Punyelroo Cave
Submitted: Wednesday, Oct 15, 2008 at 10:51
Member - Craig D (SA)
Would anyone have the exact location or GPS co-ords for Punyelroo
Cave near Swan Reach in SA?
Reply By: Squizzy - Wednesday, Oct 15, 2008 at 14:54
Not sure about the
cave, but Punyelroo is
34 36 166 S
139 36 061 E
Not sure if this helps,
Geoff
330020
Follow Up By: Member - Craig D (SA) - Wednesday, Oct 15, 2008 at 15:07
Thanks mate, it's the actual
cave I'm after.
597484
Follow Up By: Squizzy - Thursday, Oct 16, 2008 at 07:08
You will find the
cave about 6km's south of Punyelroo.
Geoff.
597591
Reply By: Member - Craig D (SA) - Thursday, Oct 16, 2008 at 08:07
Thanks Geoff - do you know if it's
sign posted?
330105
Follow Up By: Squizzy - Thursday, Oct 16, 2008 at 09:52
I think so, but not positive.
Ask a local and you will get the correct info when in the area.
597612
Reply By: Louie the fly (SA) - Thursday, Oct 16, 2008 at 21:34
Craig, coords are S34 35 18.7, E139 36 36.3. Every time we drive past the channel we say "we gotta take the kids to the cave". But we don't.
To get to the
cave you can go two ways. 1st is by river. You go in through the short channel opposite the northern end of the caravan
park. Then go sort of northeast across
the lagoon (whats left of it). Last time I was there
the entrance was hard to get to as it was overgrown at river level. But you can wade your way thru the scrub. Its easy to see. You will probably need a tinnie to get there, although, with the current river level you can probably walk across. Its approx a k wide. Once there its 10 or so metres above
water level to
the entrance.
2nd way is via the main road. Go to the corner of the Nildottie road where the golf course is and
park your car on the side track. There is a
pump shed up there. There is a track leading down the
cliff and eventually to the
cave.
Make sure you take a rope and an extra torch. There is a
cavern with a spiral entrance. You've got to go in there and then there is a small pool to swim thru.
Haven't been there for 10 or so years but its very interesting. check out the
big tree stump inside the
cave. Makes you wonder how it got there.
Happy spielientologying (???)
Louie.
330228
Follow Up By: Member - Craig D (SA) - Friday, Oct 17, 2008 at 08:16
Thanks Louie! Exactly what I was after, and thanks for
the tip on the rope.
Cheers mate.
597839
Follow Up By: Louie the fly (SA) - Friday, Oct 17, 2008 at 20:31
Where you heading in from? If by river you can
park your car just between Old Punyelroo and the South Punyelroo causeway and put your boat in at the public ramp. Then it's only about a K up river on the other side.
597967
