Rear windscreen protection
Submitted: Monday, Mar 31, 2008 at 18:04
ThreadID: 56121 Views:4305 Replies:14 FollowUps:11
We intend to travel around Australia in June towing a camper trailer. I am looking for a protection screen for the back window that when rocks bounce up and off the campertrailer and hit the back window it is protected. It would be made of a clear rubber or plastic material and stick on the window with suction caps. Does anybody know where I can get one for a Pathfinder or one size fits all model?????
Reply By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 18:07
I made my own with suction cups, about $60 for 2mm polycarbonate and about 80 cents each for the cups.. I will try to post a photo whan i get home 2nite. Michael
Patrol 4.2TDi 2003
Somewhere you want to explore ? There is no time like the present.
AnswerID: 295821
Follow Up By: Member - JohnR (Vic)&Kath - Monday, Mar 31, 2008 at 19:12
That doesn't sound too bad Michael, I was talked into getting 3mm by the local glass dealer. Would like to know what you may use to hold the polycarbonate in place please. Do you use velcro?
FollowupID: 561856
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 19:39
Gday John, No not velcro, suction cups, It really depends on the type of cup you use, i drilled 11mm holes from memory, just big enough to push the back of the cup through and the ones i purchased have an undercut and i push a stainless steel "c" circlip into the front of the poly carb.. $70 total.. GU both doors.. Michael
Patrol 4.2TDi 2003
FollowupID: 561862
Follow Up By: Oldman - Monday, Mar 31, 2008 at 19:46
Michael,
Luv to see pics
Did you just use the clear suction cups
How many?
Richard
FollowupID: 561866
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 20:02
My protection,,, i always use it!! Always use protection!!!Image Could Not Be FoundImage Could Not Be Found
Patrol 4.2TDi 2003
FollowupID: 561867
Reply By: Oldman - Monday, Mar 31, 2008 at 18:51
I have been looking into this as well.
I am looking at a product from Altrex ( www.altrex.com.au)
I have no idea how good they are but they responded to a query the next day - better than most so worth a look.
Apparently Autopro stock it ($130)
Prior/still considering the suction cup idea but am having trouble finding them or at least ones that will hold.
Richard
AnswerID: 295829
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 20:07
Richard, I dont know where you are but i bought mine from a place in Revesby NSW, Gee, cant think of their name, They sell craft glass bits and pieces, they use them to stick glass things to house windows, so are pretty good.., i just take the metal clip that comes with them and replace with a 7mm s/s circlip... Perrrrfect.. Michael
Patrol 4.2TDi 2003
FollowupID: 561868
Follow Up By: Oldman - Monday, Mar 31, 2008 at 20:14
Michael
I am in Canberra and have been looking around for them.
I have not tried the glass companies though - I will give them ago,
Many thanks,
Richard
FollowupID: 561871
Follow Up By: Oldman - Monday, Mar 31, 2008 at 20:18
Michael,
forgot ask what size are the cups. I have been looking for 45-50 mm (which look like those)
I rang one place in SA a 4wd shop and they wanted $2-3, so I am keeping on looking.
Richard
FollowupID: 561874
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 20:30
Richard, i used abut 15 and for the wiper side, i placed the middle one on the glass and not through the poly carb so i can use the wiper. If you have a problem, let me know, i can source them and the clips for cost.. Easy.. Michael..
Patrol 4.2TDi 2003
FollowupID: 561876
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 20:31
Richard!! OOOppppS About 35mm dia.. Michael
Patrol 4.2TDi 2003
FollowupID: 561877
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 20:39
Richard, forgot to mention, if you make yourself or want to convert the velcro screen savers to suction cups you must use a negative rake twist drill or at the very least and blunt drill, to drill Polycarbonate, yes it may be bullet proof but it can grab and tear if you use a sharp drill.... test on an offcut if you make your own, Michael
Patrol 4.2TDi 2003
FollowupID: 561878
Reply By: Member - David.M.C - Monday, Mar 31, 2008 at 19:18
Gday Craig,
Check these out
Have one of these for the 100 series. Got it given to me. looks like a good product.
