Reversing Camera
Submitted: Sunday, May 03, 2020 at 07:44
ThreadID: 139965 Views:13488 Replies:11 FollowUps:9
Just looking at putting a reversing camera on my Iveco Daily van. Had a look around and think I will go with a wired in type. My question is there seems a lot of variance in price for similar looking setups. I had a look at Safety Dave’s items and they look good but a little $ than others. Has anyone used their set ups or have other recommendations? Thanks
Reply By: Member - shane r1 - Sunday, May 03, 2020 at 08:14
G’day
Had a quick look, at safety Dave’s, but no pricing on the site . I’ve got CWI screens and cameras (wired) in my 4wd and motorhome, pretty happy with them. CWI aim their market at the Ag industry. That’s where I had used them previously. Not cheap but seem good quality,(had a couple of cheapies before and got sick of them) I buy mine from a local machinery dealer they keep a lot of stuff on the shelf.
Shane
AnswerID: 631332
Follow Up By: Member - shane r1 - Sunday, May 03, 2020 at 08:53
Have a look at the CWI “dealers” and a lot would have screens , cameras and cables in stock, so wherever you travel .
FollowupID: 907325
Reply By: Sinkas - Sunday, May 03, 2020 at 08:39
I would purchase from Safety Dave's (no affiliation). If there are issues, and in my case there was, they are very good at sorting them out. Also Australian jobs.
AnswerID: 631333
Follow Up By: Member - Suitcase (QLD) - Sunday, May 03, 2020 at 09:36
I would second that motion. Very good service from Safety Dave.
suitcase
Prado SX and a little van
FollowupID: 907326
Follow Up By: Kazza055 - Sunday, May 03, 2020 at 15:32
If Safety Dave is so good, why doesn't he show his prices?
I would recommend having a look at Brash Import. I have brought a few items from him over the years and he is always very helpful plus he has his prices online.
FollowupID: 907335
Reply By: Member - A J - Sunday, May 03, 2020 at 08:55
Trevor G5
When we had our caravan built, it came with a SVS 100 series reversing camera and another camera for the vehicle.
The picture is very clear, I am totally satisfied and service has been good.
I worked with some farmers who had camera on all vehicles and machinery and no picture was as clear as the system we had.
A J
AnswerID: 631334
Reply By: RMD - Sunday, May 03, 2020 at 09:43
Trevor,
Depending on your expertise you can make up a kit yourself. Buy a screen as mentioned above and fit the camera/s to it. I use two cameras on a caravan mostly for reversing use but with one placed to from same plane as the side of the vehicle and the other to track the white line you can position it all quite well. Most cameras are for reversing and provide a wide view but not distance observation. With the rear LHS camera, it actually sees around the corner which mirrors cannot do, so increased safety and surety there. The RHS camera is much the same , but if a constant driving picture is required a better camera which "sees" down the road further may be a better option. A road train nearly up to you looks far away, That is the drawback for constant use.
I use an automated system to select whichever camera I want to view from, But a relatively simple switch can be arranged to run both camera video line to the screen, and power to that camera, one at a time. If a multiple pole switch is used, it can switch the power to and video from whichever camera you require to see. Most systems don't provide a selection of camera inputs. I know some have two cameras and you press a button while reaching up to the screen to change the viewing camera, a pain to me.. A simple switch near controls is far better and if arranged with the toggle to the L or R you always know at a glance what you are seeing or intending to see.
AnswerID: 631335
Reply By: Ken O3 - Sunday, May 03, 2020 at 10:16
Trevor, most rear view cameras are pretty useless if they have a wide view angle. Following traffic appears miles away and if they are approaching at speed the are on you before you see them, even big semi's and roadtrains. I managed to find one with a view angle of 30 degrees for our van and it gives a good view of what is behind. They are not easy to find and I can't recall where I got mine from but it was a Chinese supplier. Sorry can't help with details. Sixty degree ones are on eBay but in my view it isn't worth using any camera with a view angle more than 60 deg. Sure wider angle cameras give a wider view but that is what mirrors are for.
