Mouls in water pipes
Submitted: Friday, May 05, 2006 at 18:11
ThreadID: 33583 Views:2362 Replies:13 FollowUps:10
Hi all.
The other day after a trip I had need to crawl under my Jayco Penguin Outbacker to fix a water leak near the tank outlet.
I noticed that the water filler pipe (about 1 inch dia) and the smaller 3/8th my water suction pipes were made of that clear beverage plastic.
I also noticed that both these pipes were badly effected from within by mould.
Yucky Pooh's !
Before my wife and I die of some exotic water born mould or disease from our drinking water, does any one have a solution as to how this can be overcome?
Reply By: handy - Friday, May 05, 2006 at 18:21
see if you can get some pipe that wont let light into to it,the light is what causes
the algae to grow. cheers
AnswerID: 170996
Follow Up By: Janset - Friday, May 05, 2006 at 18:31
Yeah I understand that, but to replace the pipes I would had to destroy the seal that goes through the floor, and the only pipe that I know of that would 'really' be suitable is the black poly pipe,and that is by far to rigid to take in any and all bends.
FollowupID: 426406
Reply By: Sparkiepete - Friday, May 05, 2006 at 18:32
how about painting them
AnswerID: 170998
Follow Up By: Janset - Friday, May 05, 2006 at 18:37
Now that may be the way to go if nothing else comes up.
The other problem is cleaning the inside of the pipes.
The larger of the 2 pipes, I have managed to buy a small bottle brush that I hope to feed through the piping, but the small hose, I think I will have to make up a sort of 'pull through' as in rifle barrel cleaning, and hope I do not loose the rag half way down the tubing.
FollowupID: 426409
Follow Up By: handy - Friday, May 05, 2006 at 18:40
you can buy black or white flexible and re silicone it up
FollowupID: 426411
Follow Up By: Janset - Friday, May 05, 2006 at 18:54
Hi.
I did not know that it came in black or white.
Where would I go to find these?
FollowupID: 426417
Follow Up By: handy - Friday, May 05, 2006 at 19:03
try a hardware shop,plumbing supplies or clark rubber, its the same type of hose
used on washing machines only bigger id
FollowupID: 426418
Reply By: Member - Bijengum (NSW) - Friday, May 05, 2006 at 18:57
Algae is actually not a problem. It filters the water, absorbs nitrates etc.
AnswerID: 171005
Follow Up By: Mr Fawlty - Friday, May 05, 2006 at 19:41
Actually true... Just the same as the water from a mountain stream tastes clean & pure it's because of the green stuff in the Algae, Chlorophyll, they used to put it in toothpaste as a mouth freshener...This problem happened to me and I naturally panicked and when down the road of Algae destruction only to discover that the plastic taste returned...
FollowupID: 426431
Follow Up By: fisho64 - Saturday, May 06, 2006 at 00:12
Somewhere along the way I was told that in a healthy stream system with a dead animal decaying in the water, it should be clean again with 30 meters or so?
FollowupID: 426500
Follow Up By: agsmky - Saturday, May 06, 2006 at 06:35
Yes, that would be 30m upstream :-)
Andrew
FollowupID: 426509
Follow Up By: fisho64 - Saturday, May 06, 2006 at 11:55
downstream with the flow, point being that micro organisms, plants etc are filtering the water
FollowupID: 426568
Reply By: Member - Charlie M (SA) - Friday, May 05, 2006 at 19:13
I use air hose on my caravan comes in Yellow, Blue and Blue/Yellow
On the small line 1/2 black dripper tube also works, use that from tamk to pump suction line, I use air on pressure line
Charlie
AnswerID: 171007
Reply By: Member - Doug T (QLD) - Friday, May 05, 2006 at 19:24
Yeh replace the clear pipe with non transparent, It's the light that does that ,get a clear plastic water bottle and solid color bottle and half fill them and leave them for a few weeks and see the result
AnswerID: 171010
Reply By: V8Diesel - Friday, May 05, 2006 at 19:33
Speak to a cruising yachtie. They deal with this kind of thing all the time.
I know Bias Boating sell a potable water tank conditioner product.
AnswerID: 171012
Reply By: David from Engine Saver Low Water Alarms - Friday, May 05, 2006 at 19:39
Janset,
This is a real easy one.
I do a lot of work with the marine industry and one particular vessel I work with fills it's fresh water tank with rain water.
This causes mould and a green algae to grow in the tank and the pipes.
A good dose of bleach or chlorine (about 1 litre per 1000 litres water) and a good flush out fixes the problem.
Same as a swimming pool I suppose.
Hope this helps
David
AnswerID: 171014
Reply By: Stoo - Friday, May 05, 2006 at 19:39
Chuck a couple of drops ( literally ) of ti tree oil in it, that'll kill and mouldy crap and do you no harm.
Stu
AnswerID: 171015
Reply By: Janset - Friday, May 05, 2006 at 21:25
Thanks guys.
Heaps of good answers here and ideas. I will give them a go over the next few weeks with good results I am sure.
AnswerID: 171033
Reply By: Kiwi Kia - Friday, May 05, 2006 at 22:34
Is it possible to slide a larger diameter black tube over the top of most of your clear water hose ? That way you would shield most of the hose from light and avoid changeing it where it penetrates the floor.
An extra layer would also give it a bit more protection downstairs.
AnswerID: 171061
Follow Up By: V8 Troopie - Friday, May 05, 2006 at 23:10
Interesting idea that. One could slit a suitable piece of black hose lengthwise with a stanley knife, pop it over the clear tube and tie it up with cable ties.
That would be the easiest fix if it does the trick.
Klaus
FollowupID: 426495
Reply By: derraux - Friday, May 05, 2006 at 23:36
For cleaning this problem they make a product called tank clean you should be able to get it at your local camping store or caraven store from what i understand this product will even take the plastic taste from tanks and lines.
Derraux
AnswerID: 171071
Reply By: Janset - Saturday, May 06, 2006 at 12:14
More good ideas.
Thanks guys. The sleeving idea, I have about one meter of that foam insulating hosing used to lag hot water piping. I think the diameter is just about the right size also. If it does not quite fit, I can always spray some of the black rubberised solution that I already have.
I may look at that first as I have always had concerns about stone damage also.
I never had any problems with a plastic taste so far, but I will look into that also to retard growth or just as a general tank clean out.
AnswerID: 171123
Reply By: Sand Man (SA) - Sunday, May 07, 2006 at 10:27
The correct hose for this type of use is "food grade" plastic hosepipe.
It's available from Caravan & Accessories outlets.
To clean and flush existing tanks & hose, all that should be required is a cup of bi-carbinate of soda.
Yes, after cleaning your existing pipe to get rid of the "Yucky Pooh's" you could paint over it. This may not stop algae/mould/bacteria from regrowing, but you would never see it then:-).
Bill
AnswerID: 171258
