Saturday, Oct 15, 2005 at 09:13
Andrew,
This is one of Victoria's bet kept secret, so don't tell anyone else.
It will depend on what direction that you will be going.
If starting at
Mansfield, you could go along the Circuit Road down to
King Hut.This road has been up graded to allow 4WD towing horse floats to get to
King Hut. From there go along Little Cobbler Track, this will take you past the bottom from of the Stair Case, have a look with out the camper hitched up and give it a go. The hair pin bend just before the climb could be a little tight with the camper. If after driving the Staircase with out the camper and you fell it is possible give it a go , if not stay on the Little Cobbler Track and turn right on the Cobbler
Lake Road up to
Lake Cobbler.
From there there would be two ways to get to Wonnangatta Valley. One would be to go down the Staircase, which would be a lot easier than going up, then on the Circuit Road again to
Bindaree Hut ( this is a beautiful
camp site ) from there it is a long climb to
Bluff Track, from there to Howitt Road and down the Zeka Track. The Zeka Track has a few hair pin bend on it.
The other way is to go from
Lake Cobbler to Abbeyards Road, West Buffalo Divide Track, Riley Creek Track, which will bring you on to the Wonnangatta Valley.
To get to
Dargo from Wonnangatta I would go up Wombat Spur as Hern Spur is very steep. Wombat Range Track to
Eaglevale,Wonnangatta Road, Crooked River Road to
Dargo.
All of these tracks can be found on the Hema map, The High Country - Victoria.
Have a good trip, and I might see you down that way.
Wayne
134696
Follow Up By: Andrew (Whyalla SA) - Saturday, Oct 15, 2005 at 10:13
Thanks Wayne
We are planning to take the Abbeyards road down to the valley.
Is Zeka Spur worth a drive (without the campers) up and back down or just give it a miss?
388747
Follow Up By: Wayne (NSW) - Saturday, Oct 15, 2005 at 10:54
Andrew,
I would drive the Zeka track without the campers. The hair pin bends at the top of the track make it a bit hard with a camper. Allow about 3.5 hours to do the return trip.
Wayne
388750
