Head Gasket
Submitted: Thursday, Aug 23, 2012 at 13:15
Roger E
I have a
Ranger 3.0L Turbo Diesel with a blown head gasket. It has done 210,000 K's and I was wondering whether to repair it, or to put a second hand motor in it.
Does any one have any experience of the cost to repair a head gasket?
At this stage, I have not found the actual cause for the blown head gasket (eg radiator, water pump, front fan, hoses, thermostat), so there may be more than just the head.
I have had the CO2
test which confirms that it is the head gasket.
Any suggestions appreciated
Roger
Reply By: fisho64 - Thursday, Aug 23, 2012 at 18:47
Id second the above, try Chemiweld. My ute had a cracked head (or maybe a leaking head gasket), alloy head Hilux. There were symptoms but not to bad-missing on startup, loosing a little coolant etc.
I did an oil sample and it showed up on there immediately.
Used Chemiweld exactly as per their instructions-40000km ago.
Ive done 2 samples since and the coolant (phosphorus or potassium from memory) is a complete no show.
493470
Follow Up By: Roger E - Thursday, Aug 23, 2012 at 18:51
fisho64,
That is remarkable and has made me think again about trying some.
Thank you
769074
Follow Up By: fisho64 - Thursday, Aug 23, 2012 at 19:39
certainly suprised me too. I did it as a temporary while I looked at quotes for a replacement head but its been
well over 14 months now.
Its not easy to do it as per their instructions but basically its
1/ drain and flush out coolant
2/ fill with clean water
3/ add Chemiweld
4/ start up and run the engine up to a temp hotter than normal running temp, by partially blocking airflow to rad with cardboard for 20 minutes.
5/ let it cool and drop the mixture and flush with water.
6/ Add coolant and
check it see if symptoms have gone.
769081
Follow Up By: get outmore - Sunday, Aug 26, 2012 at 04:17
on the flip side i used chemi weld on a cracked head and it didnt do a damn thing except throw chemi weld everywhere as it blew it out the overflow
769208
Follow Up By: howesy - Sunday, Sep 09, 2012 at 11:15
have used chemi weld a few times over the years, seems to work on some cracks and not others but the ones where I had no sucess I used sealup solution and it worked fine. Same statement applies for sealup they seem to work on different applications
770200
Reply By: Roger E - Sunday, Sep 09, 2012 at 07:22
Well,
Here I am asking for help again.
It is all back together and will not start.
One thing that I thought that it coould be is the timing belt, despite thinking that we had done this correctly.
The engine just vranks over and does not look like firing.
We did blow a fuse to the glow plugs , this does not happen now after we made sure that the bar connecting them all was not touching anything. I have chacked and they doe get power for about 5 -10 secs to the glow plugs just after you turn on the ignition.
When you first turn on the ignition, there is a whiring sound which then stops. I do not know what this is.
Does anyone have any further ideas on what it could be before I pull the front off to again
check the timing belt???
Regardss,
Roger
494538
Follow Up By: Roger E - Friday, Sep 21, 2012 at 19:40
Dear all,
I am beginning to tear my hair out.
Have done the head gasket and put it all back together, but it does not start.
I have sprayed the stuff with the Ether in it into the air filter and it fires, then stops when it runs out of the ether mixture.
I have checked and it is getting fuel to the injectors.
It would appear that there is no signal going to the injectors to tell them to put fuel in.
It might be the crank angle senser and this is the next thing to
check, but one of these will cost significant dollars.
I fail to see how I could have done this in all the things we took off to change the head gasket.
Any other ideas from someone with more experience than me would be greatly appreciated
Regards,
Roger
771024
Reply By: Roger E - Wednesday, Oct 10, 2012 at 17:33
Hello again,
This goes from bad to worse.
I have done everything that I could, even admitted defeat and took it to the Ford Dealer.
They are now telling me, after about $1500 that it needs a fuel pump.
This is internal to the engine and will cost so much that I am now at the point of sourcing another motor.
If anyone knows where I can get a 3.0L turbo diesel motor for a reasonable price, I would really appreciate it.
Regards,
Roger
496399
