Magellan crossover
Submitted: Wednesday, Oct 15, 2008 at 17:17
gary
Hello all, had to laugh even thou not funny.
Rang Next Destination today to complain about my crossover gps again [already been replaced once]. After a 9000klm trip to the Gulf and back it was nearly pitched out the window, it very rarely even showed us on the road always 100mtrs or so left or right.
On main highway running it would totally calculate incorrectly and tell you that the destination had arrived, 100klm short and in the middle of nowhere.
I was told today to return the unit again and I asked honestly if they were having problems to which I was told a few.
But the funniest thing was I was told after having my gripe that it was a mapping problem to which I asked who put the maps in ?
It certainly was not me
Regards Gary
Reply By: Member - Kiwi Kia - Wednesday, Oct 15, 2008 at 17:29
A lot of roads are NOT drawn in the right position on maps. Maps are made almost) freehand. There are also technical reasons why gps are more accurate then the normal topo maps. I have a Garmin Nuvi and on a recent trip to the Cape I was also shown as not being on the road.
330032
Follow Up By: Member - Doug T (NT) - Wednesday, Oct 15, 2008 at 19:10
Kiwi Kia
I have always used Garmins No 6 was a Nuvi 660, the latest is the 760, every where I go they are spot on , and the reason you were not shown as being on the road on the cape was probably you were on the new road , and your unit was not updated , thats my guess ,
And as for your statement maps are made freehand would have to get the trophy as the silly remark of the month.
597517
Follow Up By: The Explorer - Wednesday, Oct 15, 2008 at 19:25
Hello, some Garmins actually have a "Lock on Road function" to remove (hide?) the problem of either the GPS or the map being out (or both!). Garmin maps/gps units are not perfect either and they obviously realise it.
597525
Follow Up By: Member - Kiwi Kia - Wednesday, Oct 15, 2008 at 19:47
Doug, there was a bracket missing before the word 'almost'.
My statement is not silly it is fact ! I will try and keep this simple so that you can understand. The plotting on those older maps would have been done by a human being using a machine that uses a spot of light and tracing it along features on a stereo viewfinder over two aerial photographs. I have watched it being done. The base maps in some cases are obviously rather old. Your remark about the silly statement of the month just shows that you have no knowledge of map making.
I stated a fact about my Garmin NUVI, it is only six months old and uses the latest available map set. I have found many instances where the Garmin plot does not correspond to the road. Try heading south from
Winton to
Opalton and the Garmin will announce your arrival 5 km out of
Winton - what happened to the other 90 odd km still to run ? I have just completed over 15,000 km in the last three months and found many
places where the gps track was off set from map road (the gps position will be correct). Also, as I previously said there are technical reasons in the (mathematical algorithms) as to why a gps will show a different road plot from the projection used to make a topo map. There is a new map making (mathematical projection) now being introduced but the present map sets will not be all converted for many years.
597528
Follow Up By: Member - Doug T (NT) - Wednesday, Oct 15, 2008 at 20:04
Kiwi Kia
That's ok, your the map expert , but you didn't explain too
well so I immediately conjured up the vision of some dude sitting down at a desk all day drawing maps with a bloody biro, ....
well you did say ....by hand .
And so you might have travelled 15000 Ks in 3 months, I used to do that too 12 months every year and the only two spots I can recall where it was off was just North of
Bindoon WA and the new road bypass for Churchill's Head NT , both of which were rectified on CN 2008, I'm now using CN 2009 and that's even better.
597531
Follow Up By: Member - Doug T (NT) - Wednesday, Oct 15, 2008 at 20:10
Yes some units do have road lock, ie the Quest, the Nuvi 760 does not, it's so good it don't need it .
597533
Follow Up By: Member - Kiwi Kia - Wednesday, Oct 15, 2008 at 20:18
Doug, Do you know when CN2009 come out ? I don't have my unit handy at the moment but I purchased it in April.
597534
Follow Up By: The Explorer - Wednesday, Oct 15, 2008 at 20:47
Doug - they possibly have "lock on road" permanently on if its not available as a manual function. Anyway the 760 is no longer top of the tree in the Garmin in car navigator range - when are you getting one of these?
Nuvi 5000
597544
Follow Up By: Member - Zig (WA) - Wednesday, Oct 15, 2008 at 20:47
My Nuvi 760 is also often "off the" road. Some roads doesn't even exist on the "Where Is" mapping.
Did a trip with a survey technician in a government Nissan with a Nuvi 760 a few weeks ago. Their GPS was "off the road" by
miles in some parts of the SW WA.
