Ford courier WLT engine timing marks
Submitted: Friday, Jun 29, 2012 at 17:32
120scruiser (NSW)
Hi all
A friend had a Ford Courier WLT 2.5 TD engine delivered to his factory in pieces and is trying to re-assemble it. He is stuck with the engine timing.
Does anybody have a diagram on the injector pump timing marks and any other front timing gear marks please?
He has got all the balance shafts timed but is in a pickle with the pump timing.
It is the worst job, trying to put back together something that somebody else pulled apart.
Thanks in advance.
Scott
Reply By: Rod J - Saturday, Jun 30, 2012 at 09:08
Hello Scot, can you give me a email at curly5_0@hotmail.com & i can send You some thing that might be helpful.
Cheers Rod
489731
Follow Up By: 120scruiser (NSW) - Saturday, Jun 30, 2012 at 10:58
Email sent.
Thank you
764861
Reply By: Graham & Lynne - Saturday, Jun 30, 2012 at 10:47
Does he want the timing gear marks that are inside the timing case in the engine oil or timing belt marks?
Thanks Graham
489739
Follow Up By: 120scruiser (NSW) - Saturday, Jun 30, 2012 at 10:57
The timing gear marks inside the front cover.
The timing belt marks are really simple.
764860
Reply By: prospect_or - Sunday, Jul 08, 2012 at 09:58
They are a Nissan engine aren't they? Nissan TD25
If it is I might have the info in my manual . I've got a Navara with a TD27 deisel engine.
490378
Follow Up By: 120scruiser (NSW) - Sunday, Jul 08, 2012 at 20:02
All good thanks.
Job done.
I don't think its a Nissan engine. Ford and Mazda are the same.
765763
