Saturday, Dec 24, 2005 at 00:45
From what factual base do you make that comment?
Here are some of many quotes from the tyre industry :
"When moisture gets into the tire, the steel belt package rusts and the tire's structural integrity goes. Goodyear helps reduce this with its Enhanced Casing Design (ECD) which is included in all of the company's mixed service radial tires."
"Keeping moisture out of tires greatly reduces the chance of tread separation, belt failure, corrosion around the valve stems, and other common causes of blowouts."
"Water can permeate a tire through any slight cut or nick in the tire surface. Once the water reaches the steel belt, oxidation occurs. The rust weakens the belt and can cause the tire to disintegrate during normal road operation. A visual inspection of a tire with a rusted belt may reveal slight tread wear, and the tire may appear to be in good condition. Thus, the potential for catastrophic tire failure can lurk below the surface where it cannot be seen."
"With steel belt tires now standard equipment, we sometimes see the outside steel belt separating. This is due to the oxygen and moisture leaking through the tire. A tire loses between 2% and 5% of air per month. This rusts the steel belts after a period of time. Aircraft and some truck fleets inflate tires with nitrogen to help stop this problem. "
"That's important because moisture could cause corrosion that could hamper the adhesion to the rubber at the weakest point of the tire and the very place where most of the tire failures occur, said experts who testified for plaintiffs and Firestone. "
There hundreds if not thousands -
check for yourself.
No - it is not april. That part was factual.
398872
