Wednesday, Apr 10, 2013 at 22:55
I drove both the FJ45 ute and the 'luxurious' FJ55 wagons back in '69-72 in a work capacity, mainly between
Perth and Eucla.
And the drum brakes on both weren't all that hot - I found that I could pull up quicker when pulling a caravan, using the caravan vacuum brakes as well (there was a manual control on the steering column for the caravan brakes).
The 45 was pretty hopeless at towing a heavy industrial caravan - the vehicle was all over the place. Judicious application of the manual caravan brakes seemed to straighten the wobble up.
I recall the 6-cyl engine was about 3.4 or 3.6 litres, supposedly of an old wartime Chev design. Quite poor torque, not helped by the 3-speed box; a 4 cyl 4-speed Landie was much better in sand.
Our fuel consumption used to be about 10mpg, but then we pushed them. The Landie we had gave us about 15mpg, but was much slooower. The 10 gallon fuel tank on the Landie was a joke - ok for GB, but useless out in the bush here in Oz. The Cruisers had about a 20 gallon tank (90L), I recall. Our 55 wagon had an aftermarket 20-gallon tank fitted behind the back
seat, so range was quite good, though we always seemed to run out on one tank just as you were passing someone!
But the speed of the FJ55 was what impressed - we used to have no problem hitting 90mph out on the Nullarbor then, but it took nerves of steel to keep it on a steady course.
We used to frequently have wheel studs shear, and twice lost a wheel when towing a trailer (no, not at 90mph!). Luckily, no serious accident on either occasion. Our Automotive Plant gurus' response was for us to check the nuts every day before driving off.
One of our 55s was replaced in '71 with a much better 4-speed 55. Much better put together, better interior fittings, and a lot better in the sand. A bigger engine and a (slightly) better fuel economy - Toyota must have played with the tuning of the engine, as it was better all round. Unfortunately we rolled it at 8000
miles on the clock, writing it off, and we reverted to the older wagon. One ageing 55 blew the motor at about 85,000
miles, about 200
miles out on the Nullarbor. We had been pressing for a replacement wagon for some time, but this forced the hand of our employer. An expensive recovery back to town.
Other annoying things were the buzzing transfer case lever. We used to tie an occy strap to the lever and hook it under the dashboard to stop it rattling.
And the sunvisors! Turned down, they finished on a plane about 10cm above one's eyes, so were totally useless driving into the sun. I'm 180cm; ie, not short, so I don't know how Japanese drivers fared driving into the sun. To cure this, I used to hang a magazine over the visor so it finished on a plane just above my eyes.
The vinyl seats were terrible in hot weather out on the Nullarbor, so I used to put a towel on the
seat (no a/c in those days). At least they were more comfortable than the square block of foam cushion that Landrover supplied back then.
Back then the Japanese weren't sure how much info to provide in their owner's handbook. There was a chapter on how to engage and disengage the clutch, change gears and apply the brakes!
Gerry
508703
Follow Up By: Bill N2 - Friday, Apr 12, 2013 at 07:54
Funny you should mention the buzzing transfer lever, well, not funny really more pathetic really.
I have a 2006 105 series with the most BUZZIEST [ I know that's totally unacceptable spelling and grammar but I can't help it ] transfer lever ever to come out of a Toyo factory. Disappointing after all this time that Toyo can't solve such a simple issue.
Having said that I must say the ride quality on the standard
suspension is excellent. So since 1966 advances have been made.
I used to service some of the roo shooters vehicles, those boys really knew how to get the best out of a 4WD.
786398
