Wednesday, Apr 14, 2021 at 21:02
. . . and the dunes east side aren't babies, and can be soft if hot / dry making for soft sand.
They do peter out into the Nat Pk section a bit, even after Eyre Ck I'd say from memory.
Still, usually plenty of other4WD's on that section, or better, have a 2nd 4WD with you.
Drop tyres to 18psi to start, should be ok with a little excitement for you.
Yes, there is a
sign you are entering Munga-Thirri NP, but your basic sat nav SHOULD have it shown on the map too, OR take a paper map and hopefully you can pick where you are as you progress.
Take some basic recovery and safety gear, water, UHF, not sure how you're set up, but ask again here if unsure.
913819
