Friday, Jun 07, 2019 at 17:21
“........Loctite too..........never used it before.”
Beginner’s Guide to Loctite:
222, Good for small screws, or nuts & bolts, that you may need to undo sometimes. Excellent for screws on glasses frames, GPS mounts etc. KEEP AWAY FROM PLASTIC, IF POSSIBLE.
243, Useful for slightly bigger screws, bolts & nuts, say up to 10mm. Things like free wheeling hub bolts, driving light mounts etc. Same deal with plastic!
263, Recommended for bigger bolts, like
suspension bolts, shockie bolts, chassis mountings, usually above 10mm. DON’T use on small screws or bolts, nor Nyloc nuts. The bolt etc will break before 263 lets go. More of same with plastic.
Use sparingly, and wear plastic/rubber gloves when using it. All care, no responsibility!
899723
