Thursday, Mar 06, 2008 at 22:08
Hi Stevesub, Your reply made sense, and probably assisted with the original question.
What cant work out is the final couple of followups to your reply.
We are talking about the amount of current used per hour.
I prefer to talk in Amps, some talk in watts. Watts is easily converted to differing voltages, Amps is too, just one more calculation.
As we are all interested in amount of power used by our appliances every hour so we can work out our battery sizing, then by Mikes reckoning,
- watts TIMES hours (watthours) and
- watts DIVIDED BY hours (watt per hour)
in the context of the discussion, both are the same. If you multiply by 1 or divide by 1 you end up with the same result.
I dont however agree with the watt per hour being a division though, Words per minute is a good example. By the same reckoning, if you type longer you type less??? No matter which way you look at it, if you draw 1 watt per hour you are drawing 1 watt multipied by how many hours you draw this for.
Also, I am confused WRT the last follow up, The follow up states ""Watts per hour is a longer version of watthours- same thing although technically watthours is correct" then -
"If you can't understand that there is a fundamental difference between watts TIMES hours (watthours) and
- watts DIVIDED BY hours (watt per hour)"
First line says they are the same, finishing off with they are different
I'm with you Steve
Ray
556648
