Monday, Jul 30, 2012 at 19:02
I agree with David on this and have also posted about this disgusting behavior before on here.
Education is the only real way to deal with this matter and you won't always score a win either.
But we need to try and so long as each of us who reads this does the right thing then we are starting to win the battle.
I recently did a change to our method of disposing of
toilet paper and the associated wet ones.
A bit like what John describes above with his zip lock bag but we use a simple brown paper lunch bag instead.
You buy them for about $2- for a hundred or so from the
supermarket and instead of trying to burn the paper etc in the hole before filling it in, stuff the paper and wet ones in the brown paper bag, bury the remaining bodily waste properly and then put the paper bag in the rubbish bag carried like most others do on the rear wheel carrier.
In my rear rubbish bag I simply have two garbage bags, one is the burn bag the other is not which contains can's, tins, bottles etc stuff that you would obviously not burn but dump in a proper bin in the next town etc.
You could even use two different colored garbage bags if you wanted to make it even easier to distinguish which was which.
The burn bag is simply emptied every night at a suitable time that a fire is available and the contents gone!!
Or if I come into a town etc then it too will go into proper disposal bin.
Everyone knows what is in those brown paper bags on the trip and deals with them accordingly. No smell or issues.
Its a simple easy system, cost is almost nothing, effort required is next to nothing, no hassle, easy as and the results to our
camp areas is easy to see!!
Traveled for many weeks at a time doing this and works
491940
Follow Up By: Member - John (Vic) - Monday, Jul 30, 2012 at 19:03
Oops!! that should have been "Val describes above". :((
767553
Follow Up By: Member - John and Val - Monday, Jul 30, 2012 at 21:37
Thanks John!
Val
| J and V
- Albert Einstein
767568
Follow Up By: Member - KYLE S - Tuesday, Jul 31, 2012 at 12:36
Rubbish is a problem every where. Particularly take away food containers/wrappers and empty cans and bottles in the metro area. And of course the issues raised in this thread in the bush.
Clearly it is because of the "I am alright Jack someone else will clean it up" attitude of far to many.
The frustrating thing is that you could educate these folk till you are blue in the face but to no avail.
Perhaps a strong Government might introduce the Singapore solution. Cleanest place I ever did go.
767607