AnswerID: 631336
Follow Up By: Kazza055 - Sunday, May 03, 2020 at 15:39
If you ask me, there is no need to read the plate number of the car 500m behind you, mirrors are more effective for longer distance.
I find the camera on the back of the van is great for seeing if someone is hiding in you blind spot and it is also very good for when you are overtaking, once you see the complete picture of the truck you just passed, you know you can then merge back in front of him.
Maybe I just happened to have the correct camera in my box of trick and would not have a clue as to the viewing angle.
FollowupID: 907336
Follow Up By: Ken O3 - Sunday, May 03, 2020 at 17:52
It's not to read numberplates 500m down the road at all. It is about seeing an approaching vehicle at a greater distance than 90degree plus view angle cameras are capable of doing and to get a far better idea of how close the vehicle is.
FollowupID: 907338
Reply By: Member - shane r1 - Sunday, May 03, 2020 at 10:19
G’day again
RMD commented on the field of view, or degree . That’s the hard part, I have a couple of different one’s. 150 degree gives huge field of vision but you can’t see far back up the road, so depends what you need. CWI have 150, 120, 92 and 65 maybe others .
AnswerID: 631337
Reply By: 9900Eagle - Sunday, May 03, 2020 at 10:36
Trevor, I have a reverse camera form Elinz, It is a quite few years old now but has never given any trouble and I see everything I want to. Thepicture is also good quality.
Elinz reverse camera
Product review
AnswerID: 631338
Reply By: Ken O3 - Sunday, May 03, 2020 at 13:32
Danny, I have managed to find the seller of a 30 degree angle camera. My purchase was in 2018 so not sure if current status of this seller but from my experience he was excellent. Details are :
Peter.Liang (Sales Specialist)
LINTECH ENTERPRISES LIMITED
Tel: +86-769-8118 3549 M.P.: +86-159 2023 2055
Skype: lintech05 (WhatApp / Wechat): +86 159 2023 2055
Fax: +86-769-8108 6803
Email: peter.liang@lintechco.com / peter.liangc@gmail.com
Website: www.lintechco.com
Add: 3/F, Blcok A8, Kaida Creative Industry Park, Qiaochang Road, Qiaotou Town, Dongguan City, Guangdong,China.
Regards,
Ken
AnswerID: 631339
Follow Up By: Frank P (NSW) - Sunday, May 03, 2020 at 13:38
From their website, they also have a contact in Australia:
Details deleted, after John's follow-up below.
FollowupID: 907332
Follow Up By: Member - John - Monday, May 04, 2020 at 09:58
Ken, just rang the Aussie contact, haven't sold them for about 12 months, will try the Chinese contact. May want to delete the Aussie contact details. Cheers.
John and Jan
FollowupID: 907355
Reply By: Trevor G5 - Sunday, May 03, 2020 at 19:14
I really appreciate all the information from everyone. It has given me a lot more information. Thanks very much.
AnswerID: 631351
Follow Up By: RMD - Sunday, May 03, 2020 at 20:12
Good on you Trevor. I hope all goes well with your selection of the gear.
FollowupID: 907345
Reply By: Simon C7 - Monday, May 04, 2020 at 10:29
We use Balckeye Systems from AEI - Ionic. Not cheap, but stand up in mining and earth moving applications. Can get various angle cameras.
https://www.ionnic.com/safety/cctv/cctv-systems/backeye-weatherproof-kit.html
AnswerID: 631364
Reply By: Member - John - Monday, May 04, 2020 at 12:46
For those that are interested in 30 degree rear view cameras, have been in touch with supplier in China, thanks Ken03, and am looking at getting one or two for evaluation. Will let you know how it goes. Cheers.
John and Jan
AnswerID: 631367
Follow Up By: Member - John - Wednesday, May 06, 2020 at 12:31
Buying two of the 30 degree camera's, shipping is going to be the same price as a camera, LOL. Will see how they go and report back. Cheers.
John and Jan
FollowupID: 907398
