Alloy Tray V Timber & Steel.
Submitted: Friday, Nov 20, 2009 at 14:52
ThreadID: 73879 Views:10570 Replies:8 FollowUps:0
Buying a cab chassis & I am undecided whether to get an alloy tray, to save the weight, or a steel & timber one, to get strength. From memory there is 80 or 90 kg difference in weight.
How much corrugation will it take to wreck a MMM heavy duty alloy tray.
Anybody had experience with these.
Reply By: Member - DW (NSW) - Friday, Nov 20, 2009 at 15:55
I have a Triple M alloy tray which has traveled over 90,000 kms. The last 45,000 it has had a WOW canopy attached to it.
This tray has traveled well over 35,000 kms on all sorts of roads including the Gibb River Road, Oodnadatta Track, Plenty Highway and numerous other 'exciting' roads.
I cannot fault it. I have also had full steel and steel and timber trays. Being on the coast the Triple M stands the salty atmosphere better. I will most likely keep it for the next vehicle as it is set up the way I want it now.
Hope that helps.
DW
AnswerID: 391919
Reply By: wicket - Friday, Nov 20, 2009 at 16:08
Depends on what you intend to carry with it. If you are likely to be close to gvm then the alloy is the way to go as you need all the leeway you can get, otherwise it comes down to personal prefence.
I have an alloy tray with a slide on which tips the scales at gvm and have done about 40k over plenty of less than perfect dirt roads eg strzekecki, oodnadatta birdsville and lots of flinders ranges roads so far with no ill effects.
AnswerID: 391923
Reply By: Butch58 - Friday, Nov 20, 2009 at 16:41
I have had both types of trays, would now only ever buy an all steel . Alloy trays rattle to bits , I haven't seen one yet that will stand up if used for hard work in harsh conditions.
If you are only using it socially without carrying heavy loads you may be ok.
Some of the new high tensile steel trays would not be as heavy as the older style ones, they might be worth a look,cheers Butch
AnswerID: 391925
Reply By: Member - colin M (NSW) - Friday, Nov 20, 2009 at 19:10
If you are going to use a tray top camper I would suggest steel is best based on my experience with 2 different tray tops, you need something substantial to attch them safely but extra weight is a factor if your near the limit.
AnswerID: 391938
Reply By: Wilk0 - Friday, Nov 20, 2009 at 21:52
Hi Fatso,
The most common tray in the country(not near the coast) is a steel tray IMHO the take a lot of punishment and can carry heavy weights regularly, you rarely see an aluminium one.
Its the other way round near the coast prob to stop the rust.
I believe its horses for courses.
In my town we have a pump from which you can get free water (Bore water) from to water the lawns.
I had an alloy tray supplied with my rodeo when I 1st got it. The tank I have on the tray is 1000lts or approx 1 tonne. It struggled after a few months of carting 6-7 loads a day (bolt hole elongated etc).
I changed it to a steel one and its been on it since. There isnt any real damage to it so far, I spray a little diesel on it every week or so to stop the rust.
The only down side is that legally I can only carry 950kg as the heavier steel tray would put me over with 1000kg on the back.
Cheers Wilko
AnswerID: 391951
Reply By: Fatso - Saturday, Nov 21, 2009 at 14:44
Thanks everyone for their opinions. It has helped
AnswerID: 391988
Reply By: Member - Phil G (SA) - Saturday, Nov 21, 2009 at 16:55
Peter,
My only experience is with alloy - I prefer to keep the weight down.
I'd guess the strength would vary a lot between manufacturers.Mine is built by a local company and I haven't had a problem - over the past 5 years have done most of the badly corrugated tracks through the deserts. I did change the bolts holding it down with 12mm HT bolts and nyloc nuts.
A friend's was a "multifit" type and the steel brackets holding the alloy tray cracked badly on a gunbarrel trip. We welded some new stronger footings and his has been fine since.
phil
AnswerID: 392016
Reply By: Member - xrdave (QLD) - Sunday, Nov 22, 2009 at 18:26
one word steel
AnswerID: 392215
