Ultimate 4 w drive
Submitted: Wednesday, Jan 26, 2005 at 00:55
Member Eric
Well i know everyone argues about what the best 4 wheel drive on the market is today . I have come to the conclusion that there all crap lol .
I sat down and wondered what the ultimate 4wd would be if we could mix and match .
Ride comfort , I have the Cruiser ahead of the Nissan by
miles , but the RR as best.
Front & rear diff , I have the Nissan ahead by
miles
Transfer case I have both Nissan & Cruiser equal , but find the gearing better in auto cruisers for down
hill desent. better than the Nissan autos gearing . RR not a hope in this department
Auto transmition I have the cruiser infront of the Nissan
Gear boxes , I have the Nissan infront of the cruiser in the manual before 1998 but the cruiser wins after 98 due to the 5th gear issue in Nissans ( supposably solved , soon to find out ) . RR not close again .
Petrol Engines . Nissan wins in the GQ until the 4.5 came out . Then cruiser took over .
Diesel . Hard to compare , both fantastic .
Simplicity , for bush repairs , Nissan wins here in my books . Unless you go down to the 60 series or older in Cruiser .
So there you have it .
I want a car as light as the RR , with Nissan diffs , RR interior , Cruiser engine and suspention and a transfer case and gearbox out of either cruiser or Nissan but no way a RR.
I hope you dont find this alot of dribble & I would love to hear peoples opinion.
Reply By: Tuff60 - Wednesday, Jan 26, 2005 at 01:28
Well you asked:
Body: 60 Series 89 Sahara(I am a big fan)Full Alloy Cage
Seating: WRX STi, front seats anyway, I don't sit in the back.
Engine: post 98 Hummer 6.5 Turbo Diesel
Gearbox: 4L80 E4, 4 speed auto from a hummer, should be tough enough.
Transfer Case: New Venture Gear NV233, Part time 4WD push button shift.
Diffs: nissan GU, there is tougher available but not common enough to find spares.
Brakes: Do AP make a 6 pot calliper to suit nissan diffs??
Suspension: custom coils by me, about 5 inches over standard, hence the roll cage.
PS. with you on tadays 4WD's being crap, but as 95% don't go offroad(by offroad I mean somewhere bush kids couldn't get someone elses Falcodore through), why would the manufacturers cater to the 5% of buyers who do go offroad. My figures may
well be off but I don't think by much.
94933
Reply By: Member - Captain (WA) - Wednesday, Jan 26, 2005 at 10:49
Hi Eric,
I reckon your not far from the money, but a few things I would change are;
Transfer case: CRUISER, as Nissans 2:1 is just too low.
Gear box: NISSAN, might not shift as nice as a cruiser, but much stronger IMHO (5th gear sorted now I reckon).
Diesel: CRUISER 4.2TD, Nissan 4.2TD may be reliable but S..L..O..W in standard form, 3.0TD needs more bottom end - While dreaming I would go the Nissan 4.5TD - thats the 3.0TD with 2 more cylinders (can hear Truckster now - WHAT, just a 3.0TD with 50% more problems... hahaha)
Captain
94967
Reply By: Utemad - Wednesday, Jan 26, 2005 at 14:05
Come on guys you're thinking along the wrong lines.
It needs to be small enough to fit into shopping centres while large enough to
seat you and all your screming kids so I'm thinking a Prado body.
It has to be automatic for ease of city driving and amount of gears doesn't matter as you just put it in drive don't you? Mated to a V6 engine so it has more than enough power to run the air conditioner while stuck in peak hour traffic.
Constant 4x4 so as to improve wet bitumen stability.
No low range as that is just unnecessary weight and expense.
Independent
suspension all round from a Pajero to soak up all the lumps and bumps in that rough pavement.
Run flat tyres in case the RACQ is busy. They need to be a H/T pattern to suit the most common terrain encountered.
94979
Reply By: Member - Roachie (SA) - Wednesday, Jan 26, 2005 at 14:35
Jeez I hope Des Lexic, Andrew, Pesty and Muddy don't read this....
I'd have to agree that the body/interior would be Toyota (80 series for
mine).
Best engine : 6.5L Chev bent eight with a hair dryer
Nissan gearbox and tranny case, but with Marks adaptors low range gears
Nissan diffs with a couple of ARB lockers;.......nah, make that "3".......with all that grunt, I'd be wanting to spin 3 diffs please.
Cut the bod down to a dual cab and whack on a neat tray with sealed canopy containing a couple of LARGE fridges (I like Engels) and enough
battery power to keep the grog cold.....
When can you have it ready for me please Eric???? hahaha
94987
Follow Up By: Member Eric - Wednesday, Jan 26, 2005 at 17:22
I must admit , I hated my 80 series seats , so got rid of them for some AU3 Futura seats .
I sat in cars at work for 3 months before desiding they were the most comfortable .
Mind you sat in a mates FJ40 the other day with leather motorised 300 zx seats . wernt bad at all
353846
Follow Up By: Muddy 'doe (SA) - Wednesday, Jan 26, 2005 at 22:20
It's OK Roachie, I did not see this post.
I also did not Member Message Des and Andrew and Pesty to alert them to your 'yota admiration post!
Agree totally on the Trayback conversion of a full size wagon. The ones coming out of QLD look awesome.
Muddy
353885
Follow Up By: Des Lexic - Wednesday, Jan 26, 2005 at 23:05
Muddy, no need to member message me as I knew ages ago that Roachie is a closet 50series fan. Even nette is coming round. You could tell that by the way she wrapped herself up in the genuine yota blanket on Sat night.
The only thing I'd change is to fit 60series diffs as they are interchangeable.
Come to think of it, the HZ61 was unbreakable but needs coil springs all round.
353893
