Friday, Jan 09, 2009 at 15:20
Have received this email in an attempt to see who has the 'responsibility' of upholding any 'law' on the dangerous idea of travelling with gas operating in a *moving* vehicle.
Thank you for your email below to roadsafety@transport.qld.gov.au on the above issue.
We have been advised that this issue is not the responsibility of QT, however falls under the jurisdiction of the Department of Mines and Energy, in particular, the Gas and Petroleum Inspectorate.
Therefore, may we suggest that you visit the Department of Mines and Energy website (doclink attached below) and follow the links to send them your enquiry.
http://www.dme.qld.gov.au/home.cfm
LT&S DOCentral
(Land Transport and Safety)
This is something else you can read @ the govt website:
27/11/07
Fridge dangers spark safety warning
Campers and holiday makers are being warned of the dangers of the incorrect use of portable gas fridges in the lead up to the busy summer holiday season.
Mines and Energy Minister Geoff
Wilson said portable gas fridges could be dangerous if they were used in confined spaces.
"Tents, vehicles and caravans with no ventilation are danger zones for portable gas fridges," Mr
Wilson said.
Minister
Wilson said the Petroleum and Gas Inspectorate had issued a Safety Alert urging campers and holidaymakers to read the warning signs on appliances before use.
"The warning applies to portable gas refrigerators, as
well as gas barbecues and portable gas heaters," he said.
The Petroleum and Gas Inspectorate has issued a direction that requires suppliers to fit additional safety warnings with greater visibility on portable gas fridges.
"The fridges are very convenient but people should be more aware of the risks of operating them outside their intended use or specifications," Mr
Wilson said.
"Many portable fridge units use three-way operating systems (12 volt, 240 volt and LPG) and look like eskies.
"The point of difference is that
portable fridges are not intended for use in confined spaces because they can generate high concentrations of carbon monoxide gas.
"The gas combustion-driven refrigeration process can use up the oxygen in a confined space leading to lethal quantities of carbon monoxide in that space.
"Carbon monoxide is colourless, odourless and can result in death when inhaled in relatively small concentrations."
A man died earlier this year from lethal gas poisoning. He was found dead in his vehicle near
Tully in north Queensland. A forensic report established the cause of death as carbon monoxide poisoning.
"The report found his death may have been caused by a portable gas fridge inside his vehicle.
"Tests are currently being carried out to determine the rate of carbon monoxide generation by this type of portable fridge.
"In the lead up to the summer holiday season, people need to be more aware of the limitations and risks associated with gas appliances to avoid further tragedies."
Mainey . . .
343428
Follow Up By: Member - Matt & Caz H (QLD) - Friday, Jan 09, 2009 at 17:32
Hi Mainey,
thanks for the information.
Matt,Caz & Kids (Matt has finally hooked up 12V Yay!!!!!)
611286