AnswerID: 295837
Follow Up By: Michael ( Moss Vale NSW) - Monday, Mar 31, 2008 at 19:43
Good product Craig but $200. Probably ok if you cant make yourself but i cant see the value. But having said that, It could cost up to a grand depending on you make and model to replace the back window.. Because it would be classed as a slow moving part, the price could be horendous.. GEE!!! sound cheap now!! Michael
Patrol 4.2TDi 2003
FollowupID: 561863
Reply By: The Geriatric Gypsies - Monday, Mar 31, 2008 at 19:46
goodday guys
i use 2 pieces of 1/2'' thick felt held on buy velcro works a treat
steve
AnswerID: 295841
Reply By: Member - Phillip S (WA) - Monday, Mar 31, 2008 at 19:56
Craig, I bought two of those square plastic mats (without the holes) from clark rubber with jigsaw edges so that you can join them up together plus about 500 mm of 50mm wide velcro sticky tape which I cut into squares, stuck one to the mat, one in each corner and the opposite to the rear windows( troopy has two)....I was able then to place or remove the protection as I needed to....when you apply them to the rear windows, the centre meshes up so you end up with full protection.....when I stop and need to get into the back, I only have to remove the left hand side one...I travelled the GCR to Alice then up to Kakadu...then across to GRR and back down the coast with no problems at all while towing a pioneer camper trailer....The mats measure 620x620x12mm
AnswerID: 295842
Reply By: Member - Mark E (VIC) - Monday, Mar 31, 2008 at 21:42
Craig,
It really is quite easy to make up your own from bits and pieces sourced at Bunnings or similar.
I found this thread by Moggs (who I think posts here as well??)
Home made rear window guard
I made some for the 105 and they work great. No problems...total cost about $100. Polycarbonate was about $70 and I needed 3 packets of the "dual lock fasteners" and they are $10 each (ouch) but worth it and half the price of commercial ones.
Mark
AnswerID: 295872
Reply By: Member - Rob S (NSW) - Monday, Mar 31, 2008 at 22:20
It is a good idear to try and prevent the stones from
hitting the back of your
4wd all together,use good
mud flaps or some other deflection device as well.
I had my rear window covered but the paint and body work
got a hammering and cracked tail lights even a rock
through the vinyl spare tyre cover.
I only ever made one mistake
AnswerID: 295881
Reply By: Harry - Monday, Mar 31, 2008 at 22:23
You could put a stone guard on the camper
AnswerID: 295883
Reply By: Member - Derek L (QLD) - Monday, Mar 31, 2008 at 22:23
Craig I just bought a rear window saver from Mike at Obies Outback Products. Easy to order $200 delivered up to Qld for me.http://www.obiesoutback.com.au
You could make one ourself if your rear window is flat but if not don't bother more hassel that its worth.
Good Luck Derek
AnswerID: 295884
Reply By: Member - Mal and Di (SA) - Monday, Mar 31, 2008 at 23:14
I cut some of that clear plastic you find on awnings on your patio.
It's quite heavy. Just taped it with grey gaffer tape and used eucalyptus oil to get rid of the marks afterward.
Went up to Birdsville and out to Lawn Hill and whilst I had plenty of stones ( including one as big as my fist) sitting on the spare tyre there was no damage done. Cost about 5 bucks!
M.
AnswerID: 295894
Reply By: Kazza055 - Monday, Mar 31, 2008 at 23:47
Bunnings sell flat laser lite sheeting same as you use for your patio etc but FLAT.
It is only about 1.5mm think but fitted with suction cups will be fine.
AnswerID: 295898
Reply By: Danny & June - Tuesday, Apr 01, 2008 at 00:32
Gday tried most window protectors.
Velcro gets wet and gooey not good glue.
Now use ALTREX hedlite protectors .Not wide enough stick on ,stay on no worrys at all.
Danny
Broken GQ
AnswerID: 295900
Reply By: landed eagle - Tuesday, Apr 01, 2008 at 06:00
You'll pick up the suction cups from any leadlight/stained glass shop. 38mm diameter.
AnswerID: 295904
Reply By: Member - Craig W (ACT) - Wednesday, Apr 02, 2008 at 14:04
Thanks all for the information , Fantastic repsonse
AnswerID: 296138
