Wednesday, Mar 05, 2014 at 08:29
Hi Digger,
I totally agree with Motherhen.
There are a lot of vans that will do what you require and a good many that won't as
The best thing to do is get under any prospective van you are looking at and check out the chassis to see if it appears heavy enough. Once you have looked at several vans you will get a good enough idea as to what is strong and what is not.
Most of the vans you will look at are capable of light off road work so long as it is a made track without deep ruts such that the van is trying to screw itself inside out.
My advice is go for 6 inch chassis rails with a good number of cross members. Vans such as
mine with whip pars are not as good as deeper chassis rails in my opinion. For your expected "off road work" I would have the axles rotated (axle relocated under the spring as opposed to on top of spring) to give you more height. This will not effect the stability of the van unduly.
In your price range you will have many choices especially if you buy near new as opposed to new.
An ensuite, get a separate shower and loo, is a very good idea as it will give you the ability to
camp anywhere that takes your fancy and if you have solar fitted to the van then your possibilities will be unlimited. Your only limiting factor then is
water.
My advice is between 200 and 400 watts of solar and 2 to 3 X 100 Ah batteries.
The only trouble with dedicated
off road caravans is that they are so heavy. At a starting price of around 3.5 tonne it means a lot more fuel and a lot more strain on your gear.
Like Motherhen I am reluctant to mention brands also but check out other campers and see what they say about their vans, this is the best research you can do. Most people are only too happy to talk about their vans and in the main can be slightly biased toward their van, me included.
Two recent model of vans I have or had are;
1 2000 Gazal Champion 18.5 foot. (second hand)
Excellent van, excellent value for money, heavy chassis,
toilet and shower combined (not best solution), queen sized bed. not suited to an extra person but possible if a child.
2 2006 Jayco Sterling 24 foot (second hand)
Good roomy van, good value for money, reasonable chassis, a little large for off road tracks but it would not stop me if I wanted/needed to go there, all inclusions, seperate shower, seperate loo, front club lounge, good sized fridge, queen size bed, can accommodate extra people if needed in club lounge.
My advice would be look at 20 to 21 footers for your needs.
You certainly have the right vehicle for towing anything your looking at, pretty much.
Cheers, Bruce.
527676
