Sunday, Nov 24, 2024 at 12:44
Warren, although a tad sceptical about your idea of utilising a couple of ratchet straps, I gave it a go this morning & it made all the difference, worked
well. Thanks for posting it.
Sadly though it's not going to help me.
When I bought it, I now recall, I had to order it to fit the Fuelsafe brand of jerries I had, which is what I used the Tanami pump on this morning.
The disappointing bit is that the Fuelsafe jerries don't fit into the aluminium box on the cab roof, custom made to fit 4 x Sceptre jerries ( & no others I tried a few) & the Sceptre jerries have a different (larger) cap size to the Fuelsafe ones. Bugger!
In reality I reckon the only time I might fill the jerries would be on the Canning. 350 litres in the fuel tanks will likely be sufficient for any other route (& in fact enough for the Canning if purchasing at
Kunawarritji). I reckon I'll buy one of those plastic battery operated pumps if need be.
It's not just lifting the jerries to fill the tanks which is a problem, the tank filler caps are set in under the motorhome body making it hard if not impossible to tip the jerry up sufficiently to empty it. So if planning to use them I will need a pump of some sort.
If I thought I was going to use the jerries on a regular basis, I'd build a slightly larger enclosure to hold the Fuelsafe jerries I have, but it feels like to much stuffing around without a great deal of justification.
927582
