Top Gear - sucked in ??
Submitted: Tuesday, Jan 08, 2008 at 00:07
ThreadID: 53232 Views:3940 Replies:8 FollowUps:19
The North Pole has a GPS co-ordinate of 90degrees North Latitude and no degrees longitude, not 0 .
I didn't pay much attention to the actual reading on the GPS they showed when they claimed to have reached the Pole, bu I know it wasn't 90/0. Was it 78/8? - for some reason that comes to mind.
So were we sucked in by a good show filmed a few miles from the depot?
Reply By: George - Tuesday, Jan 08, 2008 at 01:30
Magnetic North Pole: 82.7° N 114.4° W
AnswerID: 280411
Follow Up By: George - Tuesday, Jan 08, 2008 at 01:42
Just to clarify, the above coordinates are about 2 years old and since it is moving continuously they would be somewhat different at the time of the challenge
FollowupID: 544623
Follow Up By: stocky - Tuesday, Jan 08, 2008 at 06:48
cooooorect! :-)
FollowupID: 544631
Follow Up By: Pajman Pete (SA) - Tuesday, Jan 08, 2008 at 16:48
The boys must have been using old data - the GPS was showing somewhere around 78ºN 105ºW when they were at the "North Pole"
The pole is moving NW at around 40km a year so the lattitude and longitude would have been higher than George's figures.
Pete
Any mug can be uncomfortable out bush
FollowupID: 544698
Follow Up By: Pajman Pete (SA) - Tuesday, Jan 08, 2008 at 16:51
Stevo further down has clarified it - they were racing to the 1996 magnetic pole
FollowupID: 544700
Reply By: Snowy 3.0iTD - Tuesday, Jan 08, 2008 at 08:29
Either way I thought it was pretty cool (excuse the pun), and would be high on my Lotto win list of things to do, although I would add a set of ARB Air-Lockers to my vehicle something which may have helped the boys from Top Gear.
Snowy
AnswerID: 280419
Follow Up By: Stevo - Tuesday, Jan 08, 2008 at 08:44
On a couple of occasions you could actually hear an air compressor cut in and out momentarily, hence I'm sure air lockers were in use (even my blonde daughter exclaimed " they must have those locker thingys like yours,dad").
FollowupID: 544640
Follow Up By: Snowy 3.0iTD - Tuesday, Jan 08, 2008 at 08:49
Yeah, I just wondered when they got bogged on a couple of occasions, I only saw one front wheel spinning away with the other sitting there uesless.
FollowupID: 544642
Follow Up By: Gerhardp1 - Tuesday, Jan 08, 2008 at 09:07
I'm pretty sure they would have had rock crawler gears in the transfer as well, to turn those rather large tyres.
Some positive bead locks would installed next time as well.
Most of the running would have been with diff locks off, or there would be no steerage at all. So it's highly likely that they got stuck with locks off, and then getting them engaged would the problem.
FollowupID: 544647
Follow Up By: Russ n Sue - Tuesday, Jan 08, 2008 at 09:11
You'd better win the Lotto pretty soon then Snowy. The rate that the polar ice-cap is melting might make that run impossible in the near future.
Russ
FollowupID: 544649
Follow Up By: Stevo - Tuesday, Jan 08, 2008 at 09:18
This the list of vehicle mods that were undertaken and some of the survival gear:
Vehicle Arctic Trucks Double Cab 3.0 D-4D
Suspension Front: lowered by 50mm, moved 40mm forwards, additional 40mm lift.
Rear: longer, more pliant leaf springs fitted with heavy duty long travel pump stops and specially tuned shock absorbers.
Wheels and Tires Bespoke Arctic Trucks 15x12" aluminum wheels with two valves per wheel.
Arctic Trucks AT 405 38" studded snow tires.
Engine Standard 169bhp 3.0 liter D-4D engine, modified to cope with ultra low air temperatures.
Auxiliary heater added to boost coolant temperature before starting, together with fuel heaters and a heavy duty battery.
Air intake raised and special exhaust system fitted.
Auxiliary 90-liter tank increasing fuel capacity to 170 liters.
Transmission Arctic Trucks 4.88:1 differential ratios with front and rear diff locks with cold weather preparation.
Bodywork Flared wheel arches.
Front bumper bull bar protection with jack locations and winch mounts front and rear.
Heavy duty skid plates made of 5mm thick aluminum to protect the front bumper, suspension, transmission and transfer case.
Heavy duty running boards.
KC Xenon spotlights.
African Outback carrying rack.
Wheel Base 3125mm (from 3085)
Length 5335mm (from 5255)
Recovery kit Chain saw, axes, shovels, crowbars, high-lift jack and winch
Survival Equipment Tents, low temperature sleeping bags, heaters and shotguns were also carried for protection against polar bears.
