Saturday, Mar 29, 2014 at 14:50
Cecilyt,
Hope you both have a safe and enjoyable trip to D'town. As others have said, fuel should not be a problem, and even from
Camooweal to
Barkly Homestead, at a bit under 270 kms, you'll probably have a tail wind across there, so economy should be better than normal.
Re your concern about road trains. I thought there was a good article on this site, by Doug Tilley, about road train etiquette, but can't find it. Maybe it's on his own webpage?
Most truck drivers are responsible, and wouldn't want to have an accident anymore than you would. Just drive normally as you would, and the "big fellars" will work around you. However, if you are about to be overtaken by a road train, keep at your normal speed. DO NOT slow down when YOU think he can pass, as the clear distance ahead may not be enough for a 53 metre vehicle to pass. When he does pull out to pass you, you can ease up on the accelerator, but it is best not to brake at this time.
Road trains usually travel at 90 clicks, but there are some that are a little quicker. Once you're in hilly country, then they are often the ones holding you up :-)))
The weather in June will be cool and comfortable, even in
Darwin. Enjoy,
Bob.
812187
