Oilskin and Mould...Looking for answers.
Submitted: Tuesday, Jun 05, 2012 at 12:34
ThreadID: 96042 Views:11907 Replies:6 FollowUps:7
Got the old drizabone vest out of storage from the depths of the van today, and found it covered with mould. No mould in or on anything else in that compartment.
Looking for ideas on how best to clean the vest of the mould.
Reply By: Sigmund - Tuesday, Jun 05, 2012 at 12:51
A ten per cent solution of bleach like White King and water. Do it twice to be sure with drying in between to get rid of remaining spores.
You may need to reproof it after that.
I used to wear Belstaff waxed cotton on the motorbike, way back when. Today's stuff is better!
AnswerID: 487699
Follow Up By: Member - eighty matey - Tuesday, Jun 05, 2012 at 13:05
I was told white vinegar is better than bleach because it kills the spores, while bleach takes the colour out of them.
Google has some sites I think,
Steve
FollowupID: 762957
Follow Up By: Dave(NSW) - Tuesday, Jun 05, 2012 at 13:30
Oil of cloves will kill the spores without bleaching anything.
Cheers Dave.
GU RULES!!
FollowupID: 762960
Follow Up By: Sigmund - Tuesday, Jun 05, 2012 at 13:43
And make him smell interesting!
FollowupID: 762962
Follow Up By: Bazooka - Tuesday, Jun 05, 2012 at 17:51
As Dave said. That's what the queen of clean Shannon Lush suggests for mould generally. Test it on a small area first of course.
This is the nearest I could find with a quick search:
4. Cleaning Mould spots from leather couch
1/4 teaspoon of oil of clove into a small bottle of baby oil. Shake it up, then put a few drops on a cloth and wipe the couches down. Repeat the next day and the mould will be gone.
FollowupID: 762973
Reply By: The Bantam - Tuesday, Jun 05, 2012 at 13:30
Indeedbleach will knock down the existing mould, but it will also sterilise the material, but not kill all the spores...so the mould is then ready to go at the slightest provocation.
Shifting the PH with some form of acid ( vinegar/ citric) will inhibit the mould growth more than bleach.
Some will swing it both ways with bicarb and acid
I have proven this on bathroom cieling....but...on an oil skin......hmmmm
What do "dry as a bone" recommend.
Ya may be simply better off hand washing it with detergent and several changes of water and then rinse very well.....remember what bleach does.
drying well then exposing it to sunlight inside and out.
Of course you will have to re-oil.
AnswerID: 487706
Reply By: Ron N - Tuesday, Jun 05, 2012 at 17:17
Fred - I wouldn't be using bleach, it's too savage. Not only does it strip colour out, it weakens fibres and is generally quite destructive.
Bleach is O.K on tiles, fibreglass and shower recesses, it works great there - but on any type of clothing, it will do more harm than good.
Even when I work over the shower, I only use about a 25-30% solution of bleach, and that's still plenty to kill mould.
Cheers - Ron.
AnswerID: 487718
Reply By: Coenen N & G (WA) - Tuesday, Jun 05, 2012 at 19:41
If you check Shannon Lush's books on cleaning anything she would say to dissolve a kg of plain cooking salt in a large icecream container and bush this solution over the item of clothing. Hang the jacket out to dry thoroughly. When the salt crystals form, brush them away with a stiff brush. This will take the mould with it. Then you put a quarter of a teaspoon of oil of cloves in a 1ltre spray bottle of water and spray the item to kill the spores.
Bleach will rot the material and spoil the jacket.
You can re-oil it if necessary. Oil is available where ever good oil skins are sold.
regards
AnswerID: 487743
Follow Up By: Member - VickiW - Tuesday, Jun 05, 2012 at 20:07
Probably saddleries too (oil for oil skins)
FollowupID: 762991
Reply By: Fred G NSW - Tuesday, Jun 05, 2012 at 21:07
Many thanks for those replies good folk. I have taken those pointers on board, and will let you know of the outcome.
BTW I found a patch of mould on the wall of the cupboard, after I emptied it completely, and will have to deal with that as well.
That was the only cupboard I did not have one of those damp rid thingy's, and the mould arrived so quickly with the onset of winter. Strange how it only attacked the oilskin, which hadn't been worn for over 12 months.
AnswerID: 487753
Follow Up By: Andrew & Jen - Tuesday, Jun 05, 2012 at 22:42
Hullo Fred G
An old timer pointed out to me very early on that you usually see oilskins in the bush hanging up where they get good air circulation and that the air is, if possible, warm and dry.
After use, I try to make sure that mine have a spell of a few days hanging free near the fire place. (In fact they are there now :) Has worked a treat so far.
Andrew
FollowupID: 763006
Reply By: Member - Bucky - Wednesday, Jun 06, 2012 at 03:24
Fred
Problem with bleaches, they are chlorine based, the Stitching will perish, and the colour will run, and the Spores will live thru it.
Go for the more non corrosive spore killer, like Viniger or Oil of Cloves
To fully seal it against all weather I use bees wax, which can be applied liberally and rubbed onto the surface, with a cloth, and to fully impregnate into the Dry as a bone", I use a hair dryer.
It's Magic !
I did my vest 6 years back, and it's still good.
Bucky
AnswerID: 487775
Follow Up By: Fred G NSW - Wednesday, Jun 06, 2012 at 10:44
Thanks Bucky.
FollowupID: 763023
