Wednesday, Nov 07, 2012 at 00:54
Hi There,
As a person who works in the (earthmoving) tyre industry, the pressures the car tyre dealers often put in your tyres when you get them changed is often higher than you would normally run if you
check them often as most people do not
check their tyre pressure often (or ever) and the dealers account for this by putting a more pressure in them than car manufactures recommend.
There are multiple issues with this if you do infact
check your tyre pressures often as the "higher than normal" pressure is what you assume your tyres should be at, therefore you continue the practice. This causes issues such as centre wearing in the tyre as when the tyre is over inflated the tyre is no longer "square or flat bottomed" on the road and is now slightly oval shaped. This means all contact is with the centre area of your tyre, wearing the centre much quicker. To see this in effect, look at your deflated tyre carefully or simply measure the tread depth difference from the shoulder area compared to the centre.
The other issue is underinflation. Underinflation causes the opposite effect to above. The shoulder will wear quicker than the centre. Depending on you load and wheel alignment (and everything mentioned above by others) etc, you may see uneven wear such as side loading on the tyre. Another
sign of underinflation is "Heel / Toe Wear". This is within each lug. Someone described above the lug coming to a "point" front to back, this is classic underinflation. To fix this wear, rotate the tyre to run in the opposite direction (so run on the opposite hub) and increase your tyre pressures.
"Scalloping" however may be caused by constant heavy breaking or constant sharp quick cornering. Just be conscious of how you drive over the next few days and see if you find yourself pulling up hard or quickly at the traffic lights.
Another thing to
check is your rim offset if you have aftermarket rims. Occasionally the incorrect rim offset may cause wear issues. Without physically looking at it, Due to the severity of your issue, it may be a bigger issue such as
suspension.
40psi is what i was running in my 245/65R17 Bridgestone D697 on my work Prado constantly on the last set of tyres. It wasn't until i got a flat tyre on a worn tyre that i noticed the centre wear due to the over inflation. I dropped them down to 36 psi on the new set but admitadly i didnt like how they drove at the lower pressure. This may simply be because i am used to the harder tyre. I put them back upto 38 psi and it feels much better. My work car is usually empty so in hindsight 40psi was probably too high.
Your tyre pressures should reflect your load in your vehicle and your tow vehicle if applicable. It also should reflect the terrain you travel.
Slightly Higher pressures for distance highway driving with load but if you are just driving around town you can safely lower your pressures to the manufacturer pressure of the car and tyre (depending if you car is always fully loaded like ours e.g. draws, engel, rear wheel carrier etc.)
Talk to your tyre dealer and he should be able to give you approx pressures you should be running in your tyres for each application. Just play with it til you like how it drives.
Last of all, ensure you rotate your tyres to the diagonally adjacent position every 5000 to 10 000 km. This will help pickup uneven tyre wear more regularly and even any abnormal tyre wear out. If the side wearing is noticable and the tyres still have life in them, maybe even get the tyre dealer to strip and flip the tyre on the rim.
All pressure readings should be made cold, and the air in the tyre when inflating is measured cold on your guage as
well. If you
check your tyres hot, the reading is incorrect as hot air expands and gives you a false higher than actual reading. E.g. if you take a hot reading of 40psi your tyres cold are actually closer to 32 psi. This is when uneven tyre wear is caused. **I know this is common sense but i have to tell fitters on
mine sites this every day i go to work and they still dont listen!**
Good Luck
498061
