Macerating toilets
Submitted: Saturday, Jan 12, 2013 at 08:23
John E
Hi all,
Has anyone out there had any experience with macerating marine
toilets in a caravan ? We have had it suggested that we install one instead of the normal Thetford cassette model in a new van. Any comments would be welcome
Thanks,
John and Lyn
Reply By: Grumblebum and the Dragon - Saturday, Jan 12, 2013 at 09:02
Never heard of macerating
toilet in a caravan...... souinds like more moving parts than a Thetford, maintenance may be a mucky issue. We have for the last seven years used a Thetford and dosed it with 'home brand' version of Nappisan. The home brand version is one third or more cheaper than the branded option and has more of the active ingrediant Sodium Percarbonate.
We have found that the effluent 'self macerates' in the cassette pretty rapidly... never any 'lumps' in the discharge when emptying.... unless thay we very recently deposited.
If you get my drift!
502324
Reply By: Alloy c/t - Saturday, Jan 12, 2013 at 10:14
Not in a c/van, but you will find you will need more
water to flush and thinner
toilet paper than your normal 2ply for the macerator to effectively shred up ,,,
502336
Reply By: Dennis Ellery - Saturday, Jan 12, 2013 at 10:48
Why bother chewing it up – lumpy or thin its all the same crap.
502340
Reply By: Member - Mark (Tamworth NSW) - Saturday, Jan 12, 2013 at 10:50
Did the person who suggested it say why, I couldn't think of anything worse?
You aren't serious are you?
Mascerating
toilets are for yachts which have an unlimited supply of flushing
water, no holding tank requirements such that you don't (easily) see the effluent when anchored in a mooring. I couldn't think of anythiing worse for a caravan.
IF you still want to pursue it member mesage me and I will pass on my old man's details for you to contact, he is a retired plumber who has owned yachts with those
toilets for over 20 years and also has a caravan.
502341
Reply By: Member - Rod N (QLD) - Saturday, Jan 12, 2013 at 14:00
I thing it would be a waste of money for all the same reasons as posted on the Caravaners
Forum.
502361
Reply By: tg123 - Saturday, Jan 12, 2013 at 14:18
Hi John
I've an AOR Quantum camper with mascerating marine
toilet and think it's fine! They used to fit a vacuum type
toilet but for some reason the supplier can no longer supply. Yes, the mascerating
toilet uses more
water for flushing but has its own dedicated 35L flushing tank. The waste empties into a 60L holding tank which is quite easily pumped out at dump points or can be offloaded into a portable 20L Fiamma container ( a few fills obviously!!) if needed. The 2 of us easily get a week's worth of use before it needs emptying rather than the 1 or 2(?) days from the Thetford type.
The only downside is that the mascerating pump is pretty noisy but in reality you only flush for a few seconds and at night the yellow can mellow until morning.
Hope this helps!!
TG
502362
Follow Up By: Alloy c/t - Saturday, Jan 12, 2013 at 17:45
Just spent 10 days an a bareboat charter in the Witsundays , 60 lt holding
tank required emptying EVERY DAY, 4 people , no yellow after sunset from 3 ,,,,,
778795
Reply By: The Bantam - Saturday, Jan 12, 2013 at 18:26
The question to ask is why macerate at all.
The reason most boats use a macerator is because it is required to macerate the waste before discharging into open
water.
My undertsanding is some macerate from the bowl into the waste
tank and others macerate immediately prior to discharge.
Mostly it is illegal to discharge in port, in marine
park areas and in enlclosed waters ( it was once not so)....so more boats have to hold more material......many boats when "outside" will discharge direct on demand...this may be why they macerate direct from the bowl.....some may also discharge by gravity from their
tank.
So the first question to ask.......is do you want to run a large waste
tank and pump out / drain with a hose or run a small
tank and portable
toilet and manually handle it.
then you need to look at the details.
how many dump points have a ground level inlet point?
depending on what you do and where you go you may not need to macerate at all and you may not need a pump at all, except to lift the flush
water.
If you have a system like a construction site
toilet, there is no macerator, no pump and the flush
water is minimal.
more research required.
502383
Reply By: Member - Captain (WA) - Saturday, Jan 12, 2013 at 20:35
Hi John and Lyn,
I have an AOR Quantum but with the vacuum
toilet. The newer Quantums have the macerator, as posted above. The main reason AOR use these types of
toilets is that they have no chemicals and thus can be dumped in long drops and the like, unlike chemcal
toilets which are banned, regardless of what type of chemical is added (due to compatability issues).
Most of the Quantum users of the macerator
toilet are getting at least 4 days from the 85L
tank, obviously depenedant on usage. They also have a portable container to be able to empty the main
tank if parked up for a while (23L from memory).
If mainly using caravan parks and the like, probably just as easy (and cheaper) to stick with a chemical
toilet, but if going off-road then chemical free
toilets are the go IMHO.
Captain
502391
Reply By: John E - Sunday, Jan 13, 2013 at 07:23
Many thanks for the replies re Macerating
toilets.
Will stick with the cassette type.
502407
