Wednesday, May 27, 2020 at 14:36
I had a 2003 Jayco
Penguin and now have a similar age Jayco Freedom. In both cases, the vans as built by Jayco had a 240v domestic light switch fitted near the battery which in one position trickle-charged the battery from the Centurion/Setec when the van was connected to 240V, and in the other position supplied 12V from the battery back to the Centurion/Setec when 240V was not available (
free camping). Does your
Penguin still have this switch, and is it wired as Jayco intended?? If yes, switch on so the van battery is only charged by your decent charger and the solar panel, but supplies 12V to the van when
free camping.
Secondly, with regard to the mysterious diode that is wired in near the Centurion/Setec. This is supposed to allow the 3-way fridge could take 12V from the car but prevents the fridge taking 12V from the van battery or the Centurion/Setec. The presence of the diode also means the van battery never gets a full charge from the car alternator due to the voltage drop across the diode. Also the Centurion/Setec is a constant voltage PSU so is not a proper battery charger. But from Jayco's viewpoint, it's a cheap system and works the day you drive away with a new van!!!
Unfortunately, if your fridge is on 12V and the car is connected whilst not running , the fridge will rapidly drain the car battery. There are three usual solutions to this problem:
1. Unplug the van from the car every time you stop, and plug it back in again before you drive away again Hands up all those people who forgotten to unplug or plug!!!!!!!
2. Fit a VSR or ignition-controlled relay in the car which stops the 12V supply to the van automatically when the car isn't running, and/or
3. Fit a Fridge Switch which connects the 12V to the fridge only when the van is in motion.
Hope this helps.
908095
