Which is the best all around 4x4 tyre?
Submitted: Tuesday, Apr 20, 2010 at 18:05
JohnnyTasman
Got tyre troubles and want soem
feedback on the best all around 4x4 tyre.
I've got a Land Rover Freelander 2 (2009). Use it 90% road, 10% sand.
Reply By: GoneTroppo Member (FNQ) - Tuesday, Apr 20, 2010 at 18:08
Think you'll find they're all round.
:-) couldn't help myself
413677
Follow Up By: Maîneÿ . . .- Tuesday, Apr 20, 2010 at 19:26
The black ones are the best, most people use them, so they must be ?
as above, couldn't help myself either :)
Unsigned
683795
Follow Up By: Member - Doug T (NT) - Tuesday, Apr 20, 2010 at 20:52
GoneTroppo
Walk due East for 8Klms will ya.
683817
Follow Up By: landed eagle - Wednesday, Apr 21, 2010 at 12:25
Mine are made of rubber.
683914
Reply By: cliffy46 - Tuesday, Apr 20, 2010 at 18:22
hi my wife and i have travelled all over Aussie in a land rover discovery, we had cooper st, they are great go any were and no flat tyres, and still got over 80,000kms out of them,sand, rocks anything great tyre.
413679
Follow Up By: Mick O - Tuesday, Apr 20, 2010 at 18:34
I'd second the Cooper ST for a general purpose track and dirt road tyre. At 90/10 with nothing technical, you might even be better with the Cooper A/T.
Cheers Mick
683785
Follow Up By: Injected - Wednesday, Apr 21, 2010 at 08:42
I wont touch the Cooper ATR again. Deadly in the rain!. Unless Coopers come up with a miracle, apparently there is a new version called the LTZ or ATZ which is meant to be better in the wet??.
683882
Reply By: Muntoo - Tuesday, Apr 20, 2010 at 18:28
Bridgestone Dueller
413680
Follow Up By: DesF - Tuesday, Apr 20, 2010 at 19:06
Have to agree ,I have the older 604's ( 2nd set) and they have been trouble free. have done interstate trips with the van , up thru the Centre, Finke ,
Birdsville, Ccamerons corner etc , have not been in much mud.
very happy and they are only $180.00 for 9R x15.
Cheers Des.
683791
Reply By: Member - Geoff H (QLD) - Tuesday, Apr 20, 2010 at 18:58
Bridgestone 693/694.
413687
Follow Up By: Injected - Wednesday, Apr 21, 2010 at 08:39
Second vote for the bridgestone 694.
683881
Reply By: Robin Miller - Tuesday, Apr 20, 2010 at 19:06
I think the BFG AT is a clear all round 4wd tyre winner Johnny but in your case of on road with a bit of sand it is not the best and I'd go with the 693/4 as others have suggested.
There are good reasons why tyres like BFG AT have so many copies.
413688
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, Apr 20, 2010 at 20:02
Hi Robin. I have the BFG AT's. What happens when you use them in sand. Something to do with the 3 ply walls not ballooning enough? Thanks for any info. Bob.
683801
Follow Up By: Robin Miller - Tuesday, Apr 20, 2010 at 20:16
Hi Toyo
The issue is the sharp edges which tend to cut into sand a little more than say 693's.
The BFG AT excel in the gravel roads that form much of the outback which makes for safter driving.
Actually , even the last issue of 4wd action concludes this from whats appears to be a comprehensive
test.
An additional point I would make is noise level - measured on a meter BFG AT are as noisy as equivalent tyres however the characteristics of the noise is such that its even distributed such that there is no detectable pattern and hence they are in effect quieter across a wider range of surfaces.
Both General and silverstone make knock off copies now.
683804
Follow Up By: Member - Toyocrusa (NSW) - Tuesday, Apr 20, 2010 at 20:32
Thanks Robin. A few good things learnt. Bob
683808
Reply By: Wilko - Tuesday, Apr 20, 2010 at 19:16
John,
I like my BFG A/T's
Best by far, daylight 2nd
cheers Wilko
413689
Reply By: Hairs & Fysh - Tuesday, Apr 20, 2010 at 19:21
Hi Johnny,
I've had my Desert Duelers 604V 31x10.5x15 for over five years now and they've done over 65 000k's, probably got another 10 000k's left in them.
I do about the same as you, 90% road, 10% sand/off road. On road I run them at 44psi, a little to hard sometimes, but hey life's a compromise. I do rotate them every 5000k's. I've been very happy with performance, towing my work trailer, the horse float and our camper. I would love to get another set.
413690
Reply By: Mudripper - Tuesday, Apr 20, 2010 at 19:45
Bridgestone Dueler 694.
413693
Reply By: long haired nomad - Tuesday, Apr 20, 2010 at 20:20
Bridgestone A/T 693, ive been using them for the past 15 years on my hilux's and have gotten just over 130,000km from each set with only 1
puncture in that time.
413701
Follow Up By: Bazooka - Tuesday, Apr 20, 2010 at 21:41
GHi Nomad
Pray tell where does one buy such a fabulous beast? Not ready for new tyres yet but anything over 80Ks is incredible 'mileage' for an all rounder.
