Self-priming electric water pump for camper trailer
Submitted: Sunday, Dec 09, 2012 at 18:33
ThreadID: 99419 Views:10845 Replies:8 FollowUps:4
Can anyone either recommend a cheap(ish) self priming electric water pump for me to put in line beneath the hand pump that's already there, which SWMBO nuts?
Or alternatively, tell me how long a Whale or Jabsco will retain its prime or whether there are little non-return valves to help it hold its prime. Can't seem to find what I'm after, using Uncle Google.
Grateful any assistance.
Reply By: Mick O - Sunday, Dec 09, 2012 at 19:12
Paul,
I'm using several Shurflo 2088 auto pumps about the ute. They are largish and have a flow rate of 10.6 litres per minute. There are smaller models, the Nautilus 100 and 105 models that are half the size and deliver 3.7 litres per minute. All self priming and have check valves to prevent flow back. Available at caravan RV accessory stores like Carac. $60 or thereabouts should see you with one in the hand. I'm sure the other brand Flojet will have similar models at similar prices as well
Cheers Mick
AnswerID: 500079
Follow Up By: Member - Paul B (WA) - Monday, Dec 10, 2012 at 02:02
Wonderful, thanks Mick. This looks like just the thing.
FollowupID: 776082
Reply By: Member - Bruce C (NSW) - Sunday, Dec 09, 2012 at 19:45
Hi Paul,
Here is a link to one on ebay which will do the job nicely.
Caravan pump
Note that you cannot just fit one of these pressure controlled pumps into the line to the hand pump. You will need a seperate line and a tap fitting at the sink on a seperate line for these. Better still do away with the manual one altogether and replace it with this setup.
You may well be pleased you did.
Cheers, Bruce.
AnswerID: 500082
Follow Up By: Member - Paul B (WA) - Monday, Dec 10, 2012 at 02:04
Thanks Bruce
FollowupID: 776083
Reply By: Member - PJR (NSW) - Monday, Dec 10, 2012 at 08:45
We use this one with our Long Ranger dual water/fuel tank in the car to bring the water up to a faucet mounted at the rear of the drawer system. We use a switch to turn it on. I didn't want to rely on an automatic function so I use the switch all the time.
Pump: Jabsco PAR-MAX 2.9 Automatic Freshwater Pump
AnswerID: 500103
Reply By: Member - bill j (VIC) - Monday, Dec 10, 2012 at 10:01
Hi Paul have installed this one under our jayco outback its a 12v whale pump also have a non-return valve under the sink controlled by push button switch.
AnswerID: 500104
Follow Up By: kev.h - Tuesday, Dec 11, 2012 at 18:08
I use the same pump and have a momentary switch - the pump only runs while you hold the button in (I found ordinary switches waste a lot of water especially with the little ones) i added just an extra spout to the sink -no tap works fine
FollowupID: 776221
Reply By: Member - Rodney B - Monday, Dec 10, 2012 at 13:06
Hi Paul
I use the Whale pump also and if you mount it at the outlet (if it is on the bottom of your tank) you don't need a primer. Have left both hand pumps in place and fitted a switch at the sink. Works great.
AnswerID: 500109
Reply By: Sand Man (SA) - Monday, Dec 10, 2012 at 18:20
Paul,
Just a couple of things to consider.
When adding the electric water pump, you don't actually place it in line.
You need a Y piece.
The bottom of the Y is the feed from the water tank.
One of the branches goes to your existing hand pump and the other to the electric pump.
Also, ensure you have an isolating switch for the electric pump so that it is not "on" all the time. You should only switch the pump circuit on when you wish to use the electric pump, otherwise leave it off. A fuse to protect the circuit should also be included, close to the battery end.
Bill
AnswerID: 500131
Reply By: Member - graeme W (WA) - Wednesday, Dec 12, 2012 at 05:33
Hi Paul.
I used the whale as well.Put it in line under the sink with a switch level with the sink.Sometimes loses its prime after an extended time without use but a few pumps of the hand pump has it fully primed again.When turned on it just pushes the hand pump up.
cheers Graeme.
AnswerID: 500211
Follow Up By: Member - Paul B (WA) - Wednesday, Dec 12, 2012 at 08:43
Thanks Graeme. That is exactly what I wanted someone to say!
What a helpful thread this has turned out to be.
FollowupID: 776263
Reply By: tim_c - Friday, Dec 14, 2012 at 11:23
The whale pumps (& others like them) are often a submersible pump which means they should ideally be mounted in the tank, or if outside, they should be located below the minimum water level. There is no need to prime them in this situation as gravity will keep the pump primed.
I'm using a ShurFlo (or FloJet?) self-priming automatic pump in my car because having connections below the minimum water level could lead to leaks, & if I'd used submersible pumps, I'd have had to use 3!
I priced them locally and they all seemed to be around $180+ locally but I managed to get one from Amazon.com delivered to Oz for less than half that. I think it's around 10-11L/min which would probably be a bit much except that I've got it controlled with a tap so you just turn it on as hard as you want/need it.
AnswerID: 500335
