another deep cycle Battery question
Submitted: Thursday, May 24, 2012 at 12:37
ThreadID: 95769 Views:2085 Replies:2 FollowUps:0
my solar system is 180 watts, 2x 105 ah Batteries. 6 months old
it usually floats on 14 .2 volts.
accidently left fridge on 12 volts for 3 /4 days,only realised when water through fridge.
system will only charge to 3.7 volts then float.
van has a projecta charger installed to charge when on 240 volts
have tried another charger on batteries (projecta 8 amp)
still only getting 13.7 floatcharge
Is it possible to get batteries back to 14.2 float?
Barry Perth
Reply By: Gronk - Thursday, May 24, 2012 at 17:23
Not sure what went on before you had this " trouble " , but if they are agm's.....they should be on 13.7 at float..
Have you accidently changed the settings on the charger ? if you have, I'd leave the settings the way they are ..
Have a look at the manual and make sure of all the settings ..
AnswerID: 486663
Reply By: ABS - Friday, Jun 08, 2012 at 10:46
Give the guys at Aussie Batteries & Solar a call on 1800 853 315 they will answer any question you have and have great prices on deep cycle batteries - http://aussiebatteriessolar.com.au/
AnswerID: 487928
