Tuesday, Jun 16, 2009 at 19:03
Hi Syd
If you have had experience in soft sand, it will not be a problem at all. Just remember that when you hit the
Finke River bed, drop your tyre pressure, and your van even lower. If the going is very soft try about 14psi in your vehicle and 10 - 12psi in the van. Lots of great spots along the way. Do not be fooled by the sign - 65 kilometres to
Hermannsburg. Depending on conditions, it will take between 6 to 8 hours to drive. If in doubt, get some Maxtrax. If you are running Ozi and need a track file, let me know and will email it to you. It is not signposted from the Ernest Giles Highway, so it is a little tricky if you do not where to make the correct turn off.
637694