FollowupID: 544652
Follow Up By: Lachie - Tuesday, Jan 08, 2008 at 09:43
You forgot another extra. The toilet seat on the tow bar.
I don't know if I would like to ride there while on the move. I so-pose if you were constipated the movement of the bumps might loosen you up a bit ?!
Lachie
FollowupID: 544655
Follow Up By: Bonz (Vic) - Tuesday, Jan 08, 2008 at 18:13
hahahahaha Lachie and if you were well endowed the vehicle would have a rudder too!
FollowupID: 544714
Reply By: Gerhardp1 - Tuesday, Jan 08, 2008 at 08:59
A little more research shows I'm not the only one who asked the question
Site Link
There are some enlightening comments there.
By the way, I agree it was a great show. I wonder whether the new Aussie Top Gear team (when and if selected) would have come to blows, unlike the restrained poms.
I'm also curious that they were able to stop the engines at -40 and just start up after some hours sleeping. The Ice Truck runs done in Canada every year Site Link
show the truckies never shutting off their engines as they ice up and will not restart.
AnswerID: 280424
Follow Up By: hotfishez - Tuesday, Jan 08, 2008 at 09:07
There are some parts of the show that had been edited out. If you go onto youtube you will find a clip where they explained what mods have been done to the vehicles. From memory they had to completley modify the front suspension to take the wheels as they were unable to open the front doors due to the size of the tyres, there was something about heating pre heating the fuel amongs many other mods. Worth a look.
FollowupID: 544646
Reply By: Member - Oldplodder (QLD) - Tuesday, Jan 08, 2008 at 09:09
Assume they got back.
Fuel guage was showing empty at the pole, which ever one they went to, magnetic or geographical.
And they had lost their auxilary tank.
At least they had two other vehicles giving them a hand with a snatch in places, and saw them following vehicle tracks in places.
There was only one sled with no other help.
But Clarkson does put on a good show for the camera. :o)
AnswerID: 280425
Follow Up By: Member -Signman - Tuesday, Jan 08, 2008 at 09:17
"There was only one sled with no other help"-
I don't think so. For a start a least there was a camera vehicle- and I reckon there would have been as many back-up vehicles with the dogs, as with the Yota.
FollowupID: 544651
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Jan 08, 2008 at 09:26
True signman,
must have been others with the sled to operate the camera and do the sound.
FollowupID: 544654
Follow Up By: Stevo - Tuesday, Jan 08, 2008 at 09:47
The "Top Gear" team undertook its race during the annual Polar Challenge Ski race, in 2007. The race has been taking place every year since 2003 with competitors in three persons team racing on skis 320 nautical miles across the Arctic to reach the 1996 Magnetic North Pole.
This gave the Top Gear team and their TV crew access to the huge logistics and safety network associated with the Ski Race, despite the tv show giving the impression that they were out there on their own.
FollowupID: 544657
Follow Up By: Member - Geoff C (QLD) - Tuesday, Jan 08, 2008 at 10:35
I'd like to know how they got the vehicles back and if not how much will it cost me to fly up there and get one free.
Geoff
FollowupID: 544666
Follow Up By: Bonz (Vic) - Tuesday, Jan 08, 2008 at 19:42
Their faces when driving on that ice told the story, they were scared for sure.
FollowupID: 544729
Reply By: Member - andrew B (Kununurra) - Tuesday, Jan 08, 2008 at 13:31
I loved the instant tyre inflation....just the right amount of bang!
AnswerID: 280461
Reply By: Shaker - Tuesday, Jan 08, 2008 at 16:44
They aren't fools, why would they clearly show the GPS readings on 2 separate occasions, if they were incorrect??
AnswerID: 280480
Reply By: Dave Thomson - Tuesday, Jan 08, 2008 at 18:15
At the end of the day anyone who doesn't think this show is good value must be completely devoid of a sense of humour, never mind the stats who else would attempt something as ludicrous as this all in the name of "cause we can" ? it'd be good to hear something positive on it, at least they had a go and gave us a good laugh along the way
regards,
Dave
AnswerID: 280493
Follow Up By: Gerhardp1 - Tuesday, Jan 08, 2008 at 18:23
This post was not meant to be negative, there's nothing wrong with having an enquiring mind.
I have said it was a great show, as have others, so you must have missed those positives?
FollowupID: 544715
Follow Up By: Dave Thomson - Wednesday, Jan 09, 2008 at 18:07
Guess I must have, what hit me most was stats stats and more stats, and what should have hit you was funny funny funny........
lighten up mate
FollowupID: 544904
Reply By: dingbat - Tuesday, Jan 08, 2008 at 19:09
We enjoyed the show-parts of the world I will never see--but I did like the nimber plate on the hilux
AnswerID: 280501
