A standard type trailer for around 200kg of camping gear.
Submitted: Thursday, Oct 14, 2004 at 16:17
ThreadID: 17043 Views:3090 Replies:6 FollowUps:2
I want to carry about 200kg off camping gear in a 6x4 trailer, 750kg rated. Most driving would be on the highway and smooth dirt/corrugated/potholed roads, not 4x4 tracks.
Does any one use a standard type box trailer for this use.
Dean
Reply By: Nudenut - Thursday, Oct 14, 2004 at 16:30
certainly do
have heavy duty bearings though ....not the standard holden or ford roller skate bearings
AnswerID: 80214
Reply By: Vince NSW - Thursday, Oct 14, 2004 at 16:55
Dean,
Have used a standard 6 x 4 garden type trailer. Make sure you pack the bearings well before the trip and check every few days for free play and grease.
The only place it could let you down is that they tend to have slipper springs which can have problems.
Just go slow on the BAD bits of road and enjoy yourself
Vince
AnswerID: 80215
Follow Up By: crayman - Thursday, Oct 14, 2004 at 17:43
dean have a 7' 5 std trailer 14" holden wheels and 8ply tyres std bearings greased and toped up with diff oil done 40k over gibb river darwin kalg slipper springs beefed up arround slipper slide`s, 1/2 " u bolts spare center bolts 400k load no probs used stabiliser bars to keep trailer down on rough roads worked a treat
Maurie
FollowupID: 339563
Reply By: Member -Dodger - Thursday, Oct 14, 2004 at 17:42
If you stick to around 200kg then you should have no worry. As previously said repack the bearings and adjust accordingly every year at least. Watch for water ingress in the bearingswhen traversing rivers etc.
Happy wanderings.
Cheers Dodg.
AnswerID: 80218
Reply By: Member - PatC - Thursday, Oct 14, 2004 at 19:02
I have a 7x4 box trailer with a camper bolted on top. All up it weights 650kg I run "roller skate" holden wheel bearings and have never had a problem but I repack them regularly and replace them every couple of years.
Last year I came across a guy about 30k north of Coen on the way up to Cape York. He had a garden trailer that would have been lucky to gross 500kg. It had broken a spring on the passenger side. Because it had slipper springs the left hand side tyre shot out the back of the trailer putting a 90deg bend in the axle. He ended up abandoning it. The road from Cairns to Coen is "highway and smooth dirt/corrugated/potholed roads, not 4x4 tracks".
Based on that I won't go far off the bitumen unless I have a minimum 4 leaf spring pack with shackles front and back.
AnswerID: 80223
Reply By: Shaker - Thursday, Oct 14, 2004 at 19:57
Why are we paranoid about trailer wheel bearings?
We drive 1000's of kms in our cars & never give a thought to the front wheel bearings.
After all, they are the same bearings doing the same job.
AnswerID: 80229
Follow Up By: Eric from Cape York Connections - Friday, Oct 15, 2004 at 06:42
Shaker I think the bearings are a big thing to remember most people forget the things.
I do mine every year on the 4x4.
All the best
Eric
FollowupID: 339615
Reply By: pjd - Thursday, Oct 14, 2004 at 20:58
have shackel to shackel springs fitted not slipper springs & get some bearings buddies to keep the bearings full of grease & you shouldnt have any problems
AnswerID: 80236
