Saturday, May 04, 2019 at 18:51
A group of us did some of these tracks in June ‘18.
North from Cocklebiddy to
Rawlinna is steady, station tracks, with lots of
limestone outcrops and a number of gates, closer to a dozen rather than 2 or 3. Camped opposite the railway station at
Rawlinna, and got to see the Indian-Pacific & a few other attractions. The IP stops there for the evening meal, heading west, and some light entertainment.
From
Rawlinna north, there is more of the same, track wise, but eventually gets into sandier soils as you leave the Nullarbor. Some washouts, scratchy bits & also some top scenery through the sandhills, with lots of different flora. Worth stopping at Neales Breakaways for the night, but don’t go where I did or you’ll get bogged!
Neale Junction is a
good camp with a couple of long term residents already there. Worth going into
Point Lilian too, it’s not far off the track, to the west. Good water at
Cooper Hills Bore too. Think road improved a bit further north too, but we turned left at Parallel Road No.2, and scratched our way across to a night
camp in a
gravel pit beside the GCR.
McPhersons Pillar WA
We camped at
Geraldton Bore before heading up the Gary. Not bad travelling, but bit slower going up past Charlie’s Knob. Definitely worth driving up to the top of
the Knob, to see where you’ve been, and where you hope you’re going. Few washouts after Charlie’s Knob, but levels out further north. We went into
McPhersons Pillar & camped the night, though not one of the best sites we’d had. Was worth it though, to see the Pillar lit by the setting sun. I wouldn’t bother going to
Mulan Rockhole nearby, unless you’re heavily in Australian history.
Charlies Knob, Gary Highway WA
Track further north varied a bit, some scratchy stuff, quick gravel, corrugations & washouts.
Windy Corner turned out to be the “a’hole” of our entire 10K trip, but one of the lads found a set of wheel tracks heading east, only a km or so north of the Corner, that lead to numerous cleared areas suitable for a
good camp, and a fire!
We were planning to do western end of the Talawana, through to
Newman, but the wet area around
Well 25 changed our plans and exited through
Well 33, Telfer
Mine and down to Desert Queen Baths, in Rudall NP.
625364
Follow Up By: Member - Mal and Naomi G - Saturday, May 04, 2019 at 22:40
Thanks Bob, we'll keep your
camp and side detour suggestions in mind. Wasn't particularly fussed about whether we turned off
Gary Hwy onto Talawana or went on up to
Gary Junction and turned left onto Wapet Rd and, like you did, come down to Desert Queen Baths from the north rather than up from the south. We'll call it as we see it on the approach to
Lake Disappointment, we're not big fans of mud, much prefer sand. Don't mind the odd scratchy bit but didn't want to have to cut our way through.
Cheers, Mal and Naomi
898999
Follow Up By: Bob Y. - Qld - Sunday, May 05, 2019 at 08:59
Forgot to mention above that
Lake Cohen had water in it too. Not a lot of bird life though?
Lake Cohen, Gary Hway. WA
Re the scratchy bits, the noise was very stressful, but end result was not as bad as expected.
899003
Follow Up By: Frank P (NSW) - Sunday, May 05, 2019 at 10:28
Don't want to start a big OT discussion, but re the "scratchy bits", I've had great success with a product called
Road Warrior. It looks and smells like white PVA glue, but is runnier. Apply two coats with the supplied small foam roller, keep it dry while it cures and it forms a hard protective layer over your paint.
You can leave it on for months, as we did, and it washes off in sheets with a pressure washer.
Best applied on glossy, freshly waxed finishes. If applied on a dull finish it can be hard to remove.
899014
Follow Up By: Member - Mal and Naomi G - Sunday, May 05, 2019 at 11:15
We were hoping for some water and birds at
Lake Cowan. Looks like that whole area might have got a drink early last month so hoping it will look its best by the time we get there. On the scratchy bits, I was amazed last year on the ABH how many heavy wacks our big side mirrors copped without damage. Folded them in most of the time but it usually took a big wack from a solid dead branch hiding behind soft-looking shrubbery to remind me.
899016