683830
Follow Up By: long haired nomad - Wednesday, Apr 21, 2010 at 04:27
Gday Bazooka, Other people on here are also getting over 100,00km from their tyres. The hilux is pretty light and most of those k's are highway km's. Maybe its the way you drive that contributes to your excessive tyre wear, i dont know but thats how many k's i get out of them.
683857
Follow Up By: Bazooka - Wednesday, Apr 21, 2010 at 11:33
Are yours made in the USA?
683905
Follow Up By: long haired nomad - Wednesday, Apr 21, 2010 at 19:09
There are made in Japan. I was told the Australian made ones dont last aslong.
683980
Reply By: Shaker - Tuesday, Apr 20, 2010 at 20:21
I can't tell you best, but from my own experience I can tell you the worst ... Cooper ST Light Truck construction.
413702
Reply By: Best Off Road - Tuesday, Apr 20, 2010 at 20:26
Johnny,
90% road and 10% sand, I'd suggest any old AT or HT will serve you well. In sand you need to deflate to bet a bigger footprint to "float" over the sand.
A chunky tread will dig in rather than float. Then churn its way down into the sand, throw more sand out and bog you deeper.
Just my experience.
Regards,
Jim.
413704
Reply By: chris_s - Tuesday, Apr 20, 2010 at 20:31
I love the BFG A/T.
I got close to 100,000Km and they did the CSR (great in sand, most vehicles got bogged, we only managed this once due to driver error). The 3 ply sidewall is a great bonus. The others on the trip had staked sidewalls. The BFGs had slight chipping on the Gibb & Major
Mitchell roads, but the Cooper A/T and STT had major sidewall splitting. More travel into the
Pilbara and they handled the gravel without hassle. Their last trip was up to
Cape York and return. They handle the corrugations on all the above trips without fear - just drop the pressure a bit and you will be laughing!!
413706
Follow Up By: Member - Dunworkin (WA) - Tuesday, Apr 20, 2010 at 21:47
Second that chris_s, we got 110.000 out of our first set of BFG/AT which included the CSR as well, our second set are going well also, have done
Birdsville, and all through out there, Great Central,
Gibb River etc and still going. A bit more expensive though.
D
683834
Reply By:- Tuesday, Apr 20, 2010 at 20:48
Hi Johnny,
Bridgestone 694 for your needs as an all rounder
Ev
413709
Follow Up By: Member - Gary J (NSW) - Wednesday, Apr 21, 2010 at 09:18
Another vote for Bridgestone 694. We have LT on the Navara, good "all round"
683884
Reply By: Secret Mens Business - Tuesday, Apr 20, 2010 at 20:53
Pirelli Scorpion ATR streets ahead of the competition. Several of the 4WD mags have also reported this now. The Cooper's aren't very good on the bitchumen and certainly not in the wet, I replaced my Coopers with these new Pirelli's , awesome.
IMO BFG AT's are an older design tyre and better suited to dirt and gravel, there are so many better choices for a 90-10% combination. IMHO....
413710
Reply By: mikehzz - Tuesday, Apr 20, 2010 at 22:28
I've got a Freelander 2 and it's been all over including into the Simpson. I've got Geolander AT/S. on it and they are really good. Pretty pricey at $320 a pop for the 17"s though.
Mike
413720
Follow Up By: Member - Tony (ACT) - Wednesday, Apr 21, 2010 at 06:44
I will 2nd the Geolander AT/S as a great allrounder. Been using them for the last three changes, they wear well, average 70,000k in all conditions.
683861
Follow Up By: TerraFirma - Wednesday, Apr 21, 2010 at 11:32
Geolander would also be a great selection if you weren't buying the Pirelli Scorpion ATR.
683904
Reply By: uneekwahn - Wednesday, Apr 21, 2010 at 00:01
Hi JohnnyTasman,
My wife and I purchased 6 Mickey Thompson (Dick Cepek) FC-II tyres to use during our 2 month honeymoon to the
Kimberley region.
That was in July/Aug/Sept 2007 and I still have not used either of the two spares purchased for the trip. The tyres have done approximately 35-40,000k since 2007 and the only issue I have had is one lug come off due to not airing down on a local 4wd track.
I have found them to be great tyres for both on and off-road and would highly recommend them.
Hope this helps,
Jason.
413729
Follow Up By: Mick O - Wednesday, Apr 21, 2010 at 21:20
I've run a set of the FC2's as well. Good all purpose tyre with plenty of tread. Not good "off track" due to the thin sidewalls but then so are the Cooper ST's BFG or anything less than a Toyo. Then again, if you not going bush bashing, they'd be fine.
684015
Reply By: cobber - Wednesday, Apr 21, 2010 at 14:04
Go with the Bridgestone Dueler the 963's they are made in Australia, they were recommended to me by the Guy who runs "
Top End Tours" so he should know, I did the
Great Central Road,
Gibb River Road, with out any problems at all, Tyres are a bit like Girls we blokes see them all differently other wise we would all be after the same one......lol
413764
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 21, 2010 at 19:39
Bridgestone have closed the
Adelaide plant, so aussie made bridgestones are a thing of the past.
683993
Reply By: Member - Syd R (QLD) - Wednesday, Apr 21, 2010 at 14:07
BFG the only way to go.
413765
Reply By: Tonyfish#58 - Wednesday, Apr 21, 2010 at 15:49
Maxxi Range - Bravo
The above I am having a good run with
You asked the tyre question, do you have enough to choose from :-)
413782
