Monday, May 27, 2013 at 12:21
I have done the Simpson 3 times and I offer some advice.
1. Don't do a solo trip, it is much too dangerous, become a part of a party of vehicles. There is safety in numbers for example, if you become bogged in the sand there is someone there to help dig you out. If you have a roll-over, there is someone there to save your life!
2. You must have a sat phone in the group because a mobile just will not cut the mustard. You can hire a sat phone at
Birdsville and drop it off at Mt Dare or vice versa if you are travelling from west to east (supposedly the easier way).
3. You must have a quality CB radio in you vehicle and on channel 10. This is not only for your safety but for the safety of others you might encounter on the track.
4. Tyre pressures are extremely important and it is not unrealistic to lower the pressures to 10 p.s.i. in an extreme situation. Just remember to raise them to about 18 p.s.i. once free of that situation.
5. Water, water, water and more water. You ought have about 10 litres of water per person per day for the duration of the crossing.
6. The desert can deliver extreme temperatures. In the summer (although the desert is closed over the summer months), as high as 50 degrees C and during the nights for most of the year below zero temperatures are not uncommon.
7. This probably preaching to the converted but I would feel remiss should I not mention that you must have your vehicle in tip top shape. Also you need to be able to get your vehicle going should you have a failure of some sort because to recover your beloved 4by can cost upwards of $4000.00.
Regards and best of luck, the
Simpson Desert is one of the most wonderful experiences that one can have.
Ajay and Fletch.
511929