597545
Follow Up By: The Explorer - Wednesday, Oct 15, 2008 at 21:00
Yes - I have CityNav and it is far from perfect in out of town areas but that goes for all mapping products aimed at that market. It is one reason why people go for units such as the Hema Navigator where you can use both Whereis style mapping and voice nav (for main roads/cities/towns) and OziExplorer (out of town areas..plus it has wider range of applications).
597548
Follow Up By: Member - Zig (WA) - Wednesday, Oct 15, 2008 at 21:34
I use the Shonky maps when I'm out bush/out of town. They are good but not perfect. I will probably buy the OzTopo from GPSOZ. I would already have bought them if the v2.1 was ready prior to the NT latest trip.
Zig
597551
Follow Up By: Member - Doug T (NT) - Thursday, Oct 16, 2008 at 17:19
Kiwi Kia
City Navigator 2009 - Garmin has released City Navigator 2009 updates for the majority of GPS units. For those that own IQue's, StreetPilot III's, Quest's and non 'X' model handhelds will have to wait another week or two. New in 2009, traffic support, update lane information, updated rural road classification, more speed zone data. The update will be available for download form Garmin's website,
I didn't go for the update, I opted for the full version on CD so I can have it on the PC as
well .
597668
Follow Up By: Member - Kiwi Kia - Thursday, Oct 16, 2008 at 18:36
Thanks Doug, I take it that the CN2009 has only just been released then ?
597685
Reply By: Member - Doug T (NT) - Wednesday, Oct 15, 2008 at 19:05
One day you people will find out about Garmin, until then just keep wasting Money.
You would be better off with this Navman pictured below
Image Could Not Be Found
330038
Reply By: Skippy In The GU - Wednesday, Oct 15, 2008 at 22:31
Hi gary, I was over the border just 2 weeks ago and we drove from
Dartmoor to
Casterton and back and I found on both my GPSr Nuvi 760 Running City Nav 2009NT and Colorado 300 also running City Nav 2009NT they went off the road quite a few times , I think Mapsource forgot to draw a squiggly line in some
places , I still believe the old paper maps are still more correct than the Mapsource products
Here are some screen shots Image Could Not Be FoundImage Could Not Be FoundImage Could Not Be Found
If anyone whats to check the location it is S37 40.247 E141 18.790
The Ozi map used was from DNRE map # T7122-1-3
and as you can see the 2
track logs were from Nuvi760 and Colorado 300
I calculated the Mapsource road was up to 147 metres off in this location.
Paper map rules OK !!!!! :-)
330086
Follow Up By: The Explorer - Wednesday, Oct 15, 2008 at 22:42
Hello - You can use scans of paper maps with OziExplorer.....and get the best of both worlds. Ozi Ozi Ozi Oi Oi Oi!!!
597566
Reply By: Member - AJB (VIC) - Thursday, Oct 16, 2008 at 17:32
What version of Discover Aus or Topo is on the SD card? The later the better as with all mapping software. Anyway your unit said you were off the road when you knew you weren't. Your unit said you had arrived when you knew you hadn't so you weren't lost!
GPS/Navigators are big boys toys that we get because we have mastered the CD player anyway. The first part of navigation is a good sense of direction. The second part is to be able to determine which way is North or South. The third part is the ability to read a map and know where you are on the map. Then maybe GPS systems come in at 4th place. The accuracy of the GPS system is pretty good considering we are mobile in a vehicle, the satilites are orbiting the earth which is spinning on its axis and orbiting the sun which is possibly doing its own orbit of something.
By the way I have a Crossover and have no problems except for some stupid routes through the City but I only knew they were stupid because I knew where I was going. The free (while they last) upgrades are the way to allieviate these problems.
330173
Follow Up By: Member - Kiwi Kia - Thursday, Oct 16, 2008 at 18:50
The gps is right it is the maps that are slightly off.
The mathematics required to plot a flat map from the earth's curved surface is rather tricky so little errors occur everywhere. The paper map gives you a good pictorial overview of where things are in relation to each other on the earth's surface but the gps gives you an exact point.
597691
Follow Up By: Skippy In The GU - Thursday, Oct 16, 2008 at 21:52
Hi Kiwi Kia do you have a track log and the coords where it was out and can check on the Mapsource and Raster maps , as you can see on my screen shots above Mapsource are out on that road in many
places
597775
Follow Up By: Member - Kiwi Kia - Friday, Oct 17, 2008 at 19:20
Hi Skippy, Sorry I did not keep
track logs as we were on a 'real road' at all times. I note that the gps 'road' and the real road did not match almost all the way up the peninsula to
Cape York but the worst spot was around the turn off to
Weipa (several km out).
597950
