is then let me know.
Now let me see I payed $4900 for the vehicle so I could sell the lower dash to you for say mmmmm $4850. Sounds about right. LOL.
Just kidding :-) anyway let me know if that is the part you are looking for.
Wayne B
692767
Reply By: sweetwill - Monday, Jun 28, 2010 at 10:08
hi Wayn b.
just a thought, will you need to consult with an engineer before you start, to iron out the legality's of the change over, cheers for now Bill.
422355
Follow Up By: Member - Wayne B (NSW) - Monday, Jun 28, 2010 at 17:52
Yep Done that. Its only a paper issue. No engineering required.
Wayne
692763
