Wiring of Anderson Plug
Submitted: Wednesday, Jun 13, 2012 at 15:23
ThreadID: 96245 Views:19638 Replies:4 FollowUps:7
Related Pages
Hi all,
What is the correct way to wire the Anderson plug, for the trailer, to the car battery system.
I have dual batteries with an isolator.
Thanks, Ian
Reply By: Member - Bruce C (NSW) - Wednesday, Jun 13, 2012 at 16:01
Hi Ian,
Pretty simple installation so here is a diagram
Image Could Not Be Found
I have not specifically shown the earth or neg wire but a good chassis earth at the back of the car is good enough provided a good chassis earth is pressent at the Aux battery
Cheers, Bruce.
AnswerID: 488382
Follow Up By: Member - Barnray (NSW) - Wednesday, Jun 13, 2012 at 16:09
Sorry Bruce but you need to run 6bs TWIN not single from main to Aux and to Anderson plug, there is to much chance of a bad earth thru the body of the car and trailer. A lot of fridge complaints are caused by poor wiring. Barnray
FollowupID: 763570
Follow Up By: Whirlwinder - Wednesday, Jun 13, 2012 at 17:10
Thanks guys for the great and fast replies.
That was what I thought I should do but nice to get confirmation.
Also thanks for the info on connecting the ends.
Now to buy the stuff.
FollowupID: 763574
Follow Up By: Member - Bruce C (NSW) - Wednesday, Jun 13, 2012 at 17:33
Ian I recommend you get the bits from your local autoelectrician as mine was a lot cheaper than superdear or repco. I paid around $8 for quality anderson plugs and his wire was cheaper than most as well. He should be able to supply all your bits and peices.
Bruce.
FollowupID: 763575
Follow Up By: Member - Bruce C (NSW) - Wednesday, Jun 13, 2012 at 17:51
I just checked out ABR Sidewinder and they have everything at a reasonable price as well
FollowupID: 763576
Reply By: Ross M - Wednesday, Jun 13, 2012 at 16:10
Make sure you fit the +ve connector into the +ve marked section on the Anderson. Real easy to get one set wrong/swapped frack to bunt.
Double check all connections with a multimeter first before EVER plugging the Andersons together. Not a pretty sight if you inadvertently got it wrong.
Hundreds of amps running in a dead short circuit. Make sure both/all +ve connections to batteries have a heavy fuse in them so IT will blow and avoid the flames.
All the earth cables will have to be the same size or bigger if you want everything to operate properly with out troublesome voltage drop causing insufficient charge to batteries and poor performance of appliances.
Ross M
AnswerID: 488383
Reply By: Flighty ( WA ) - Wednesday, Jun 13, 2012 at 16:49
Ian.
You could not have timed your question better, just got back from buying plugs & about to ask the same.
Hope you don't mind.
Paul
AnswerID: 488389
Reply By: ABR - SIDEWINDER - Wednesday, Jun 13, 2012 at 16:56
Hi Ww
Have a look here:Battery-Charging-Art
Derek from ABR
AnswerID: 488391
Follow Up By: ABR - SIDEWINDER - Wednesday, Jun 13, 2012 at 16:58
Here is a link that shows you how to fit Anderson plugs. Link: How-To
FollowupID: 763573
Follow Up By: Member - KYLE S - Thursday, Jun 14, 2012 at 09:59
ABR
Diagrams are very clear and no doubt will be very useful.
I had an Anderson plug on my previous car mainly to power the boat winch.
I installed it same 10 plus years ago and have just sold that car.
I wish to put plug on new vehicle but I'm getting old and can't remember the circuit breaker capacity I used.
Can't find current draw on winch but it pulls max 4000kgs.
I would be great full if you could advise the circuit breaker amps I will need.
Thanks Kyle
FollowupID: 763611
Follow Up By: ABR - SIDEWINDER - Thursday, Jun 14, 2012 at 22:53
Hi Kyle
Email me the spes and a photo of the winch.
Derek
FollowupID: 763648
